Problem using Microloader and Uart Comm at the same time
Results 1 to 1 of 1
    Default Problem using Microloader and Uart Comm at the same time
    I have problem using hserout using portc.6 and portc.7 (PIC16F877A) and at the same time I load my program using microcode loader. Can I use the same circuit for microcode loader and at the same time I use the circuit for serial communication to PC using hyperterminal. So far I don't receive any output at the hyperterminal screen or my code is wrong. For your infos, below is my serial communication source code using uart communication
    DEFINE LOADER_USED 1
    DEFINE HSER_BAUD 2400
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_SPBRG 25
    DEFINE OSC 4 ' 4MHZ
    MAIN:
    HSEROUT [DEC 120, 13, 10]
    LOOP:
    GOTO LOOP
    This program should display character "X" at the hyperterminal. Is there any problem with the source code or I cannot use the same circuit for serial comm using microcode loader circuit. For your info, my setting is 2400,8,N,1. TQ
