+ Reply to Thread
Results 1 to 5 of 5
    pjsmith's Avatar
    pjsmith Guest
    Default Proton development board with Picbasic
    Anyone using one of these with MELABS Picbasic Pro? I've got one but the defaults for LCD etc are different as it's designed for their proton basic.
    Does anyone have any code samples for it? I'd like to see a few examples of LCD output, adin etc.
    Thanks.
    carl_schell's Avatar
    carl_schell Guest
    Cool Development boards & Defines
    PJ Smith -
    I do not have the proton development board, but it is a very easy thing to modify LCD defaults or any other such thing.
    All you do is change the DEFINE statements:
    e.g.:
    Lets say the default for the enable pin of the LCD is PortB.3
    and your development board is wired for the enable pin of LCD connected to Port D.4. Simple:
    '===Was===:
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 3
    '===Change to===:
    DEFINE LCD_EREG PORTD
    DEFINE LCD_EBIT 4
    Then simply add your code:
    LCDOut $FE,1,"LCD working"
    There are many define statement...refrence your PBP manual, Appendix B.
    Best Regards;
    Carl
    www.schellelectronics.com
    P.S. - You could also simply throw out your proton development board and purchase my PIC Deelopment Board with bootloader at www.schellelectronics.com !
    It also comes with sample programs
    pjsmith's Avatar
    pjsmith Guest
    Thanks for the quick answer. I've already looked at your site and would definately have gone for it if I didn't already have spent several hundred getting to where I am. I just wish I'd seen it earlier. I may still take you up on it
    I had the following from the proton people
    LCD_DTPIN = PORTD.4
    LCD_RSPIN = PORTE.0
    LCD_ENPIN = PORTE.1
    LCD_INTERFACE = 4 ' 4-bit Interface
    LCD_LINES = 2
    LCD_TYPE = 0
    SCL_PIN = PORTC.3
    SDA_PIN = PORTC.4
    SERIAL_BAUD = 9600
    RSOUT_PIN = PORTC.6
    RSOUT_MODE = TRUE
    RSOUT_PACE = 1
    RSIN_PIN = PORTC.7
    RSIN_MODE = TRUE
    HSERIAL_BAUD = 9600 ' Set baud rate to 9600
    HSERIAL_RCSTA = %10010000 ' Enable serial port and continuous receive
    HSERIAL_TXSTA = %00100100 ' Enable transmit and asynchronous mode
    HSERIAL_CLEAR = ON ' Enable Error clearing on received characters
    KEYPAD_PORT = PORTB
    CCP1_PIN = PORTC.2
    CCP2_PIN = PORTC.1
    Symbol T300 = 3313 NO_LIST
    Symbol N300 = 3313 + $4000 NO_LIST
    Symbol T600 = 1646 NO_LIST
    Symbol N600 = 1646 + $4000 NO_LIST
    Symbol T1200 = 813 NO_LIST
    Symbol N1200 = 813 + $4000 NO_LIST
    Symbol T2400 = 396 NO_LIST
    Symbol N2400 = 396 + $4000 NO_LIST
    Symbol T4800 = 188 NO_LIST
    Symbol N4800 = 188 + $4000 NO_LIST
    Symbol T9600 = 84 NO_LIST
    Symbol N9600 = 84 + $4000 NO_LIST
    Symbol OT2400 = 396 + $8000 NO_LIST ' Open True
    Symbol OT1200 = 813 + $8000 NO_LIST ' Open True
    Symbol OT9600 = 84 + $8000 NO_LIST ' Open True
    Symbol OT300 = 3313 + $8000 NO_LIST ' Open True
    Symbol ON2400 = 396 + $4000 + $8000 NO_LIST ' Open Inverted
    Symbol ON1200 = 813 + $4000 + $8000 NO_LIST ' Open Inverted
    Symbol ON9600 = 84 + $4000 + $8000 NO_LIST ' Open Inverted
    Symbol ON300 = 3313 + $4000 + $8000 NO_LIST ' Open Inverted
    Symbol HOME = 1 NO_LIST
    Symbol BELL = 7 NO_LIST
    Symbol BKSP = 8 NO_LIST
    Symbol TAB = 9 NO_LIST
    Symbol CR = 13 NO_LIST
    ALL_DIGITAL = TRUE ' Set PORTA and PORTE to all digital
    So I've added
    ' LCD defines for proton board
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTE
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTE
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_RWREG PORTE
    to the program and tried
    but I still get nothing. The LCD is just showing squares, like it's always done. Does this look right to you?
    Thanks for the newbie help!
    carl_schell Guest
    Cool
    PJ Smith -
    Thanks for looking at our site.
    As to your questions, one more thing you could check:
    You didn't mention which PIC you are using...but i noticed some of your LCD pins are on port E...this is no problem, however, Port E on the 16F877A are Analog pins (when set to analog, pin can not output...only input, so must be changed to digital!) You can do this by setting your ADCON1 regester. e.g....to make all analog pins digital on the 16F877A type:
    ADCON1 = 7
    Also check your TRIS statements (1 = input, 0 = output)
    If you need some of these set as analog, no problem, just look in the data sheet to set as desired
    You have to set bits 3,2,1,& 0 to match your desired A or D
    '***ADCON1 Register for 16F877A***
    'Bit 7 => ADFM: A/D Result format select
    ' 1 = Right Justified. 6 most significant bits of ' ADRESH are read as ‘0’.
    ' 0 = Left Justified. 6 least significant bits of ' ' ADRESL are read as ‘0’.
    'Bit 6 => Unimplemented: Read as ’0’
    'Bit 5 => Unimplemented: Read as ’0’
    'Bit 4 => Unimplemented: Read as ’0’
    'Bit 3 => PCFG3 A/D Port Configuration Control bits
    'Bit 2 => PCFG2 A/D Port Configuration Control bits
    'Bit 1 => PCFG1 A/D Port Configuration Control bits
    'Bit 0 => PCFG0 A/D Port Configuration Control bits
    Check this to make sure you are ok.
    Best of luck...
    Carl
    pjsmith's Avatar
    pjsmith Guest
    Thanks very much. ADCON1 = 7 got the LCD working.
    Pretty steep learning curve at the moment!
  1. microcode studio and ql200 development board
    By mombasa in forum mel PIC BASIC Pro
    Last Post: - 1st October 2015, 17:28
  2. Pretty cool display and development board PIC_LCD3310
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 17th April 2010, 10:05
  3. Proton PICBASIC vs MeLabs PICBASIC
    By Fredrick in forum General
    Last Post: - 11th January 2008, 21:51
  4. Anyone use the Solderless Proton Dev Board?
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 28th January 2007, 16:50
  5. Development Board
    By carl_schell in forum Adverts
    Last Post: - 21st July 2004, 08:39
