How can I turn off USB support in 18F4550
Results 1 to 2 of 2
    Default How can I turn off USB support in 18F4550
    I have a simple BLINK program that uses 92 words in a 16F877A, 146 bytes in an 18F4620 and a HUGE 2104 bytes in the 18F4550. A quick look at the .LST file shows a lot of routines for the USB port are loaded by default.
    I don't need the USB port in my current project but I do need the code space. How can I prevent the USB support being loaded by default? Sadly I am stuck with the 18F4550 for this job.
    The BLINK code follows.
    ' Example program to blink an LED connected to PORTB.5
    ' define osc 4
    define loader_used 1
    LED var portb.5
    loop: High led
    Pause 100
    Low led
    Pause 100
    High led
    Pause 100
    Low led
    Pause 100
    High led
    Pause 100
    Low led
    Pause 2000
    Goto loop
    ' A PIC 16F877A using PBP 2.47 and PM assembler uses 92 words
    ' A PIC 16F877A using PBP 2.47 and MPASM uses 89 words.
    ' A PIC 18F4680 with PBP 2.47 & MPASM uses 146 bytes.
    ' A PIC 18F4550 using PBP 2.47 and MPASM uses 2104 bytes because it loads
    ' the USB libraries - need to kill that.
    Default Found problem.
    I can now compile BLINK to 146 bytes.
    The problem is simple. I copied the USB demo program from USBDemo http://www.picbasic.co.uk/forum/showthread.php?t=5418
    and all its files to c:\testcode last week. This has a number of files xxxx.BAS, .INC, .ASM and yyyy.MAC.
    I then wrote the simple BLINK program and placed it in the same c:\testcode directory. It seems PBP uses its BAS, RAM, INC, etc files from c:\testcode first rather than from c:\pbp.
    By deleting all files from c:\testcode except BLINK.PBP, the program now uses only 146 bytes.
    What a relief.
  1. 18f4550 usb problem.. so im getting crazy..
    By MeSaKu in forum mel PIC BASIC Pro
    Last Post: - 11th May 2009, 22:03
  2. 18f4550 USB and pulsin or pulsin alternative
    By vacpress in forum mel PIC BASIC Pro
    Last Post: - 15th January 2009, 13:14
  3. Usb Mass Storage With 18f4550
    By wagner in forum USB
    Last Post: - 17th August 2008, 16:46
  4. USB Programmer for 18F4550 PICs
    By Kamikaze47 in forum USB
    Last Post: - 21st August 2007, 16:29
  5. LCD will not start
