Can anyone recommend me a GSM modem model?
Results 1 to 11 of 11
    Mar 2007
    Smile Can anyone recommend me a GSM modem model?
    Hi guys,
    I'm new to this group. Can anyone tell me which GSM modem to buy?
    1. Wavecom M1306B GSM Modem
    2. Nokia GSM modem (which particular model )
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by aromacor View Post
    Hi guys,
    Buy them both and figure out which one works...
    Mar 2007
    Smile GSM Modem Selection
    Thanks for your advice Sir but I don't think I can't afford to buy two that's why I joined this forum.
    Thanks anyway.
    skimask's Avatar
    skimask Guest
    Thanks anyway.
    Then it sounds to me like you should've joined a forum on GSM instead of the PicBasic forum that you did join.
    Mar 2007
    Default GSM Modem Help
    I actually bought a book on PIC. I'm very interested to develop projects like you guys but right now I need to study AT commands.Thanks
    skimask's Avatar
    skimask Guest
    Then study AT commands.
    www.google.com
    search for Hayes Modem AT Command Set
    Mar 2004
    Sony Ericsson Gm29 is good. compact module 12v external antenna, standard AT + model specific commands. Nifty feature, has handset socket that allows a standard handset from a land line phone to be connected. this allows two way phone conversation once you have initiated the call with the AT command. I have used this feature for fault finding.
    I've used Falcom Tango and Telit EZ-10 modules for development with success. Falcom allows condenser mic to be directly connected, Telit is well priced
    www.falcom.de
    www.telit.com
    Mar 2007
    Default Hi Mr. Anderson
    Hi
    Thanks for your advice. Sorry for my late reply. I just checked my emails today. I'm wondering if Wavecom is related to Falcom since I've read somewhere about Wavecom falcom GSM modem. I'm not sure if I remembered correctly.
    Roderick
    Hi Roderick-
    Yes, The Falcom Tango modem uses a Wavecom GSM chip internally, with the Wavecom AT instruction set.
    Mar 2007
    Default Thanks a lot
    Hi Mr. Anderson,
    Thanks a lot for the info. I will be delighted to try out the AT commands when I have the device. Thanks again.
    Roderick
  1. Interface Pic --> Max232 --> GSM Modem
    By SangkiMangki in forum GSM
    Last Post: - 28th September 2013, 12:57
  2. Replies: 10
    Last Post: - 26th May 2008, 07:00
  3. Anyone used a WAVECOM gsm modem ?
    By isaac in forum mel PIC BASIC Pro
    Last Post: - 8th September 2007, 13:15
  4. PIC18F2550 and GSM modem
    By zach in forum GSM
    Last Post: - 28th November 2006, 09:01
  5. SEROUT2 to GSM Modem
    By tommyers in forum General
    Last Post: - 21st August 2006, 21:35
