show on LCD decimal numbers
Results 1 to 9 of 9
    Jun 2006
    Default show on LCD decimal numbers
    It's possible to show on LCD decimal numbers;
    value = SQR 10 ' give 3,16
    i use this:
    Lcdout $fe,1, DEC (value DIG 2), "." ,DEC (value DIG 1) ,DEC (value DIG 0)
    but not show correct.
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by savnik View Post
    i use this:
    Let me guess....you're expecting 3.16 right?
    Do a search in the PBP manual for floating point math and tell me what you come up with (hint: we've already been through this in January, see post #8 of the "16f877 with LM335 problem" thread ).
    Apr 2006
    New Hampshire USA
    Smile A similar question (with answer)
    Hi savnik,
    This is a very common problem.
    A similar question is asked here.
    Be sure to see Darrel's great explanation:
    http://www.picbasic.co.uk/forum/showthread.php?t=5545
    -Adam-
    Jun 2006
    Default math problem
    i have two variables:
    x var word
    y var word
    and x < y.
    How to show on lcd the result of x/y , or the value = SQR x/y
    This has worked for me. Play with it.
    RESULT	VAR	WORD
    LCDOUT $FE,1,DEC RESULT/100,".",DEC2 RESULT//100
    Note DEC2 and // after the dummy “.”
    The DEC2 gives the last two digits and // gives the remainder or MOD of a number.
    I use this to monitor battery voltage to the hundredths place.
    skimask's Avatar
    skimask Guest
    x var word
    y var word
    and x < y.
    Right...I understand that. I'm still trying to make you understand.
    Again, I ask you to do a search in the PBP manual for floating point math and tell me what you come up with (same hint: we've already been through this in January, see post #8 of the "16f877 with LM335 problem" thread ).
    Jun 2006
    I have read the manual for floating point very well and i have see post #8 of the "16f877 with LM335 problem" thread.
    i use this:
                                            ' forwardpower  = 400
                                            ' reflectedpower = 20
        B0 = forwardpower/reflectedpower    ' = 400/20 = 20
        B1 = 10000/B0                       ' = 10000*1/20 = 500
        B2 = SQR B1                         ' = 22,360679
        B3 = (10000+B2*100)/(100-B2)        ' = (10000+22*100)/(100-22) = 12200/78 = 156,4
        Lcdout $fe,$90, "SWR  : ",DEC (B3 DIG 2),".", DEC (B3 DIG 1),DEC (B3 DIG 0)
    skimask's Avatar
    skimask Guest
    So what's the problem? What did you find about floating point in the manual?
    Jun 2006
    now i don't have problem.
    I spent many hours , how to solve my problem.
    with floating point i solve my problem
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. Play with LCD on PICDEM
  5. LCD will not start
