Funky I/O pin behavior on PIC12F629???
Results 1 to 2 of 2
    charliez's Avatar
    charliez Guest
    Question Funky I/O pin behavior on PIC12F629???
    Problem 1. For some reason, pin 0 and pin 1 will not latch the output value when another pin output follows it. Other pins work fine (I know pin 3 is input only).
    The code is as follows:
    i var byte
    loop: 'turn on LEDs
    HIGH 0
    pause 5000 ' led 0 will stay on for 5 seconds
    HIGH 1 ' but will turn off here, and led 1 comes on
    pause 5000 ' led 1 will then stay on for 5 seconds
    HIGH 2 ' led 1 will turn off here, and led 2 comes on
    pause 5000
    HIGH 4 ' led 4 on, led 2 stays on, while 0 and 1 are off.
    pause 5000
    HIGH 5 ' led 5,4,2 stays on, while 0 and 1 are off
    pause 10000
    For i = 0 to 5 'turn off LEDs
    LOW i
    next
    pause 10000
    goto loop
    Problem 2. Pin 1 for some reason can not be made an input.
    PINS VAR PORTL
    PIN0 VAR PINS.0
    PIN1 VAR PINS.1
    INPUT 1
    IF PIN1 THEN
    HIGH 0
    What am I missing?
    charliez's Avatar
    charliez Guest
    Talking Solved
    Ha, found the cause. GP0 and GP1 are comparator inputs.
    To make them true I/O pins I needed to add the following line:
    CMCON=%00000111
    at the beginning
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  2. Microcontroller with 2 way paging application problem
  3. Another RTC, DS1287
    Last Post: - 12th December 2006, 17:07
  4. Grounding Negative voltage through I/O pin
    By Squibcakes in forum Schematics
    Last Post: - 31st July 2006, 12:12
  5. I/O pin and MCLR
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 15th July 2004, 10:52
