Well this device is some kind of 16 ports 1Wire to Serial HUB, it sends serial
data to a pc with the info requested by the PC, maybe write the pages of a 1wire device (0-15 pages), read de Identification from a 1Wire, read some temperatures, you should be able to do anything to any device on the port.
Why?: well in this development I am using up to 16 i-buttons, actually they where read directly through the PC. And i am in Colombia, it is not easy at all to find DS parts, even more it is really expensive.
What kind of info? well mostly OW commands with data bytes, since each page is 32 bytes it would be interesting to receive and send everything in an array 32 bytes long. Exactly?... well $F0, $cc, some bytes... typical protocol bytes for 1wire
Pins used: PORTB (ALL), portA (0-3... i hate pin4
), portC(2,3), portd (0,1)
Thats all.... its simpler than it seems i guess.... i might do other simple tasks, but iīm sure i dont need help with that.
I really want to learn this, i m sure you have a great tip behind this request.
Thanks Again
