+ Reply to Thread
Results 1 to 14 of 14
Thread: Quick n dirty HPWM out of phase
    Jul 2006
    Default Quick n dirty HPWM out of phase
    Assuming a PIC with at least 2 PWM channels, can someone suggest a quick way to output two PWMs exactly 180 degrees out of phase with each other?
    I can do it by turning alternating pins on and off but there's no CPU left to do anything else without messing up the waveform.
    Trying not to recreate the wheel...or maybe it's so obvious I can't see the answer.
    La La Land, where errant code runs by
    Quote Originally Posted by ChrisHelvey View Post
    Hardware ways, flip flop, inverter, transistor . . . since you do not want to burden PIC.
    Human ears are very much like the gills on fish, they close whenever the mouth opens.
    California
    Use a PIC with an ECCP (ENHANCED CAPTURE/COMPARE/PWM MODULE)
    16F690 is one.
    Put it in Enhanced Half-Bridge mode.
    Outputs will be on P1A and P1B pins.
    How about a PIC with a Comparator. Feed the PWM into comparator and use the comparator output to give your out of phase signal.
    Advantages...
    No external components
    no software overhead other than setting up comparator
    Disadvantages...
    You lose one comparator and a few pins on your PIC
    Keith
    www.diyha.co.uk
    www.kat5.tv
    California
    Thumbs up
    oooo, I Like it Keith.
    Sadly I cant take the credit.
    The idea was originally suggested by Melanie but it stuck in my mind because I have an device that uses the HPWM to generate an IR carrier which I then gate with a transistor. Too late to change my existing design but I will use the comparator to do the gating in a later revision of the board.
    Not only does it save a transistor and a couple of resistors but has a better voltage swing as well!
    Keith
    www.diyha.co.uk
    www.kat5.tv
    California
    Darn Melanie. She's just too smart for her own "Britches".
    Which is why I tend to envision her without them.
    Oh wait, I'd have done that anyways.
    At least you applied it to the right problem.
    Jul 2006
    That is a very elegant solution - just what I was looking for.
    Thanks, I will look in to this. The link to Melanie's post is very helpful. Since 0 Volts is "low voltage" it should work exactly the same - when the pulse goes low, the comparator output goes high.
    Brilliance is always in the simplicity...
    Jul 2006
    Thumbs up
    Just for the record. I followed through on this and the above idea (using the comparator) works great on a 16f877A with a 20Mhz crystal.
    I just tied the output of the HPWM pin to the Comparator input. I struggled with setting the registers properly because that part is still a bit greek to me (read - I had to experiment until I got what I wanted and then look at the data sheet to figure out WHY it did what it did.)
    The wave form is very sturdy and quite square all the way up to 15Khz. I even managed to figure out how to use one of the two ADC inputs the comparator shares on PortA.
    I'm learning. As an old dog, SLOWLY, but I'm learning....
    Thanks everyone,
    Chris Helvey
    Glad you got it working.
    Tip! - Download the English version of the Datasheet
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Darrel really! In exchange for a really big bag of negotiable money all in nicely used notes etc etc (pics, noddy currency and vapourware doesn't count), I'll send you a signed naughty photo... *smiles*
    California
    Ohhh... temptations...
    Must say you are a wizzard constructing web pages though... Harry Potter would be proud...
    As a 'big bag' full of loot, it's a bit lightweight... (new job obviously's paying well I see...) flight over to California for a trip to the cinema... ooohhh... bargain can't wait... let me rain-check that... *smiles*
    Just curiosity, are you counting the hits on the Yes and No buttons?
    California
    Awwww, Jilted again.
    Good thing I'm a nerd. I'm used to it.
    Yup, should have used $1 bills. Would've filled a good sized duffle bag.
    But you're right, the Jobs going good.
    No, not keeping track of the clicks or anything.
    After the fiasco with the Javascript LCD and Firefox. I'm trying to learn Flash to see if I can do the same kind of stuff, that'll work in any browser.
    Of course, that means you all have to put up with my silly creations along the way.
+ Reply to Thread
  1. 3 phase supply detector challenge
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 15th May 2009, 07:54
  2. VFD and HPWM
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 12th January 2009, 02:12
  3. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 15:05
  4. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 14:14
  5. 3 HPWM channels
    By docwisdom in forum mel PIC BASIC Pro
    Last Post: - 4th April 2006, 02:43
