Problem with enumeration and EasyHID
Results 1 to 23 of 23
    Apr 2007
    Default Problem with enumeration and EasyHID
    Hi, I'm using a pic18f2550 with picbasic pro and easyhid.
    I get the files generated from easyhid to compile correctly. The problem is that when I plug in the usb cable, the computer never enumerates the pic, no new hardware found box on windows.
    I connected the pins correctly, i think, just as the schematic suggests on the easyhid website. I'm just trying to code something where it will send the a/d values from an RA pin to the pc.
    Any suggestions or tips?
    Thanks in advance
    skimask's Avatar
    skimask Guest
    Cool
    Quote Originally Posted by jizyjuice View Post
    Thanks in advance
    Those that read this are supposed to help you figure out your code problems because we can all guess exactly how you have written your code. Am I correct in this assumption?
    Post some code!!!
    Apr 2007
    Heres the code that Easy HID created. I set up an led to see where the code stops at. It seems to stop after
    USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, . I guess this is because I dont have any code right now to send data, but I was more concerned with the pc recognizing the pic.
    If usbinit is called, doesnt the pc enumerate the usb device? It never shows that a hid device is connected. Is there something I am missing to get the pc to recognize this device?!
    DEFINE OSC 48
    DEFINE LOADER_USED 1
    USBBufferSizeMax con 8 ' maximum buffer size
    USBBufferSizeTX con 8 ' input
    USBBufferSizeRX con 8 ' output
    ' the USB buffer...
    USBBuffer Var Byte[USBBufferSizeMax]
    USBBufferCount Var Byte
    ' * main program loop - remember, you must keep the USB *
    ' * connection alive with a call to USBService every couple *
    ' * of milliseconds or so... *
    usbinit ' initialise USB...
    ProgramStart:
    gosub DoUSBOut
    goto ProgramStart
    ' * wait for USB interface to attach *
    DoUSBOut:
    USBBufferCount = USBBufferSizeTX ' TX buffer size
    USBService ' keep connection alive
    USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data
    That's not the "Whole" code that easyHID created.
    You've deleted some things that are very important.
    If you just want to see it enumerate, change the main loop to this...
    ProgramStart:
    goto ProgramStart
    But that will neither send or receive any data.
    This also assumes you've setup your Configs properly.
    Apr 2007
    Oh, I took out the code for receiving data from the pc to the pic. I just want to communicate to the pc side.
    All the configs are what easyhid has set up. I will try just polling serviceusb and see if that can get the pic to enumerate. Thanks
    What Darrel talked about was the PIC configuration Fuses... which EasyHID don't create for you.
    http://www.picbasic.co.uk/forum/showthread.php?t=5418
    Apr 2007
    I still cant get the pic to enumerate.
    Here is my code for the fuses:
    LIST
    LIST p = 18F2550, r = dec, w = -311, w = -230, f = inhx32
    INCLUDE "C:\PBasPro Projects\AirDrum\PICBasicPRO\P18F2550.INC" ; MPASM Header
    __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    __CONFIG _CONFIG1H, _FOSC_XTPLL_XT_1H & _IESO_OFF_1H
    __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOR_OFF_2L & _BORV_2_2L & _VREGEN_OFF_2L
    __CONFIG _CONFIG2H, _WDT_OFF_2H
    __CONFIG _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_OFF_3H
    __CONFIG _CONFIG4L, _STVREN_OFF_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    NOLIST
    Here is the main code again:
    DEFINE OSC 48
    ' the USB buffer...
    i var byte
    ProgramStart:
    'gosub DoUSBIn
    'gosub DoUSBOut
    High PORTB.0
    for i = 1 to 10
    Pause 2
    USBservice
    next i
    LOW PORTB.0
    for i = 1 to 10
    Pause 2
    USBservice
    next i
    goto ProgramStart
    ' * receive data from the USB bus *
    DoUSBIn:
    USBBufferCount = USBBufferSizeRX ' RX buffer size
    USBIn 1, USBBuffer, USBBufferCount, DoUSBIn ' read data, if available
    DoUSBOut:
    The LED lights up correctly, but the pic still does not enumerate even with calling the USBSERVICE. I have 0.5microF on VSUB, 20 MHZ crystal with 33 pF connected to it. D+, D- set up correctly. Bus powered.
    I have no idea what the problem is!
    For a 20mhz crystal, second config line should be
    __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H & _IESO_OFF_1H
    Apr 2007
    I changed the config for 20 Mhz clock, but still no enumeration. I uploaded my project files in the following zip. Can someone please let me know if they can get this to enumerate on their bread board? Thanks
    It would have been much easier to start with mister_e's example ....
    Apparently, you have an 18F2550.INC file in your project folder where you are changing the configs.
    PBP won't use that file. It uses the one in the PBP folder.
    But you should really put the configs in your program, and comment out the configs in the 18F2550.inc file in the PBP folder.
    Use these ...
        asm
        __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
        __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L  & _BORV_2_2L  & _VREGEN_ON_2L
        __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
        __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L  & _XINST_OFF_4L & _DEBUG_OFF_4L
        endasm
    Then remove the pauses in your loops, USBSERVICE must be called every ~1ms or less. (when enumerating)
    After making those changes, I was able to get your program to enumerate on an 18F4550. Don't have a 2550.
    Apr 2007
    Well I changed the config files and took out the pause in the code. Still no enumeration. Could this be a hardware problem?
    I attached everything the same way as the 4550 pictured by easyhid, but just adapted to the 2550.
    There's always a chance for a hardware problem. But that's a liitle hard to troubleshoot on this end.
    The schematic is good though.
    Just noticed you have a DEFINE LOADER_USED 1
    Are you using a bootloader?
    Apr 2007
    No im not, im using melabs pic programmer. Should I take out that define statement?
    Apr 2007
    Okay, Finally I got the thing to show up on the pc! A 1k pull up resistor needs to be put on D+ and Vsub!! I was under the assumption that there was an internal pull up resistor there. Maybe I didn't configure that in the code.
    Well Thanks for everyones help so far.
    The windows doesnt recognize the device tho. So it wont enumerate as an HID device yet.
    There are internal pull-ups. And EasyHID configures them for Full-Speed, so you shouldn't need external ones.
    Did you use all the configs from post #11?
    In particular _VREGEN_ON_2L.
    Your original configs had that turned OFF, just want to make sure it's turned ON now.
    It doesn't really matter, it's fine even if not using a bootloader. But if you were using a bootloader it may have caused problems with the config settings, so I thought I'd ask.
    Apr 2007
    I used the config code from post 11, but _BORV_2_2L and _FCMEN_OFF_1H dont seem to be define for the 2550, so I took them out.
    Is there another file i need to include to get these fuses to work correctly?
    You still have MPASM 5.02 so it's _FCMEM_OFF_1H
    That'll change after you upgrade MPASM.
    _BORV_2_2L is defined for the 2550. I can see it in the .LST file in your .ZIP in post #10
    Can't image why there would be a problem with it. But since it's in the same line as _VREGEN_ON_2L, it makes me wonder if there's something else wrong with that line which caused the error.
    Apr 2007
    I looked at the list file and it should be _BORV_21_2L. So, now I've set the fuses correctly, nothing happens now. Windows doesnt pop up with anything, not even usb device unrecognized. I have no idea what could be wrong
    Apr 2007
    I set the fuses finally. The brown out reset voltage fuse is _BORV_21_2L, found this looking through the lst file. Now nothing seems to work, not even simple LED flashes. I have no idea what is going on.
    Now that you get "nothing". It seems like FCMEM_OFF is doing it's job, and now it's not running on the internal oscillator.
    I think your problem might be the 33pf caps on the crystal. Or a bad/wrong crystal.
    The datasheet shows that it should be around 22pf for 20mhz.
    With FCMEM_ON, the chip will switch over to the internal oscillator if the primary isn't working. You'll see LED's blink, but it's not the right frequency for USB to work.
    ___________
    Q. Why do they put braille on the number pads of drive-through bank machines?
    Mar 2005
    Iowa, USA
    Default O.t.
    Q. Why do they put Braille on the number pads of drive-through bank machines?
    A. The manufacture of the number pads on bank machines, have Braille on the numbers. Whether it is a drive through or walk up. It would be expensive to change the number pads on drive through machines, or put the braille enhanced number pads on walk up. The buttons being mass produced, are put on all of the number pads, no matter where they are located.
    Source:http://www.confusionwithin.us/docofbs/?p=11
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Apr 2007
    Okay I finally got it to work!
    I had to set the fuse values in melabs serial programmer as well as the fuses in the config files. I didn't know the programmer would rewrite the config values from picbasic pro.
    Thanks for the help guys!
