Using CCP1 and CCP2 to measure instant fuel consumption
Results 1 to 13 of 13
    Sao Paulo - Brazil
    Default Using CCP1 and CCP2 to measure instant fuel consumption
    Hello friends,
    some time ago, I did a digital speedometer for my car using the following code to count pulses (written by Tim_B for Proton Basic)
    Define LCD_DREG PORTA
    Define LCD_DBIT 0
    Define LCD_RSREG PORTB
    Define LCD_RSBIT 4
    Define LCD_EREG PORTB
    Define LCD_EBIT 5
    REM Variables
    TMR0_POSTCOUNT1 var WORD ' POSTSCALER COUNTERS
    COUNT_RESULT var WORD ' THE RESULT OF THE COUNT
    REFRESHED var BIT ' FLAG TO SAY COUNT REFRESHED
    ON INTERRUPT GOTO PULSE_COUNT ' DEFINE WHERE TO JUMP TO ON AN INTERRUPT
    GOTO INITIALIZE ' JUMP ALL INT CODE
    '----- INTERRUPT CODE -------------------
    Disable
    PULSE_COUNT:
    TMR0 = TMR0 + 7 ' RELOAD THE TIMER
    TMR0_POSTCOUNT1 = TMR0_POSTCOUNT1 - 1
    IF TMR0_POSTCOUNT1 = 0 THEN
    TMR0_POSTCOUNT1 = 500 ' 1/4 sec (may need some adjust)
    T1CON.0 = 0 ' TURN OFF THE TMR1
    COUNT_RESULT.lowbyte = TMR1L ' GET THE COUNT
    COUNT_RESULT.Highbyte = TMR1H ' GET THE COUNT
    TMR1L = 0
    TMR1H = 0
    T1CON.0 = 1
    REFRESHED = 1 ' SET FLAG TO SAY COUNT READ
    INTCON.2 = 0 ' CLEAR INTTERUPT FLAG
    Resume
    enable ' RELOAD THE SYSTEM VARS
    '------ END OF INTERRUPTS CODE ----------
    '------ INTIALIzE ALL REGS --------------
    INITIALIZE:
    TMR0_POSTCOUNT1 = 500 ' INITIALZE THE POST SCALERS
    OPTION_REG.0 = 0 ' SET THE PRESCALER TO 1:1
    OPTION_REG.1 = 0
    OPTION_REG.2 = 0
    OPTION_REG.5 = 0 ' TMR0 CLOCK FROM MAIN OSC
    OPTION_REG.3 = 0 ' IN THIS INSTANCE PRESCALER IS ASSINED TO TMR0
    INTCON.2 = 0 ' CLEAR INTERRUPT FLAG
    T1CON = %00000110
    T1CON.0 = 1 ' TURN TIMER 1 ON
    TMR0 = 7 ' LOAD THE TIMER
    INTCON.5 = 1 ' ENABLE TMR0 INTERRUPTS
    REFRESHED = 0 ' DONT MAKE FIRST READ UNTIL MAIN INT HAS OCCURED
    INTCON.7 = 1 ' START THE WHOLE THING RUNNING
    COUNT_RESULT = 0
    lcdout $FE,1
    '------ MAIN CODE BELOW HERE -------------
    LOOP:
    IF REFRESHED = 1 THEN
    lcdout $fe,1,$fe,2, "Freq = ", dec (COUNT_RESULT * 4) ' Show results in pulses / Sec
    REFRESHED = 0 ' PREVENT A RE-READ UNTIL NEXT MAIN INTERRUPT
    GOTO LOOP
    Well, I bought a new car (used, but newer than the other one). I had do modify a lot my circuit to make it working due to the Car´s Hall sensor strange bahavior. Now, it´s fixed.
    But now, I would like to measure my instat fuel consumption, reading the Injector´s "on" time and the engine´s RPM (please, see http://www.eelkevisser.nl/fuel.htm )
    I was reading the 16F877A datasheet and I noticed that CCP1 and CCP2 uses Timer1.
    Is it possible to measure those two other parameters (engine´s RPM and Injector "on"-time) using the CCP1 and CCP2 without messing my interrupts ?
    Sorry for my bad english !
    Regards.
    Sérgio
    Capture is not reliable with Timer1 in asynchronous counter mode. You're also
    stopping & clearing Timer1 in your interrupt handler which would cause
    problems with capture.
    I would change to the 18F4431. This one has a Motion Feedback Module with
    capture that uses Timer5, measures pulse widths or frequency, and it's really
    easy to use.
    The 18F4431 has everything you need.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jun 2007
    Hi Bruce,
    I am interested to use motion feedback module on 18F4431, could you please post sample code how to read the number of rotation ?
    Johan
    Sao Paulo - Brazil
    Thanks Bruce !
    I will check here were I live, if I can buy this device.
    But, thank you for your advice !
    Do you have tips on how to use the CCP4 and/or CCP5 on this device ?
    Regards .
    Sérgio
    Here's an example of measuring a 32kHz signal on RA2 with the Motion Feedback Capture. It's pretty simple to use.
    DEFINE DEBUG_REG PORTC
    DEFINE DEBUG_BIT 6
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 0 ' 1 = inverted, 0 = true
    T1 VAR WORD
    T2 VAR WORD
    T3 VAR WORD
    Capture VAR PIR3.1
    False CON 0
    True  CON 1
    ' auto time base reset, capture on rising to falling edge
        RiseToFall CON %01000111
    ' auto time base reset, capture on falling to rising edge
        FallToRise CON %01000110
    ' auto time base reset, frequency mode, capture on every rising edge
        Frequency  CON %01000101
        ANSEL0 = 0           ' All digital
        TRISA.2 = 1          ' Cap1 input pin (Capture input)
        INTCON = 0           ' Interrupts off
        TMR5H = 0            ' Clear high byte of TMR5 counter
        TMR5L = 0            ' Clear low byte
        T5CON = %00000001    ' prescale=1:1, int clock, TMR5=on
        GOTO Main
    Trash: ' Trash 1st capture after capture mode changes
        Capture = False       ' Reset capture flag
        WHILE Capture = False ' Wait for capture
        WEND                  '
        RETURN                ' Return
        GOSUB LtoH
        GOSUB HtoL
        GOSUB Freq
        PAUSE 500
        GOTO Main
    LtoH:
        ' Capture on falling to rising edge
        CAP1CON = FallToRise
        GOSUB Trash
        WEND
        T1.HighByte = CAP1BUFH ' high byte
        T1.LowByte = CAP1BUFL  ' low byte
        DEBUG "Low PW = ",DEC T1,"uS",13,10
    HtoL:
        ' Capture on rising to falling edge
        CAP1CON = RiseToFall
        GOSUB Trash
        WEND
        T2.HighByte = CAP1BUFH
        T2.LowByte = CAP1BUFL
        DEBUG "High PW = ",DEC T2,"uS",13,10
    Freq:
        ' Frequency measurement mode, capture every rising edge
        ' to measure period
        CAP1CON = Frequency
        GOSUB Trash
        WEND
        T3.HighByte = CAP1BUFH
        T3.LowByte = CAP1BUFL
        DEBUG "Freq = 1/",DEC T3,"uS",13,10
    Returns;
    High PW = 17uS
    Low PW = 14uS
    Freq = 1/31uS
    This 18F series has a boat-load of nifty features. Check out how fast the A/D
    is. Should be a killer PIC for robotics applications.
    -Bruce
    tech at rentron.com
    Sao Paulo - Brazil
    Thank you very Much Bruce !
    regards .
    Sérgio
    Aug 2007
    Question I too am trying to use capture mode with hall sensor on cap1 2 an3
    duty var word
    ansel0=%00000000 'all digital
    'ansel1=%00000000
    trisa=%11111111 'set all port a pins to input cap1,cap2,cap3
    trisb=%00000000 'set all port b pins as output
    portb=%00000000 'set port b to all zero
    trisc = 2 ' rc1=flta input(ground pin 16 to stop) pin 16 high to run
    'capture mode
    intcon =0 'interrupts off
    tmr5h = 0 'clean high byte of tm5 counter
    tmr5l = 0 'clean low byte
    t5con = %00000001 ' prescale 1:1, int clock, tmr5 =on
    cap1con=%01000101 ' enable caputure,pulse width measurement mode,
    'every rising o falling edge
    cap2con=%01000101
    cap3con=%01000101
    where is the capture data go from here
    ' ovdcond=%00010010 'turn on / off pwm pins
    'ovdcons=%00000000
    'pcpwm init
    dtcon = %00000101 'set deadtime to -500ns
    ptcon0 =%00000000 ' 1:1 postscaale,fosc/4 1:1 prescale, free run mode
    ptperl =0
    ptperh=1
    pwmcon0= %01010000 'pwm[5:0] output enabled 0100pwm4,5 independent,
    'pwm0,1,2,3 complementary
    pwmcon1=1 'update enable,overrides sync w/time
    ptcon1=%10000000 'pwm time base is on, counts up
    fltconfig = %00000011 ' enable fault a, cycle-by-cycle mode
    duty =100 ' 50% =800
    PDC2L = duty.lowbyte 'main a fixed 50% duty cycle on pwm4,5
    PDC2H = duty.highbyte 'independent pwm outputs.
    for duty = 900 to 100 step-1 ' 10% to 90%
    PDC0L = duty.lowbyte 'register controls pwm1/0
    PDC0H = duty.highbyte
    PDC1L = duty.lowbyte 'register controls pwm3/2
    PDC1H = duty.highbyte
    PDC3L = duty.lowbyte 'register controls pwm6/7
    PDC3H = duty.highbyte
    pause 50
    next duty
    pause 500' 1/2 second delay between ramp up / down
    for duty = 100 to 900 ' 90% to 10%
    pause 5
    next duty
    skimask's Avatar
    skimask Guest
    Default Instant Fuel Consumption
    Here's how I monitor instant fuel consumption...
    Aug 2007
    Default hall senors
    trying to us motion feedback module with capture on state mode on pins 3,4,5
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by mystified View Post
    What's the question/problem?
    Aug 2007
    Default brushless motor control
    i want to set up a brushless dc motor control,I need to setup capxcon to input state change, (hall sensor as the inputs)
    rest tmr5 if a change on cap1 or cap2 or cap3, us a ic interupst and ovdcond regisiters to turn on or off pwn channels (pins)in a sequence for rotation for the motor. How do I check the flags to turn on or off the channels ?(doc an899)
    Looks great Jeremy, more on screen than my snap on scanner, what kind of display is that, a monitor? What are you measuring the fuel flow with? ( the mpg goes over 60 due to the computer shuts off the fuel completely when decellerating. Impressive work.
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by Joe S. View Post
    http://www.sparkfun.com/commerce/pro...roducts_id=569
    It's the same screen that I posted the color lcd code to here awhile back.
    Straight OBD2 data, mass air, temp, pressures, etc.etc.etc. Do enough math, mainly unit conversions and a bit of integration, and you can get almost anything you want out of OBD2...although the outputs are all 'estimated' because they're all derived from formulas with a few generic numbers (i.e. fudge factors) thrown in. But based on my driving over the past 8,000-ish miles, that 'estimation' seems to be quite accurate.
    And when the mileage goes over 60...
    The Nissan I've got ('98 200SX) isn't very aggressive at decel fuel cutoff like todays vehicles are. Based on my datalogging and calculations, if I'm doing 65mph and I let off the gas, I only get complete cutoff under certain conditions (above 2000 rpm, above 25mph, closed throttle, MAF below 500grams/sesc, MAP below 6 in/hg, calc.load.val below 10%). Other than that, I figure it goes open loop and tries to hit an A/F of about 25:1. Apparently, today's vehicles go to decel cutoff as soon as you think about slowing down (which accounts for some of todays vehicles being a just a little bit jerky at lower throttle settings in my experience).
  1. CCP1 and CCP2 to measure 2 frequencies together
    By bobonapoletano in forum mel PIC BASIC Pro
    Last Post: - 28th December 2005, 07:34
