PIC driving Adjustable Voltage Regulator
Results 1 to 7 of 7
    SWITZERLAND (french speaking)
    Default PIC driving Adjustable Voltage Regulator
    Hello,
    I'm building a(nother) lead battery charger.
    Just to make sure I'm not missing something important, I would like somebody, who made this before, to tell me if my principle is correct.
    The PIC will read the Vout via ADC (GP1) and set the PWM (GP5) to adjust voltage.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1715&stc=1&d=118112643 8">
    Is there a better way to control a voltage regulator?
    Roger
    Sep 2005
    Campbell, CA
    Your circuit will allow you to vary the output voltage, but only over a narrow range. I see that your input voltage is 24 - which implies to me that you need an output voltage that is probably above 10V.
    The LM317 series of regulators is designed such that the output voltage on pin 2 is 1.2V greater than the voltage at the "adj" pin 1. For that reason, your circuit will have a voltage output of a little over 1.2V (at "0" PWM) or to a maximum of 6.2V at PWM = 255.
    If you want full-range, you should add an op-amp with a gain of about 5 at the R-C junction, and the output of that op-amp would go to the LM317 adjust pin. I would also pull up the PIC output pin to Vcc through a 1K (or so) resistor to help insure that the pin swings close to 5V when it is HIGH.
    Adding an op-amp to the circuit would also let your raise the impedance of the R1/R2 circuit. That would allow for a smaller capacitor and lower your PIC loading.
    Charles Linquist
    skimask's Avatar
    skimask Guest
    Or maybe use one of those digital potentiometers, like the Xicor series types, for your voltage divider...
    Feb 2005
    Kolkata-India
    Default You are loosing the LM317 voltage regulation
    Look at this article here http://www.elecdesign.com/Articles/I...rticleID=13077 . I hope no explanations are necessary.
    Sougata
    Talking
    Hi Flotul
    I already saw a '317 as a couple of KHz PWM amplifier ( yes ON/OFF !!! ) ... OK ... precisely ON/1.25v ...
    Seems it's also already used in classA amplifiers !!! ( see National Datasheet )
    Just have a nice filtering for the PWM out of the Pic and it will work just as you want !!!
    Default ?
    Alain,
    I downloaded the datasheet and quickly read it.
    Could you give me a little more info about what you mean by "a couple of kHz amplifier"?
    Sougata,
    Your link just gives everything I need . I thought I could make something with less components; I'm very short in space.
    Roger
    Talking
    Hi, flotul
    I just mean the ref pin is driven by a 1kHz 12v p.p. square wave !!!
    The use is a variable switching supply for model Trains ...
  1. PWM and adjustable voltage regulator
    By bogdan in forum Schematics
    Last Post: - 11th September 2009, 13:26
  2. 3V Voltage Regulator with Shutdown Feature
    By rsocor01 in forum General
    Last Post: - 30th August 2009, 06:34
  3. voltage regulator or resistor for a pic?
    Last Post: - 19th August 2008, 15:15
  4. make a low voltage output from a PIC pin
    By emptyset in forum General
    Last Post: - 8th February 2008, 19:20
  5. Driving a Voltage Regulator with PWM
    Last Post: - 27th June 2007, 13:14
