Incoming Pulse Monitoring code - comments and suggestions welcome
Results 1 to 4 of 4
    Aug 2005
    Default Incoming Pulse Monitoring code - comments and suggestions welcome
    I've been working on a project that looks at an incoming pulse which is a 50% duty cycle and varying between 0 to 400hz.
    This project is using the instant interrupts routines to do all its work.
    The pic basically needs to invert the incoming pulse and put it back out of a port, however, If theres no incoming pulse for around 1.5 or more seconds, then the pic needs to generate approx 15 Hz on the same output port, until the incoming pulse is restored, then it will output the inverted incoming pulse back on the output.
    On the scope it seems to work upto about 2kHz which is more than enough speed for my purpose.
    Anyway here is my code, any comments or suggestions are welcome (sorry about the formatting, it did look ok in MPLAB)
    '  	Pulse Monitor
    '  	PIC16F628A @ 4mhz
    '	Input Signal Port B.3
    '	Output Signal Port B.5
    CMCON = 7						' set portA to digital
    TRISA = %00100000				' Port A all output but MCLR
    TRISB = %00001000				' Port B all output but 3 (CCP)
    T1CON = %00110000				' Set Timer 1, Off and 1/8 prescale (fire every 520ms)
    T2CON = %00000011				' Set Timer 2, Off and 1/16 prescae (fire every 4ms)
    Symbol  Capture = PIR1.2 		' CCP1 capture flag
    T1count		VAR BYTE			' Timer 1 count (1 count = 0.52 sec)
    i			VAR BYTE			' i is the incrementer for the pulse generator
    INT_LIST  macro    	 ; IntSource,   Label,  	Type, ResetFlag?
            INT_Handler	   CCP1_INT,  _gotpulse,	PBP, 	yes
    		INT_Handler    TMR1_INT,  _nospeed,		PBP,  	yes
    		INT_Handler    TMR2_INT,  _generate,   	PBP,  	yes
        INT_CREATE               	; Creates the interrupt processor
        INT_ENABLE   TMR1_INT     	; enable timer1 interrupts (CCP timer)
    	INT_ENABLE 	 CCP1_INT	  	; enable CCP port change interrupt
    	INT_DISABLE  TMR2_INT     	; enable timer2 interrupts (pulse generator)
    	Low portb.5					' start with Portb.5 low
    	T1count = 0					' set variable
    	i		= 0					' set variable
        CCP1CON = %00000100  		' Capture mode, capture on falling
        T1CON.0 = 1          		' Turn TMR1 on here
    MainLoop:
    	pauseus 20
        GOTO MainLoop
    '---[CCP1 - interrupt handler - We got an input Pulse] ---------------------------------
    gotpulse:
    		If CCP1CON.0 = 0 then			' if we captured a falling edge, switch to rising edge
    		CCP1CON.0 = 1
    		if CCP1CON.0 = 1 then			' if we captured a rising edge, switch to a falling edge
    		CCP1CON.0 = 0
    		Portb.5 = Portb.3 ^ $0F			' Output PortB.5 = inverted state of Portb.3
    		TMR1H = 0            			' Clear high byte of TMR1 counter
        	TMR1L = 0            			' Clear low byte
    		@ INT_DISABLE  TMR2_INT     	' disable timer0 interrupts (pulse generator)
    	    T2CON = %00000011				' Set Timer 2 Off prescale 1/16
    @ INT_RETURN
    '---[TMR1 - interrupt handler - Called when CCP Timer Overflows @ 520ms] ---------------
    nospeed:
    	 T1count = T1count + 1				' increment every 520ms
    	 If T1count >= 3 then				' no pulses for 1560ms, start generating them
    	 T2CON = %00000111					' Set Timer 2 prescale 1/16 and on
    	 Low portb.5						' start with portb.5 low
    	 @ INT_ENABLE  TMR2_INT    			' enables timer0 interrupts (TMR0 fires on Overflow)
    	 T1count = 0						' reset the TMR1 count
    @ INT_RETURN
    '---[TMR2 - interrupt handler - This will fire every 4ms]----------------------------------
    ' send a 20ms pulse every  (12 *4ms) 48ms, gives a frequency of ~ 15hz
    generate:
    i = i + 1								' increment tmr2 count
    if i => 12 then							' equal to or more than 12, send a pulse
    pulsout portb.5,2000					' 20ms pulse out
    i = 0									' wait another 12+ cycles
    @ INT_RETURN
    Hi jamie,
    It's nice to see more examples with Instant Interrupts popping up.
    I think using the CCP to generate an interrupt on every transition of the Input is slowing things down.
    If you handle the "Input to Inverted Output" in the main loop, It should go alot faster than 2khz.
    Then the interrupts can just handle the timer overflows.
    Here's a possibility ...
    '  	Pulse Monitor
    '  	PIC16F628A @ 4mhz
    INCLUDE "ReEnterPBP.bas"        ' Include if using PBP interrupts
    InPIN       VAR PORTB.3         ' Input Pin
    OutPIN      VAR PORTB.5         ' Output Pin
    TMR1ON      VAR T1CON.0
    TMR2ON      VAR T2CON.2
    LastState   VAR BIT
        INT_ENABLE   TMR2_INT       ; enable timer2 interrupts (pulse generator)
    Low OutPIN                      ' start with Output LOW
    TMR1ON  = 1                     ' Turn TMR1 on here
    '---[MainLoop handles the Inverted transfer From InPIN to OutPIN] ----------------------
    MainLoop:
        if InPIN <> LastState then  ' If Input State Changed
            LastState = InPIN
            TMR2ON = 0              ' Stop Timer 2
            OutPIN = LastState ^ 1  ' Output = inverted state of Input
            T1count = 0
    GOTO MainLoop
    '---[TMR1 - interrupt handler - Called when Timer1 Overflows @ 520ms] ------------------
    nospeed:
            TMR2ON = 1              ' Set Timer 2 on
    @ INT_RETURN
    '---[TMR2 - interrupt handler - This will fire every 4.103ms]------------------------------
    ' send a 20ms pulse every  (12 * 4ms) 48ms, gives a frequency of ~ 15hz
    generate:
        if i < 12 then              ' Pin is low for 1-11
            OUTPIN = 0
            OutPin = 1              ' Pin is high for 5 ints  (20ms)
        If i = 17 then i = 0        ' restart cycle, total = 69.751ms = 14.3hz
    @ INT_RETURN
    Last edited by Darrel Taylor; - 4th March 2007 at 06:58. Reason: Changed INT_DISABLE TMR2_INT - to - INT_ENABLE
    Aug 2007
    Default 18f4431 try to use three-input capture mode with hall-effect senor state transitoin d
    capture
    ansel0=%00000000 'all digital
    trisa=%11111111 'set all port a pins to input cap1,cap2,cap3
    trisb=%00000000 'set all port b pins as output
    t1 var word
    t2 var word
    t3 var word
    Capture1 var pir3.1 ' tmr5 value was capture by the active edga on capl input
    Capture2 var pir3.2 'interrupt flag for pin cap2
    Capture3 var pir3.3 'interrupt flag for pin cap3
    ' auto time base reset, capture on rising to falling edge
    RiseToFall CON %01000111
    ' auto time base reset, capture on falling to rising edge
    FallToRise CON %01000110
    false con 0
    true con 1
    'capture mode
    intcon =0 'interrupts off
    tmr5h = 0 'clean high byte of tm5 counter
    tmr5l = 0 'clean low byte
    t5con = %00000001 ' prescale 1:1, int clock, tmr5 =on
    cap1con=%01000111 ' enable caputure,pulse width measurement mode,
    'every rising o falling edge
    cap2con=%01000101
    cap3con=%01000101
    Capture1 = false 'rest caputer flag
    Capture2 = false
    Capture3 = false
    main :
    if (Capture1=true)and(capture2=true)and(capture3 = true) then
    high portb.7
    if (Capture1=true)and(capture2=false)and(capture3 = true) then
    high portb.6
    Aug 2007
    Default need help with 3-input caputer transtion detector
  1. Pushbutton code routine suggestions?
    Last Post: - 3rd September 2005, 01:02
