Does anyone have comments or experiences to share about using the op amps in the 16F785?
I have an application in mind, and using the 785 would eliminate a lot of glue.
Russ
N0EVC, xWB6ONT, xWN6ONT
"Easy to use" is easy to say.
I had, worked great for me on some kind of feedback control and few audio gizmo. Having their output directly connected to ADCs input (and comparator) is somehow useful, this also give you an external test point.
The two phase PWM was also a nice feature for me.
No bad comments on them from me.
What I'd like to do is cascade the op amps, then use the two comparators as a window detector.
Russ
Just look how they're internal connected, I don't think it will be 100% doable, but probably close enough. Sure comparator interrupts are handy, while sometime a couple of ADC reading would do... it really depends of the final application and timing i guess.
Russ
