TTL input - 3rd states possible?
Results 1 to 27 of 27
    SWITZERLAND (french speaking)
    Default TTL input - 3rd states possible?
    Hello,
    I was asking myself about the possibility of using any TTL input of my PIC to "read" 3 different levels.
    Roughtly, for TTL values, the LOW level is from 0V to 1V and the HIGH is from 3,5V to 5V.
    Assuming this is not completely wrong, would it be possible to read 3 different states on the PIC?
    I tried to make it a simple way with a 2 resistor divider between Vdd and Vss. The middle point of the divider is logically connected to the pin.
    Two buttons are parallel connected each to a resistor.
    In theory, I can simulate 3 states:
    1.- 0V (if button "A" is pressed)
    2.- something around 2V (no button is pressed)
    3.- 5V (if button "B" is pressed)
    I can't achieve to read state 2.- but is it really possible... or am I dreaming?
    Roger
    skimask's Avatar
    skimask Guest
    Hello,
    You can do 3 states with a regular ol' TTL pin right now, but it takes a bit of programming.
    1 and 0 are self explanatory, set the pin to an input and read it...
    then you can read the 3rd state...open...
    set the pin to an output, output a 1, read the input back...if it's a 0, it's being held to a 0 (in other words, not open), then set the output to 0, read the pin back, if it's a 1, it's being held to a 1 (again, not open)...however if you read back exactly what you put out, then the pin can be reasonably assumed it's open.
    But the way you described works well too, if you're using a button sort of thing.
    Italy
    See tip #3:
    http://ww1.microchip.com/downloads/e...doc/40040b.pdf
    Best regards,
    Luciano
    Default Good documentation
    Thanks to both of you,
    The Tips & Tricks documentation is cool :-)
    I'll have a try with tis stuff.
    Roger
    Unhappy Can't get it working...
    Well,
    After a few hours trying to get a positiv result, I just got nothing working.
    I would like to read two buttons connected to one pin.
    The states are "0" and "1". The third "Z" state is not relevant to me here.
    To make sure I have an intermediate level, I use a 2 resistor divider like described in the first post.
    Currently, I can't get clear "0" or "1" states.
    Any idea?
    OSCCON       = %01100000  '4MHz
    OPTION_REG   = %10000000  'D I S A B L E PORTB's Pull-Ups for buttons
    ANSEL        = %00000000  'Disable Analogue Inputs
    TRISB        = %00010000  'Inputs/Outputs
    PORTB        = %00000000  'Drive all ports low
    MAIN:
        IF PORTB.5 = 0 THEN PORTB.0 = 1
        IF PORTB.5 = 1 THEN PORTB.1 = 1
        PAUSE 1000
        PORTB.0 = 0
        PORTB.0 = 0
        Goto MAIN
    I use PORTB.5 of my PIC16F88 for buttons because it is a TTL input only.
    Roger
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    you have PORTB.4 set as input, not PORTB.5
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Red face How can I be so blind?
    Thanks Paul,
    It was again far to obvious to me (the tree in the forest story...).
    I'll try again tomorrow and let you know.
    Thanks a lot.
    Roger
    Default Just tried - didn't want to go to bed frustrated...
    Well,
    I've still got one led always ON.
    In my understanding, I should get a state where no Led is ON.
    Is this correct?
    Roger
    skimask's Avatar
    skimask Guest
    Well,
    Is this correct?
    Show us your code again...
    Default My code
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1504&stc=1&d=117511986 5">
    I'm not sure about the ANSEL register. Shall I stay DIGITAL or ANALOG?
    I tried both but I get always the same result.
    I found this in the data-sheet; it's about the TTL levels.<img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1505&stc=1&d=117512006 5">
    As far as I can understand, the LOW level will be between Vss and 0,15V and the HIGH level between 2V and Vdd.
    Is this correct?
    Roger
    skimask's Avatar
    skimask Guest
    Do you have the other side of the LEDs connected to +5v or ground?
    Never mind the above
    Put another pause 1000 after your led1 = 0 : led0 = 0, see what happens.
    You might be missing the 'both leds off state' because it happens too quickly.
    Unhappy
    Both leds are connected to ground.
    I added the PAUSE as you mentionned. Now, Led0 is blinking slowly without any button pressed.
    Before I added the PAUSE, the Led0 was always ON until I pressed the button to make Led1 switch ON.
    So, unfortunately, no big change.
    I can see I never get a Z state (between Low and High TTL).
    I also measured my resistors and the voltage levels are correct.
    Roger
    Feb 2003
    Smile
    The only options for a digital input are high or low (1 or 0). If you provide a voltage (on a TTL pin) above 0.15*VDD but below 2 V, then the PIC has to decide whether to read the input as high or low - but the PIC will always pick one or the other, high or low (and this may fluctuate back and forth). If you stay below 0.15VDD or above 2V, then you know what the PIC will do ... if you are between these, then you do not know what the PIC will pick (1 or 0) or whether it will stick with the selected value.
    For your original logic shown in post #10, you would expect one of the LEDs to always be on (Skimask noted this for you). If you add the pause like he suggested, you would always expect to get the blinking you are getting because the pin is always read as high or low. With the pause added, the light goes on for a second, then off for a second and repeats as expected.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Paul,
    Previously, I have mentionned a doubt I had about the ANSEL (analog) settings because I agree with you, in DIGITAL, I can have only two states (0 & 1).
    Do I have to conclued that the reading of a "3 states ports" can be achieved only by means of software (as stated in the "Tips & Tricks" doc) and that it is not possible by reading the inputs states on the PIC's pins?
    I don't care about the Z state.
    I would like to read only both "0" and "1" states (2 buttons)...
    Roger
    T.Jackson's Avatar
    T.Jackson Guest
    Post Valid TTL Levels
    TTL - Transistor-Transistor-Logic, valid logic low between (0 - 0.8v), while valid logic high must be within the region of (2 - 5v) Any where between (0.8 - 2v) may be read as either logic high or low. You can't predict it. Could even oscillate.
    CMOS - Complementary-Metal-Oxide-Semiconductor on the other hand can be feed with up to 26% of VCC for a logic low and a minimum of 73% of VCC for a logic high.
    This industry standard ensures that CMOS is guaranteed to produce no more than 26% of VCC for a low output and no less than 73% of VCC for a high out.
    CMOS is far, far superior to TTL in that it mirror's current from in to out. Some CMOS chips can even partially function even without supply. i.e. if there's something on an input you still get something on an output. TTL is however much more robust. That's the trade off. Plus TTL has a much bigger fanout,
    which means that more inputs can be driven from an output.
    Trent Jackson
    Feb 2005
    Kolkata-India
    Default Not tested hastily made after reading post
    This is just an idea using the MChip Tips n' Tricks. No timer, no comparator just an idea. Flotulopex please test it out. Others on the forum please comment if it is crap.
    READ_SWITCH:
    TRISA.0 = 0             ' MAKE THE PIN AN OUTPUT
    PORTA.0 = 0             ' MAKE IT LOW
    PAUSE 100               ' WAIT FOR THE CAPACITOR TO DISCHARGE
    TRISA.0 = 1             ' MAKE THE PIN AN INPUT
    PAUSE 100               '
    IF PORTA.0 = 1 THEN SWITCH_HIGH   '
    LED1    = 0             ' DEFINATELY NOT HIGH
    PORTA.0 = 1             ' MAKE IT HIGH
    PAUSE 100               '
    PAUSE 100               '
    IF PORTA.0 = 0 THEN SWITCH_LOW   '
    LED0       = 0          ' DEFINATELY NOT LOW
    GOTO READ_SWITCH
    SWITCH_LOW:
    LED0 = 1
    GOTO READ_SWITCH
    SWITCH_HIGH:
    LED1 = 1
    GOTO READ_SWITCH
    P.S. - The code can be made shorter!!
    Sougata
    Default still blinking
    Hello Sougata,
    Thanks for your code (I copied/pasted it without any change and worked!!!). Unfortunately, the Led0 is still blinking.
    I made a code (also based on the Tips & Tricks) very similar to yours and had the same result.
    As one can multiplex 6 Leds with only 3 pins, I thought I could do something similar with buttons on 1 port.
    After a lots of trials, I think it is not feasable... or I still miss something.
    As already said, I don't care about the Z state. Only both "0" and "1" states would be used.
    Roger
    skimask's Avatar
    skimask Guest
    Hello Sougata,
    Curious...why are you worried about the 'Z' state?
    Is it the fact that it can 'hover' around the trip point and cause false readings if left open?
    Feb 2005
    Kolkata-India
    Question Time for your schematic and entire code
    It is possible. Did you connect your PIC according to the schematic I provided. <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1507&d=1175158348" align="absmiddle">Try increasing the pause. Please post your entire code and schematic. It is possible in one way or the other. I have chosen the Digital way. Detecting multiple switches with one pin is also possible using the ADC. By the way the circuit doesn't work when both the switches are pressed simultaneously. The 1K resistors are provided for that purpose so that you don't blow up your PS. When both are pressed most likely your PIC would read a logic high. As you get 1/2VDD and @ 5 volts it is good enough to be a logic 1. In any TTL/CMOS gate your cannot have anything other than 0 or 1 in your output whether your inout is at 0,1 or Z. So software tricks does it. By switching your port pin between input and output and detecting the holding capacitors state. I repeat please post your exact code and schematic and it should work.
    Let me clarify my understanding about your requirement.
    • You need to use only one pin of your PIC.
    • You need to connect 2 switches to that.
    • You need to determine whether your input is hanging idle (Z)
    • Switch connected to VDD was pressed (H)
    • Switch connected to VSS was pressed (L)
    I am waiting.
    Sougata
    ? I don't understand. I said I don't care about the Z state. I would like to read "0" and "1" states (= read two buttons on 1 pin).
    Sougata,
    The code I use is almost the same as yours. I'll post it this evening (I'm in the office now).
    The shematic is absolutely the same as yours but I've some different values:
    PIC16F88-4MHz int osc
    R1 = 10k
    R2/R3=1k2
    Nevertheless, you have pointed out what I was expecting.
    I'm afraid that reading states that must be defined by software will slow down the maniability of your program.
    In my case, I'm (re)making a SIMON game and when you get use to play with this, you can be quite fast on the buttons.
    I already tried with A/D; this was far to slow. RCTime was to slow too.
    I'll have another try and come back for a feedback.
    Roger
    skimask's Avatar
    skimask Guest
    Ok, now I smell what you're cooking.
    I know you don't care about the 'Z' state, but you probably have to 'worry' about it in this case.
    How about this... when you write to a port, you write the data register, when you read a port, you read the actual pin...so...
    The button's are set up just like in the schematic above.
    You set the pin to an output, and high...read back the pin...
    If it's still high, either the one button pulling it high is pressed or, neither are pressed, if it's low, the other button is pressed...
    Then you set the pin low...read back the pin...
    If it's still low, the one button pulling it low is pressed or, neither are pressed, if it's high, the other button is pressed...
    Problem with this approach is finding a low value to pull the pin far enough (either way) to change states, and yet not smoke the guts of the pin itself.
    pinput var portd.0 : temp var bit : realinput var byte '0=lo, 1=hi, 2=no push
    output pinput : pinput = 1 : temp = pinput
    if temp = 0 then
    realinput = 0 : goto finish
    pinput = 0 : temp = pinput
    if temp = 1 then
    realinput = 1
    realinput = 2 : goto finish
    finish: 'done here
    I haven't tried this, might work, might not. If you do go this route, start with high resistor values (10k or so) and work your way down. It'll either start working or smoke the PIC.
    Personally, I like sougata's solution better. If you drop the cap and resistor values, you'll be able to drop the pause values as well, and make everything a lot faster.
    in general you don't want to add the capacitor. In this case you just need a current limiting resistor, anything bellow 10 and above Vcc/25mA. Just do what Skimask said.
    Set pin as output
    set it high
    Set the pin as input
    read it
    Set pin as Output
    Set it low
    Set pin as input
    read it
    Now compare both reading and have fun with.
    It may work in PBP, but i'll suggest some ASM lines.
    Okay; finally, it works.
    Here is my code I had to correct according to Sougata's example.
    ' Fuses
    @ DEVICE PIC16F88,INTRC_OSC_NOCLKOUT
    @ DEVICE PIC16F88,PROTECT_OFF
    @ DEVICE PIC16F88,WDT_OFF
    @ DEVICE PIC16F88,PWRT_ON
    @ DEVICE PIC16F88,MCLR_ON
    @ DEVICE PIC16F88,BOD_OFF
    @ DEVICE PIC16F88,LVP_OFF
    @ DEVICE PIC16F88,CPD_OFF
    @ DEVICE PIC16F88,DEBUG_OFF
    @ DEVICE PIC16F88,CCPMX_OFF
    ' Registers   76543210
    'ANSEL      = %00000000  'Disable Analogue Inputs
    TRISA      = %00000000  'Inputs/Outputs
    TRISB      = %00100000  'Inputs/Outputs
    ' Variables
    Led0  var PORTA.0
    Led1  var PORTA.1
    HiLow var PORTB.5   'this port is TTL only
    InOut var TRISB.5
    Time  var byte
    time  = 2
    ' Program
    MAIN:
        inout = 0
        hilow = 0
        pause time
        inout = 1
        pause time
        if hilow = 1 then led1 = 1 : goto main
        led1  = 0
        inout = 0
        hilow = 1
        pause time
        inout = 1
        if hilow = 0 then led0 = 1 : goto main
        led0 = 0
        Goto MAIN
    ANSEL or not, it works.
    I changed the 0,1µF cap for a 0,01µF and reduced the pause time to 2 so it goes drastically faster.
    Thanks a lot for your patience.
    In fact, I was stuck in my mind thinking this problem would have to be resolved another way than by a software routine...
    Roger
    Thumbs up Great
    Thanks mister_e, I just read your post.
    I removed the cap and PAUSEs.
    It works too very well.
    Cool
    Roger
    use a ADC input....
    EDIT: just read yours... WOOOHOOO! good luck!
    Default Asm?
    mister_e,
    May I ask you what this BASIC routine would have become in assembly?
    Please, don't waste your time if it is long to do.
    I'm just curious to compare what "I know" (=BASIC) to what I don't (=ASM).
    I don't really understand the difference between BASIC and ASSEMBLY in terms of program execution speed (looks to be faster in ASM but I don't understand why - have to find other threads for more info) because I never looked into it up to now - looks very complicated.
    Roger
    skimask's Avatar
    skimask Guest
    I used to worry about how tightly BASIC compiles down to actual assembly. I don't anymore. If you look at PBP source code relatively close, you'll see that most of the PBP commands directly relate to straight assembly programming, while others may take 1-2-3 ASM instructions to complete a PBP instruction. Again...I used to worry about it. There's only a few instances where straight assembly can make anything faster. If you really want to see it, take a look at your .LST file generated during assembly. Put a couple of labels around the code you're interested in and do a search of the file.
  1. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 19:51
  2. RB0 + Internal Pullup + Interrupt
    By Freman in forum mel PIC BASIC Pro
    Last Post: - 10th August 2009, 12:11
  3. LED "capacitance" won't get lower
    Last Post: - 3rd May 2007, 21:31
  4. Timing input pulses and re-outputting them
    By jamie_s in forum mel PIC BASIC Pro
    Last Post: - 28th February 2007, 02:50
  5. Using LEDs as light sensors
    By skimask in forum Code Examples
    Last Post: - 30th December 2006, 23:19
