time counter using pic16F84A (need help in checking my code)
+ Reply to Thread
Results 1 to 4 of 4
    Aug 2007
    Smile time counter using pic16F84A (need help in checking my code)
    i am a colleage student and i am doing a pic project..
    my project's concept is connecting a normal switch to the pic and let pic to count the time (in seconds) when the switch is switched on and display the results on LED until switched off...
    EXAMPLE: when the switch is (switched on), pic starts to count the time from 0 second to xxx seconds. When the time is less than or equal to 5 seconds, it will blink the LED in portb.0. When the time is more than 5 seconds, it will blink the LED in portb.1. Then, when the swith is (switched off), the time counter will reset to 0 and wait for the next press on switch....
    THIS IS MY CODE:
    DEFINE osc 4 'using 4MHz oscillator
    second VAR BYTE
    TRISB.0= 0 ' define portb.0 as output
    TRISB.1= 0 'define portb.1 as output
    second= second + 1 'count from 0 second..1 second..2 seconds and so on..
    start:
    IF second <= 5 THEN
    GOSUB loopa
    GOSUB loopb
    PAUSE 500
    loopa:
    HIGH PORTB.0 'blinking led in portb.0
    PAUSE 500
    LOW PORTB.0
    PAUSE 500
    GOSUB loopa
    loopb:
    HIGH PORTB.1 'blinking led in portb.1
    PAUSE 500
    LOW PORTB.1
    PAUSE 500
    GOSUB loopb
    RETURN 'return to start and count continuously until switch is switched off
    But...my circuit cannot work..
    i had read through picbasic Pro data sheet but i still dunno which part i did wrongly..
    So..can anyone give me guidelines or tell me the errors in my project?
    I will appreciate it...
    Thanks a lot...
    Eric 17/8/07
    Aug 2007
    hmm...
    i have few more questions..
    --- is the define of "TRISB.0= 0" and "TRISB.1= 0" is useless...
    --- should i delete the "RETURN"...
    --- is it suitable to use "IF..THEN...".....how about "FOR...TO...NEXT"
    --- is the define of "OSC 4" is useless...
    thanks for helps..^^
    1. When you use GOSUB to reach a sub-routine, there should always be a RETURN to get back.
    2. TRIS is not necessary when using the HIGH and LOW commands.
    3. GOTO start at the end of start ensures program execution will loop in start, and not fall through to the routines below it.
    See how this works.
    second VAR BYTE
    'TRISB is not necessary when using the HIGH and LOW commands
    'TRISB.0= 0 ' define portb.0 as output
    'TRISB.1= 0 'define portb.1 as output
    start:
    IF second <= 5 THEN
    GOSUB loopa
    GOSUB loopb
    PAUSE 500
    GOTO Start
    loopa:
    PAUSE 500
    LOW PORTB.0
    PAUSE 500
    'GOSUB loopa ' replaced with RETURN
    loopb:
    PAUSE 500
    LOW PORTB.1
    PAUSE 500
    'GOSUB loopb ' replaced with RETURN
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Aug 2007
    Hi Bruce,
    thanks for your help...i very appreciate it..
    i will program it in my school laboratary later..
    hope that i can get the results..
    Eric...
  1. Help with Pic Delay code mod please
    By g7jiq in forum General
    Last Post: - 26th March 2009, 00:06
  2. Making Program Code Space your playground...
    Last Post: - 19th July 2008, 08:26
  3. Code snippet: time execution for each line: help please
    Last Post: - 6th April 2008, 15:46
  4. I don't understand this code!
    By Russ Kincaid in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 02:55
  5. Time diference in microseconds
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 14th March 2005, 08:25
