need help in decoding RC-5 IR-remote
Results 1 to 3 of 3
    Mar 2007
    Mumbai-INDIA
    Smile need help in decoding RC-5 IR-remote
    Hi All,
    I need some help in decoding RC-5 IR remote, can somebody help me in getting started with some simple example code as I am still novice. I plan to use pic16f72. I searched forum but did not find sufficient info to start.
    Any help would be much appreciated especially with sample code to start.
    Thanks in advance
    vu2iia
    www.vu2iia.blogspot.com
    Mar 2007
    Mumbai-INDIA
    Wink Abt decoding RC-5
    Thank you Ioannis for you help.
    Below is the modified code from Proton to PBP. I made very minor changes and it works very well. Novice may do the modification to suit their needs. Its not my original work.
    Original code is available at http://www.picbasic.nl/indexes_uk.htm
    modified code is given below.It may contain some unwanted lines ignored.
    Code below shows DEC key values on 2x16 LCD. Modify code to suit
    PIC of your choice.
    'Device pic16f72, Its very cheap
    define osc 4
    DEFINE LCD_DREG PORTB 'LCD data port
    DEFINE LCD_DBIT 4 'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTB 'LCD register select port
    DEFINE LCD_RSBIT 3 'LCD register select bit
    DEFINE LCD_EREG PORTB 'LCD enable port
    DEFINE LCD_EBIT 2 'LCD enable bit
    DEFINE LCD_RWREG PORTB 'READ/WRITE SELECT PORT
    DEFINE LCD_RWBIT 1 'READ/WRITE SELECT BIT
    DEFINE LCD_BITS 4 'LCD bus size 4 or 8
    DEFINE LCD_LINES 2 'Number lines on LCD
    PAUSE 500
    lcdout $fe,1,"LCD OK"
    ALL_DIGITAL
    ADCON1 = 7 'disable A/d work digital
    ;Normal aliases (constants)
    Glitch con 52 ;Max 255: Reduction glitches
    SYMBOL LED_Time = 500 ;mSec: Error LED's burning time
    Ok con 50 ;Max 255: Controltime of the RC5 code is received ok
    ;Port aliases
    IR_Receiver var PORTA.4 ;TSOP1736
    ByName var PORTB.0 ;When low the IR-code is given else (unconnected) the System-name and Command-name
    ; 76543210
    TRISA = %11110000
    ;BYTE
    Command VAR BYTE
    CommandOld VAR BYTE
    Systeem VAR BYTE
    SysteemOld VAR BYTE
    BD1 VAR BYTE ;Byte Dummy
    ;BIT
    ByNameOld VAR BIT ;When switching between code- and text-mode and sending the same RC5 code then should the LCD not been updated
    ToggBit VAR BIT
    Value VAR BIT
    ' ID1 VAR BIT ;bIt Dummy
    CLEAR
    GOTO Start
    ;Subroutines
    BitOphalen:
    Value = IR_Receiver ;Make value 0 or 1 dependent from received IR-code
    BD1 = 0
    WHILE IR_Receiver = Value AND BD1 < Ok;Level must change within time 'Ok'
    BD1 =bd1+1
    WEND
    IF Ok = BD1 THEN ErrorReceive ;No level-change whitin the 'Ok' time
    pauseUS 1100 ;950 - 1600
    ;Mainprogram
    Start:
    ByNameOld = ByName
    BD1 = 0
    WHILE IR_Receiver = 1
    WEND ;Wait until a IR-signal is received
    WHILE IR_Receiver = 0
    if BD1 < Glitch then BD1 =bd1+1 'Glitch val 52
    WEND
    IF BD1 < Glitch THEN GOTO ErrorGlitch
    CommandOld = Command ;Save old values for repair in case of a error
    SysteemOld = Systeem
    pauseUS 500 ;200 - 825; Avoid RC5 header
    GOSUB BitOphalen
    Command.6 = Value ^ 1 ;Extended bit
    GOSUB BitOphalen
    ToggBit = Value
    GOSUB BitOphalen
    Systeem.4 = Value
    GOSUB BitOphalen
    Systeem.3 = Value
    GOSUB BitOphalen
    Systeem.2 = Value
    GOSUB BitOphalen
    Systeem.1 = Value
    GOSUB BitOphalen
    Systeem.0 = Value
    GOSUB BitOphalen
    Command.5 = Value
    GOSUB BitOphalen
    Command.4 = Value
    GOSUB BitOphalen
    Command.3 = Value
    GOSUB BitOphalen
    Command.2 = Value
    GOSUB BitOphalen
    Command.1 = Value
    GOSUB BitOphalen
    Command.0 = Value
    lcdout $fe,1
    lcdout $fe,$80,"Sys:", DEC Systeem
    lcdout $fe,$c0,"Com:", DEC Command
    goto start
    ErrorGlitch:
    'original ckt has LED to indicate error, but I have not used.
    'Receive error (No RC5 code or glitch) ' not used
    'pause LED_Time ' not used
    GOTO Start
    ErrorReceive:
    Command = CommandOld ;Repair Command and Systeem
    Systeem = SysteemOld
    GOTO Start
    vu2iia
  1. Replies: 17
    Last Post: - 12th April 2014, 02:17
  2. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 19:52
  3. Plz help in completing RC-5 IR remote lamp dimmer project
    By vu2iia in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2008, 08:44
  4. Decoding car alarm remote
    By George in forum Off Topic
    Last Post: - 19th June 2007, 14:36
  5. "momentary" IR decoding
    By sporker in forum mel PIC BASIC Pro
    Last Post: - 20th June 2005, 01:53
