7-segment display with P16F84
Results 1 to 17 of 17
    Jul 2007
    Default 7-segment display with P16F84
    Hi all, I am new to PIC's but have been studying electronics for 3 years and work as a technician.
    I recently came across this site http://www.melabs.com/resources/articles/ledart.htm
    with instruction on how to run 7-segment display, i have built the circuit and programmed the PIC with this code: http://www.melabs.com/resources/samp...p/7segment.pbp
    but the numbers run really fast and display 0 runs too fast to read it, I have tried adding a PAUSE 1000 under "mainloop" and just below GOSUB display but it only make the displays flash on and off
    I am trying to get them to display a number for atleast 1 second each or atleast make it so i can read digit 0
    PS I have tried contacting the site but they never got back to me.
    Thanks is advance.
    once I get this working and learn a little more I plan on adding push buttons and making it into a stopwatch or either a countdown timer.
    Raf
    Bombay, India
    i	Var	Byte
    n	Var	Byte
    Value	Var	Word
    	TRISB = $80		' Set segment pins to output
    	TRISA = $f0		' Set digit pins to output
    mainloop:
    	For Value = 0 To 9999
    		GoSub display	' Display the value
    	Next Value
    	GoTo mainloop		' Do it forever
    You need to modify this patch to something like this
    i	Var	Byte
    n	Var	Byte
    Value	Var	Word
    timedelay      var        word
    mainloop:
                    for timedelay = 0 to 2000
                    next
    	Next Value
    The value you choose for the timedelay will help you persist a value for as long as you choose.
    Jerson
    Feb 2003
    Quote Originally Posted by spitfire View Post
    Thanks is advance.
    Raf
    This is the section of code you should try to alter
    display:
    	For i = 0 To 3		' Loop through 4 digits
    		n = Value Dig i	' Get digit to display
    		GoSub display1	' Display the digit
    		Pause 1		' Leave it on 1 millisecond
    	Next i			' Do next digit
    This displays each digit for 1 millisecond. try increasing the length of the pause.
    By adding your Pause 1000 in the main loop you are adding a 1 second delay between counting. The LEDs are only lit during the display subroutine so you have 4mS of display and then a second waiting to the next 4mS.
    Try a 25mS delay (PAUSE 25) or longer to make the digits more visible but you may then notice a flicker across the digits.
    Try adding another counting loop so that you only increment the 0-9999 count once every "x" passes through the main loop.
    HTH
    Keith
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Jul 2007
    Thank alot guys, I was hardly expecting such promt replys.
    I will try your suggestions out now.
    Jul 2007
    Thumbs up
    I got it working using your method Jerson by setting "for timedelay = 0 to 100", works great.
    I was wondering if someone could recomend some books or any other good sources of information for writing code?
    Cheers,
    Raf
    Hi Spitfire,
    I have bought several books, and without this forum, I would be using them as table levelers, I do not have one I would recommend. Keep reading this forum and the PBP manual, read the archives . . every post, thats waaay better than any book I've seen. Bruce is writing one though and when it is published, I will buy one.
    JS
    Dec 2006
    Does anyone know where i can get one of those 3 digit seven segment displays that are designed to be multiplexed. aka has 12 pins instead of well loads more.
    Dec 2006
    quick one.
    in the 7 seg display program what does ~dcd mean in the line
    digits=~dcd i
    thanks
    Jul 2007
    Quote Originally Posted by hoops2006 View Post
    quick one.
    digits=~dcd i
    thanks
    ~ = NOT
    and
    DCD = it changes a bit number (0-15) into binary and set that bit to a Logic 1
    Basicly it finds out what value digits is (0 to 3, 0 being the first display on the right and so on) and converts that into binary if 0 then to 00, if 1 then to 01, if 2 - 10, if 3 - 11 and instead of applying a logic 1 like DCD is supposed to do it does the opposite because there is ~ infront of it which make it 0
    Its basicly applying a Logic 0 to pin RA0 on the PIC,completing the subroutine and then doing the same for pin RA1, RA2 and RA3. These are the pins that turn on and off each digit.
    Logic 0 normally means 0 or close to 0 Volts but in this case transisors are being used to supply the current to the display. A transistor is basicly an inverting switch so if you input logic 1 (+5V) you get 0 at the output and the opposite if you apply 0 Volts to the input.
    I got a little carried away there and have gone into more detail and answering more than you asked but it might help you understand what the code is doing a bit better. Or atleast I hope so.
    Dec 2006
    Smile
    Many thanks for your reply spitefire just what i needed. I made a boxing round timer a while back, now im trying to improve it by displaying the time on a 7 seg display. its proving to be tricker than i thought. As im still struggling to get my head round this one as im a newbie to pics your extra info helped alot.
    Jul 2007
    No worries hoops, nice project there. Have you got the hardware side finished yet?
    I'm also somewhat of a newbie to PICs but after studying discrete logic and designing a 24 hour clock with cmos 4000 series IC's (made my own 4 digit 7-segment display on veroboard using 58 blue LEDs) I now unterstand abit better.
    I'm interested to see how it turns out.
    Dec 2006
    Yes i think i have a fair idea of the hard ware. Pretty much the same set up as the link you gave on the first post. Two microswitches for round selection .With a relay chunked in for the buzzer. But my objective for now is to get minutes and seconds counting down on the display. Once i have that ill start worrying about how to select the times i want ect,
    So i have plenty to keep me going. ill keep you posted.
    Dec 2006
    Would a count down timer be as simple as:
    for sec=59 to 0
    if sec=0
    then minutes=minutes-1
    gosub display.
    the value for display would be (minutes*100)+sec eg if 3mins 59 sec value 359
    then just display the value as per the code on the link.
    Dec 2006
    Are u in the raf spitfire?
    Dec 2008
    Hi all friend
    there is someone can create this project in proteuse and poste it
    and thanks
    Dec 2008
    Hi all friend
    Dec 2006
    WADSWORTH OHIO USA
    Thumbs up 7 seg display using 16f870
    I have used this listing for over two years without any problems...
    and am happy to share it...
    ENJOY!!
    Thanks !
    SOMRU
    TWE/TFP/EE
  1. 7 Segment Displays and MAX7219
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 31st October 2010, 19:30
  2. Weird compile issue 7 segment LED display
    By George in forum mel PIC BASIC Pro
    Last Post: - 21st June 2006, 03:12
  3. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 21:25
  4. WRITE not working
    By servo260 in forum mel PIC BASIC Pro
    Last Post: - 29th December 2004, 03:02
  5. Multiplex two 7 segment display
    By Fernando Santos in forum mel PIC BASIC Pro
    Last Post: - 20th July 2003, 14:26
