Will This program work
Results 1 to 3 of 3
    Default Will This program work
    Hello.
    I am new to this as I explained in previous thread.
    i am creating a tilt sensor as a project.
    I have a board that has two accelerometers on it. The accelerometers are fed into my pic18F242 microcontroller. I want the microcontroller to spit out what the accelerometer reading is in digital format so i can read it via hyperterminal on my computer.
    If that works i will feed the accelerometer data to an RF device and do it remotely but i have to see if i get data from microcontroller first.
    Does this program look like it will work?
    DEFINE ADC_BITS 10 ' Set number of bits in result
    DEFINE ADC_CLOCK 3 ' Set clock source (3=rc)
    DEFINE ADC_SAMPLEUS 15 ' Set sampling time in uS
    tx var portB.0
    rx var portA.0
    n9600 con 16468
    adcVar VAR word[4] ' Create variable to store results
    channel var byte
    byteVar var byte[4]
    inByte var byte
    ' set Sleep pin high:
    ''HIGH PORTD.0
    ' Set PORTA to all input
    TRISA = %11111111
    ' Set up ADCON1:
    ' All are analog inputs
    ADCON1 = %10000000
    ' read all channels of the accelerometer:
    for channel = 0 to 3 ' read the two accelerometers from pin 0 - 3
    ADCIN channel, adcVar[channel]
    ' convert to a byte:
    byteVar[channel] = adcVar[channel] /4
    pause 1
    next
    ' send results out the serial port:
    serout2 tx, n9600, [byteVar[0],byteVar[1],byteVar[2], byteVar[3]]
    GoTo main
    It looks OK to me (except the Next which is orphan! Needs the variable to increase), but sure only testing will prove this.
    A couple of improovments:
    Since the chip you intent to use has UART why not use the HSEROUT command instead SEROUT2?
    Like this
    HSEROUT [bytevar str\4]
    Also I don't quite understand why do you use the
    If you want to convert the 10-bit ADC result just type this:
    byteVar[channel] = adcVar[channel] >>2
    and the 10-bit result will be converted to 8-bit.
    Even better use the DEFINE to set ADC to 8 bits.
    So it might be like that:
    ADCIN channel, bytevar[channel]
    pause 1
    next channel
    Hserout [byteVar str\4]
    GoTo main
    Red face
    How did i ever live my life before the days of the internet. Thanks a lot for your advice I will modify my program and test it out. Any other advice someone has?
  1. Help with DS18B20 program
    By presario1425 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2012, 00:50
  2. My PIC program won't work! Plz Help?!
    By beckyzammi in forum mel PIC BASIC
    Last Post: - 4th March 2010, 18:26
  3. Making Program Code Space your playground...
    Last Post: - 19th July 2008, 08:26
  4. Replies: 5
    Last Post: - 5th February 2006, 16:51
  5. Simple Interrupt Program
    By eoasap in forum General
    Last Post: - 28th October 2005, 16:22
