Big big big memory or tiny SDs!
Results 1 to 10 of 10
    Sep 2003
    Vermont
    Default Big big big memory or tiny SDs!
    Okay, here's a good one. I need to store some .bmp files for retreival and display on an OLED display. Each file is 48KB, can't be compressed, and I will need at least 25 of them. The largest serial flash memory seems to be around 2 Meg. I'd like at least 8 Meg but I don't want it removable. Any ideas, or will I have to go SD?
    And... On that note, has anyone got a line on micro SD card sockets?
    Ron
    No need for flash card, M25P16 will be more than enough. 16Mb and SPI. No need for extra annoying socket. small, cheap and reliable.
    http://www.st.com/stonline/books/pdf/docs/10027.pdf
    also W25P16VSFIG.
    http://www.winbond-usa.com/products/...P80-16-32j.pdf
    Both above are supported in my BKPrecision 844A.
    Never used them so far.
    Sep 2003
    Vermont
    Thanks Steve,
    I have a 1 MByte chip from ST, but I would really like some acreage! How about the memory inside the thumb drives?
    Thumb drive? USB ones? If so you should have a look to MAX3421E, this should do the trick. Nice reference http://www.ghielectronics.com/details.php?id=13
    Those are in stock here... never had any time to play with...
    SD card pinout
    http://pinouts.ru/Memory/sdcard_pinout.shtml
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by Ron Marcus View Post
    Thanks Steve,
    How about the Atmel DataFlash chips? They're gettin' big these days (big as in good capacity)
    I played with this awhile back, converted it to PBP (which was a piece of cake). A bit on the slow side, could've had faster transfers had I used the SPI module on the PIC itself.
    http://www.emesystems.com/BS2flash.htm
    http://www.digikey.com/scripts/DkSea...463292&Site=US
    $2.37USD each at Digikey.
    May 2006
    Del Rio, TX, USA
    I've also used the Atmel Dataflash (AT45DB321C (32MB)). Worked well with Shiftin/Shiftout. Also worked with the Hardware SPI, just a little harder to setup.
    The hardest part is finding a supplier with some in stock. I think I got some obsolete SOIC parts from Arrow, but it's been a while. Digi-key lists all of there compenents as Non-Stock, but you might give them a call.
    SteveB
    Sep 2003
    Vermont
    I found a supplier for the micro SD sockets. I was thinking of breaking out the old "FAT" code and installing it permanently on the board. For my proto, I will more than likely use the ST part. The down side to the SD card is the power consumption...but you can't beat the $15.- price!
    Thanks for the leads,
    Ron
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by SteveB View Post
    SteveB
    I just checked Digikey. Searched for 'Atmel Dataflash' and clicked 'Items in Stock'. I get 42 results for parts in stock, ranging from 1Mbit up to 64Mbit parts.
    May 2006
    Del Rio, TX, USA
    Yep. I must have narrowed my previous search too much. 16Mb SOIC for $2.37.
    SteveB
  1. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  2. Replies: 4
    Last Post: - 2nd March 2007, 07:12
  3. Which pic has a big flash program memory?
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 1st November 2006, 20:35
