Updating HPWM frequently, safe?
Page 1 of 2 12 LastLast
Results 1 to 40 of 79
    Feb 2005
    Default Updating HPWM frequently, safe?
    How often is safe to update the HPWM duty cycle when running a 12f683 at 4mhz?
    I see that doing it constantly confuses the uC, so whats the safe "wait period" ?
    Thanks!
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by peu View Post
    Thanks!
    What do you mean by 'safe' and 'confuses the uC'?
    Feb 2005
    Hi Skimask,
    I mean if I update the HPWM inside the main loop of a program, is it safe to update it every time the loop loops?
    From my experimentation (Im controlling LED brightness using this hpwm) if I do this the LED flickers.
    On the contrary, if I create a 3 lines new program with just one HPWM line and a loop:gotoloop, the LED does not flicker at all, its stable as it should be.
    thanks
    skimask's Avatar
    skimask Guest
    Hi Skimask,
    thanks
    PIC12F683 datasheet, Section 11.3.3
    Feb 2005
    here is the gist of the code im running:
    @ device pic12f683,INTRC_OSC_NOCLKOUT , wdt_on, mclr_off, protect_off
    DEFINE ADC_BITS 10
    DEFINE ADC_SAMPLEUS 50
    ANSEL = %00000010 ' GPIO.1 A/D in, rest digital
    TRISIO = %00010010 ' GPIO.1 lectura AD,
    cmcon0 = %00000100 ' AD via gpio1 and internal reference
    vrcon = %10001010 ' set vref=2.25v
    loop:
    oldpote=pote
    ADCIN 1, pote ' (0-65535)
    if oldpote <> pote then
    hpwm 1,inverduty,frecu 'these values are calculated in other section
    goto loop
    maybe the problem is that im using ADC and HPWM simultaneously?
    I don't undertand what you implied by reading that section of the DS.
    Thanks!
    .... I don't undertand what you implied by reading that section of the DS. ...
    That's just his little way of saying "I don't Know, go read the datasheet or something."<hr>
    When an HPWM command executes, it treats it like it's the First time, and sets up every register needed to run PWM with the CCP module.
    Changing CCP and TMR2 registers while the CCP is running PWM will cause "false pulses", Cycle Resets or elongation.
    It would be nice if there was an HPWM_UPDATE command that only changed the dutycycle, without messing with the other registers. But there isn't.
    If you need a totally "Glitch Free" PWM signal, then you'll have to modify the dutycycle manually. You can still use HPWM to set everything up. And then just modify the dutycycle later, after the PWM is running.
    If you haven't already, you should get a copy of mister_e's PicMultiCalc.exe
    It'll help figure out what values to use for the dutycycles.
    http://www.mister-e.org/pages/utilitiespag.html
    HTH,
    Feb 2005
    Thanks for the reply Darrel, now that explains many things
    After many tries I managed to make the mister-e app work, it gave me an unregistered class error, but after a little googling I solved, it.
    baaaack to the protoboard!
    Feb 2005
    well, now I have a new difficulty, trying to understand the calculator
    Running OSC at 4mhz and PWM at 1khz I get:
    And I found a post where Mister_e explains how to use it:
            '       38KHz PWM @ 4MHZ using a PIC16F877
            @  __CONFIG _XT_OSC & _LVP_OFF
            TRISC = 0
            Duty        var byte
            '       PWM SETUP
                    ' PicMultiCalc says..
                    '   Duty value for 50%=52
                    '   PR2 = 25
                    '   PRESCALLER 1:1
            duty = 52                           ' duty value for 50% duty cycle
            PR2 = 25                            '
            T2CON = %00000100                   ' timer2 on, prescale 1:1
            CCPR1L = duty>>2                    ' MSB of duty cycle value
            CCP1CON=%00001100 | (dUTY<<5)       ' set PWM mode and store the
                                                '   2 LSB of duty
    SpinInRound:
            goto spininround
    If I understand correctly what you posted, I can start the HPWM before the main loop by using for example: HPMW 0,0,1000 and then within the loop adjust just the dutycycle.
    Now what I dont understand is how I change the duty cycle, by using the calc I get 1000 values, but the duty variable is defined as BYTE
    I could use some help/hint
    Thanks!
    Feb 2005
    well it seems Im having a conversation with myself, instead of busting the few neurones I have left, I used the second option (prescaler 1:16) and I made it work, but the glitches are still there.
    I initialized the PMW before the main loop using: HPWM 0,0,1000
    and the registers as:
    T2CON = %00000110 ' timer2 on, prescale 1:16
    PR2 = 62 'per pic calculator
    and every time I wanted to adjust the duty cycle I entered the value in the duty variable and called this subroutine:
    CCPR1L = duty>>2
    CCP1CON=%00001100 | (duty<<5)
    As I said...the glitches remain... if I stop reading the ADC they dissapear and the PWM is steady
    HELP !
    first you'll have to match the calc values to suit your need. With your current code example (which seems to be one of mine, the calc will give you...
    <IMG SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1593&stc=1&d=117840872 7">
    look at this section of the code
            PR2 = 25                            '
                                                '   2 LSB of duty
    52 is showned in the result section and it's to set the duty cycle to 50% as selected in the duty cyle section.
    Now if you want to update the duty cycle, you could use this section
                                                '   2 LSB of duty
    in your code you just need to change the value of Duty variable.
    The example was for a 16F877, you should have a look at the 12F683 to see if they work the same way.
    post your whole code, maybe some register need to be set in a different way. I'll put some effort and open my datasheet as well
    Feb 2005
    it seems we posted at the same time, yes the post I used is from an old post of yours I used for reference. Please read my last post and tell if if you have an idea that may help me. Thanks!
    mm, you didn't disable the analog comparator.. maybe it worth to do it first?
    i'm about to do something here to see what's happen.
    try this
    <font color="#000000">        <font color="#008000">'
            '       Pic Configuration
            </font>@ __CONFIG _INTRC_OSC_NOCLKOUT &amp; _WDT_ON &amp; _PWRTE_ON &amp; _MCLRE_OFF &amp; _BOD_ON
            '       Hardware configuration
                    '       I/Os
            </font>TRISIO = %00010010
                    '       ADC's
            </font>ANSEL = %00000010
            <font color="#000080">DEFINE </font>ADC_BITS 10     <font color="#008000">' ADCIN resolution  (Bits)
            </font><font color="#000080">DEFINE </font>ADC_CLOCK 1     <font color="#008000">' ADC clock source  (Fosc/8)
            </font><font color="#000080">DEFINE </font>ADC_SAMPLEUS 11 <font color="#008000">' ADC sampling time (uSec)
            </font>ADCON0.7 = 1           <font color="#008000">' Right justified results
                    '       Comparator
            </font>CMCON0 = 7             <font color="#008000">' Disable comparator
            </font>VRCON = 0              <font color="#008000">' CVreff = OFF
                    '       CCP
                            '   PWM Freq=4KHz
                            '   Initial duty cycle set to 50%
                            '   PICMultiCalc says
                            '   10 Bit resolution when prescaler = 1:1
                            '   MAX duty value 1000
                            '   PR2 = 249
            </font>CCP1CON = %00001100     <font color="#008000">' PWM mode
            </font>PR2 = 249               <font color="#008000">'
            </font>T2CON = %00000100       <font color="#008000">' Start Timer2, Prescaller 1:1
            '       Software variables
            </font>Duty    <font color="#000080">VAR WORD
            </font><font color="#008000">'
            '       Software constants
            </font>PWM_ON  <font color="#000080">CON </font>%00001100
            PWM_OFF <font color="#000080">CON </font>0
            '       Software/Hardware initialisation
            </font>GPIO = 0
            <font color="#000080">PAUSE </font>50    <font color="#008000">' OSC settle delay
            </font>Duty = 0
            <font color="#000080">GOSUB </font>SetPWMDuty
            <font color="#008000">'------------------------------&lt; Main program &gt;-----------------------------------
    </font>Start:
            <font color="#000080">ADCIN </font>1,Duty                    <font color="#008000">' read pot
            </font><font color="#000080">IF </font>Duty&gt;1000 <font color="#000080">THEN </font>Duty =1000    <font color="#008000">' avoid results &gt;1000
            </font><font color="#000080">GOSUB </font>SetPWMDuty                <font color="#008000">' Set PWM duty cycles
            </font><font color="#000080">PAUSE </font>1                         <font color="#008000">' allow few PWM cycles
            </font><font color="#000080">GOTO </font>Start
            '-------------------------------&lt; Subroutines &gt;-----------------------------------
    </font>SetPWMDuty:
            <font color="#008000">'       Datasheet recommend to stop PWM, load duty cycles vale
            '       to avoid possible glitches.
                    '       stop PWM
            </font>CCP1CON = PWM_OFF
                    '       load Duty values
            </font>CCPR1L = Duty &gt;&gt;2
            CCP1CON.5 = Duty.1
            CCP1CON.4 = Duty.0
                    '       Start PWM
            </font>CCP1CON = CCP1CON | PWM_ON
            <font color="#000080">RETURN
    </font>
    things to remember, disable the PWM mode, update the duty cycle, start PWM mode and allow few PWM freq cycle.. unless results could be weird.
    skimask's Avatar
    skimask Guest
    True, but the point was exactly as you posted, about the glitches and false pulses, etc. But you spelled it out, so now there's no need to read the datasheet.
    Wink ??? some explanations welcome ...
    HTH,
    Hi, Darrel ,
    I do not know if you're right here ...
    The fact is I used HPWM without pain for years ... but NOT aboard any '683
    and it REALLY seems there's a HARDWARE ( say CCP functionning ) issue.
    The µChip section Skimask pointed at shows " PMW module *might* be disabled before changing the dutycycle ". I read some Other Pics Datasheets and this GREY section didn't appear elsewhere ...
    IF I'm right, this "funny feature" happens whatever you use, assembler or Basic (!) ... The way HPWM command works doesn't matter here !!!
    So, a ( Which other Basic do you think to ??? .... mmmmmh ? ) HPWM_UPDATE command wouldn't solve the question !!!
    µChip clearly says : Changing the dutycycle while PWM running (and only dutycycle is enough ) will produce unwanted effects ...
    The only way I see to keep ( is it really necessary ??? Good Q.) a "neat" PWM output would be to switch between HPWM, to the last produced fixed freq. and duty, soft PWM ... while disabling CCP, changing Dutycycle and re-enabling the CCP.
    Quite a funny little sub to write, no ???
    Back to our Friend Skimask ... I really do not know ... if he really doesn't know the "what is wrong".
    I'm Ok ... this is not giving the solution, nor ... BUT ... His first answer could have been " Won't work with the '683 ( FINAL POINT )"
    Would be kind to leave guns, knives, scissors and umbrellas out before entering the saloon ... just a thought.
    Here is a snippet of code from a motor speed controller for a small electric cart. The HPWM command is constantly repeated and has never caused any problems. In fact, in the beginning, I took the value of the speedpot once and just let the motor run and it caused problems. Intermittently the motor would "jump" into full speed. In spite of double regulation and a lot of filtering, motor noise sometimes caused the HPWM to go OUTPUT HIGH. I know it was motor noise because it never happened when controlling a 12V lamp.
    ON:
    ADCIN 2, SPEEDPOT 'READ VALUE OF SPEED CONTROL POT
    IF SPEEDPOT > 150 Then LET SPEEDPOT = 150 'LIMIT SPEED OF MOTOR
    IF LEFTRAMP < SPEEDPOT Then LET LEFTRAMP = LEFTRAMP + 1 'INCREASE SPEED SLOWLY
    IF LEFTRAMP > SPEEDPOT Then LET LEFTRAMP = LEFTRAMP - 1 'DECREASE SPEED SLOWLY
    Pause 1 'CONTROLS RATE OF SPEED INCREASE/DECREASE
    HPwm 1,LEFTRAMP,10000 'OUTPUTS THE DUTYCYCLE CONTROLLED BY SPEEDPOT
    IF PORTB.5 = 1 Then ON 'SWITCH PUSHED KEEP MOTOR RUNNING
    GOTO START 'STOP EVERYTHING
    Feb 2005
    The circuit Im using controls the feedback node of a switcher which its used to drive a power LED, any small glitch in the duty cycle is "visible" in the light output.
    What puzzles me is the minute I stop using the ADCIN command, all the problems dissapear:
    if calibrapin=0 then
    ADCIN 1, pote
    if I put this calibrapin to 1 the output is steady. When it was bedtime yesterday (yes I keep thinking about problems in bed ), I tought: why not use software PWM, that may solve this issue. Well seeing it was suggested here too, makes me want to try it and I will
    Regarding the DS section 11.3.3: "The PWM module may generate a premature pulse when changing the duty cycle."
    Its the MAY word that puzzles me, I would expect more certainty here.
    I still need to test Mister E suggestion, and speaking of it:
    In fact Im using the internal comparator, thats why I didnt disable it, if you check my 1st code post you will see:
    I need to put this value there so I can get more samples from my limited range sensor.
    Also I tough it may be simply a reading problem, but this wasnt the case, I filled the available eeprom space with the read values and they were steady.
    THANKS for the help guys! Back to the protoboard!
    Pablo
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Quote Originally Posted by peterdeco1 View Post
    ON:
    That's called "Closed Loop Control"
    Feb 2005
    mmm I oversought this statement, THANKS!, I will tidy it up a little, Im kinda messy compared to your code postings
    skimask's Avatar
    skimask Guest
    And I just downloaded the latest/greatest 12F683 datasheet and it DOESN'T have that statement in there. What's up with that?
    Couldn't you update the duty cycle right after T2 has overflowed? As long as the duty cycle wasn't too low or too high, wouldn't this almost eliminate all false glitches?
    I got a good handle on "what's wrong" 'cause I ran into the same problem with my multi-channel software PWM program I wrote to run a bunch of lights awhile back. And my fix for the problem was to only update the PWM duty cycle for each channel in between cycles, so basically, I ended up with PWM that couldn't do 100% duty cycle, but only about 0%-95% duty cycle. The extra 5% at the top end was used to update the software registers.
    Wink
    Hi, Skimask
    Q1) Here is an excerpt ( joined ) ... Peu found it also ... If not in the latest datasheets, might we think the new devices have been modified ???
    Q2) I must experiment ... T2 overflow is to try ... Honestly, I would use a SMD 16F628,648,88 or ??, instead, if size is a really a problem ( LOL !!! )
    R3) It's the most logical solution ...
    Feb 2005
    Hi, Skimask
    Its indeed modified...!! I just redownloaded the datasheet and the PWM section is more complete now.
    check both versions here: http://peu.net/temp/pic12f683_OLD_vs_NEW.zip
    Well, in my case I have very low space, all my pcb is a 18mm diameter board...
    Here is my code, I tidied / commented it so its more readable: http://peu.net/temp/pwm-adc
    Thanks!
    And, You're all correct!
    Well, except for that part about me being wrong
    After my last post, I started working on an example for Pablo. It's kind of grown along the way, and is now a candidate for replacement of the HPWM command. IMHO
    It pretty much encompasses everything you guys talked about while I was doing it. Plus maybe a bit more.
    It's an Include file that gives 1 new command...
    @  HPWM10  1, _DutyCycle, _Frequency
    It works the same way as the PBP HPWM command, except that it uses 10-bit resolution, works with all CCP modules CCP1-CCP5, And is "Glitch-Free" when changing Frequency or DutyCycle.
    Well, at least that's what it's supposed to do. Seems to work pretty good here, but I've only had a day to play with it.
    It uses about 250 more words than HPWM, so I don't know how good it will be for a 12F683. But it definately will fit, if the rest of the program isn't too big.
    If anyone has any problems, I'd appreciate a "Heads Up".
    http://www.pbpgroup.com/files/HPWM10.zip
    <br>
    Feb 2005
    OMG
    Im "digesting" the code, just tried it and it compiles to 409words, compact enough for a 12f683
    Thanks!!!
    Quote Originally Posted by Darrel Taylor
    One day to do all that? Wow, some 'over a month TicTacToe brain challenged programmer' will be impressed
    Feb 2005
    I just tested it using this code:
    '       Pic Configuration
    '       I/Os
    TRISIO = %00010010      ' pin1 is ADC , pin4 is the calibration button
    '       ADC's
    ANSEL = %00000010
    DEFINE ADC_BITS 10      ' ADCIN resolution  (Bits)
    DEFINE ADC_CLOCK 1      ' ADC clock source  (Fosc/8)
    DEFINE ADC_SAMPLEUS 11  ' ADC sampling time (uSec)
    ADCON0.7 = 1            ' Right justified results
    '       Comparator
    'CMCON0 = %00000111     ' Disable comparator
    'VRCON  = %00000000     ' disable
    cmcon0 = %00001110      ' Multiplexed Input with Internal Reference CIS=1
    vrcon  = %10001010      ' set vref=2.25v (from 4v input)
    include "HPWM10.pbp"
    ' definitions
    pote 		var word
    Frequency   var word  ' edited after original post per Darrel suggestion
    calibraled  var gpio.5
    gpio=0
    frequency=1000
    pause 50    ' coffee break
    for pote=1 to 1023
    @ HPWM10  1, _pote, _Frequency
    pause 10
    'gosub flashled
    next pote
    flashled:
    high calibraled     ' I use this to visually count each loop step
    pause 50
    low calibraled      ' by using it I saw that my switcher starts to
    pause 50            ' work at hpwm=4, less than that is too low
    high calibraled
    pause 50
    low calibraled
    pause 50
    high calibraled
    pause 50
    low calibraled
    pause 700
    Comments:
    I used the flashing led routine to know when my switcher started to work, it started at hpwm=4 which is great, the power led is very dim at this value.
    then I removed the flashing routine and something was too fast, because my switcher was off. So I added a little pause in there and it was solved, tried 1, 5 and settled in 10ms where it started to work again.
    This is great!, now I will test it with adcin
    pablo
    Both DutyCycle and Frquency MUST be WORD variables.
    I put it in the comments, but I should have mentioned it in the post too.
    That... Frequency con 1000 will cause problems.
    <br>
    Feb 2005
    I just finished testing it with this code:
    '       Pic Configuration
    '       I/Os
    '       ADC's
    ANSEL = %00000010
    '       Comparator
    'cmcon0 = %00001110      ' Multiplexed Input with Internal Reference CIS=1
    'vrcon  = %10001010      ' set vref=2.25v (from 4v input)
    ' definitions
    pote 		var word
    Frequency   var word
    calibrapin  var gpio.4
    gpio=0
    frequency=1000
    loop:
        adcin 1, pote
        if pote>1000 then pote=1000
    pause 10
    goto loop
    The output is not steady when I use ADCIN, if I enable the calibrapin then it goes to steady mode.
    To generate the adcin values I used a 10k pot instead of the sensor Im using for simplicity sakes.
    Am I doing something wrong?
    Thanks!
    Pablo
    Can't tell ya! But as far i remind, the datasheet suggest a maximum impedance of 2.xxx Kohm.
    I tested my code on a EASYPIC 4 board with 10K trim pot... seems to work.
    Post your schematic but make sure your PSU is well filtered and is strong enough for your need first.
    Weird, weird, weird.
    Oh Great!
    Thanks for trying it Steve.
    It helps to know not all is lost.
    I think I've got a 683 around here somewhere.
    Maybe there's something I missed for the little guys.
    <br>
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Yes, Mister_e, very impressive indeed.
    Feb 2005
    Im using this schematic:
    Im using a recently charged Li-Ion (3.635v measured under load using a good multimeter) all is mounted in a protoboard
    Using my last posted code the LED flickers, if I press the button it goes steady
    Thanks!
    mmm, yeah it works.. but a scope attach to show few glitches... mine too.
    Deeper analysis show that flicker go away if i don't turn off the PWM off before updating the duty cycle. So maybe i have those latest silicon version.. and why the datasheet no longer suggest to turn off the PWM module...
    aarrrggghh
    Feb 2005
    let me join your ARGHHH...
    Thanks Steve, at least now I know Im not alone here
    I ordered some 12f683 samples not so long ago, if they changed something I guess I could test it with a rather new IC. But they are at my office, will check tomorrow if time allows.
    Thanks for the continued help guys!
    Pablo
    in my code just remove the following line
    CCP1CON = PWM_OFF
    and also that one
    In darrel's include, comment out line 160
    MOVE?CB  0, CCP1CON
    At least, it work here.. thanks to my scope
    Now the history don't tell if this will work with ALL PIC #, and with ALL silicone release. Time will tell.
    T.Jackson's Avatar
    T.Jackson Guest
    Smile
    You are a genius Mister_e. Wish I was as smart.
    Don't give up, maybe one day you'll be. Then i could hire you
    Feb 2005
    I removed that line from Darrel code and its clearly more stable now, but it still flickers at the lower range of the pot... very strange...
    I just modified the code I posted to write to eeprom the lowest pot setting where its stable, the read value was from $007B to $007C but I recorded a couple of $007F and $0068 after 125 readings/writes, my guess for these oscillations was someting in the write cycle because after I stopped reading the led went to steady again, I wish I had a scope...
    modified code:
    if calibrapin=1 then
    if conta < 250 then
     write conta, pote.byte1
     write conta+1, pote.byte0
     conta=conta+2
    Pablo
    Strange indeed.
    Well, I've made the changes Steve found and posted it at the same link.
    I won't get my scope back till wednesday. (should have waited)
    But I'll sure have a good look at it then.
    <br>
    mmm, could be a noisy pot as well... using your code and on many low-value ADC.. they are all stable.. no noise, no frlicker.
    what happen if you stick a 0.1 uF in parallel with your POT wiper?
    Any 0.1uF + 10uF capacitor close to your PIC?
  1. need help on hpwm
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 28th August 2007, 15:49
  2. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 15:05
  3. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 14:14
  4. HPWM and A to D interaction question 18F252
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 10th May 2006, 03:50
  5. 3 HPWM channels
    By docwisdom in forum mel PIC BASIC Pro
    Last Post: - 4th April 2006, 02:43
