Why is He using TMR0 in this code?
'* Name : LedSensor.BAS *
'* Author : Kifo *
'* Notice : Copyright (c) 2004 kifo *
'* : All Rights Reserved *
'* Date : 15.01.2004 *
'* Version : 1.0 *
'* Notes : *
LedAnoda VAR GPIO.0
LedKatoda VAR GPIO.1
GPIO = 0
cmcon = 7 ' comparator (off , set as digital IO )
TRISIO = %00000000 ' set GP 1,2,3,4,5 as outputs
'WPU = %00110000 'pin gp3, gp4 - pull up enabled
'option_reg.7 = 0 'global GPPU bit - za pull up enabled = 0
'ANSEL = %00010001 'GP0 analog input , Fosc/8 ( A/D konverzija )
'ADCON0 = %10000001 'chanel 0, stop AD, A/D On, Vdd = ref
'ANSEL=0 'digital IO " samo za 12F675 "
INTCON = %00000000 ' Onemoguci prekide
INTCON.2 = 0 ' brisanje flega prekoracenja Tmr0
option_reg = %10000111 ' timer 0 prescaler rate 1:256
Low LedAnoda ' inverzni napon na led
High LedKatoda ' led ne svijetli
Input LedKatoda ' high Z na katodi led diode
tmr0 = 0 ' reset timer 0
WaitLow: IF TMR0 > 50 Then GoTo ukljuci ' tu određujemo razinu osvjetljenosti
IF LedKatoda = 1 Then GoTo WaitLow ' čekamo kad padne nivo na nulu
GoTo main ' ako ima dosta svjetla vraćamo se na main
ukljuci: High LedAnoda ' ako nema dosta svjetla upalimo led diodu
Low LedKatoda '
Pause 400 ' led svjetli 400ms
GoTo main
