multipal serial ports
Results 1 to 3 of 3
    Default multipal serial ports
    Hi there
    I need to build a series comms repeater. I require 2 and in future maybe a third port, my problem is that I need to use even parity and serin does not support it. I could be fine with a chip that has 2 uarts in but what if I need a third
    Any suggestions
    SERIN2 can use even parity.
    But since it can't transmit at the same time it's receiving,
    it'll be a whole lot easier with USART's
    Sep 2007
    Smile
    İf you want to communicate many chip.You will use RS485 protocol.But when device send data dont able to recive data at same time.
    http://www.denizelektronik.com/rs485.htm
    RS232-RS485 converter
  1. serial ports, the servo control.
    By m.nobre in forum Serial
    Last Post: - 7th December 2009, 16:16
  2. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 17:03
  3. Question on IO ports
    By studysession in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 18:10
  4. How many serial ports can 1 PIC handle?
    Last Post: - 2nd March 2005, 04:34
  5. Which PIC supports 2 HW serial ports?
    By charliez in forum mel PIC BASIC Pro
    Last Post: - 27th July 2004, 08:01
