ones tens hundreds counter to eliminate and up/down counter[ASM]
Results 1 to 2 of 2
    Sep 2007
    Default ones tens hundreds counter to eliminate and up/down counter[ASM]
    I have a speed alert code which i need to modify with 3 extra push buttons (Used on a PIC16F886) - A ones, tens and hundreds placeholder to input the speed limit
    Would you think it would be viable to have both a three button input and an up down input? If not how would i replace the up down counter with these three buttons.
    If i keep the up down buttons - How could I add the ones, tens and hundreds placeholder buttons ontop of this? I will be using PORTC - (excluding PIN17 and PIN18 NEEDED FOR EUARTS (RC6 and RC7))
    so I'm thinking i'll do the following
                STATUS          equ 03h
                TRISA             equ 87h
                PORTC            equ 07h
                                      bsf                    STATUS,5
                                      movlw                03h          ; RC0,RC1, RC2 = inputs
        ; (Hundreds,Tens,Ones)
                                      movwf               TRISC
                                      bcf                    STATUS,5
    Register map is included here
    (i'll play with RC6 and RC7 once i read up on EUSARTS )
    I was planning on having a temp variable - templimit such that I can store the actual speed limit in it as follows:
    templimit = (hundreds*100)+(tens*10) + ones.
    This would set the speed limit then I'd use the serial EUSART to overwrite this if it needs to be automatically updated.
    the locations for the up/down counter is:
    *Polling for
    - down button: Line 863
    - up button: Line 869
    * incrementing the speed
    - line 925
    * decrementing the speed
    - line 936
    Any help - whether theory or advice would be highly appreciated.
  1. UP/down counter & shiftout interupt problem
    By RFsolution in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2007, 16:56
