Hardware I2C
Results 1 to 12 of 12
Thread: Hardware I2C
    Jun 2005
    Default Hardware I2C
    Is it possible to use the Hardware I2C in PicBasic Pro?
    I need to read faster than I2CREAD PicBasic Pro command. Even with a 20MHz crystal I'm unable to obtain full speed I2C.
    Surely someone have ever work on that issue. Maybe an assembly include?
    Thank you
    Mentor, Ohio
    Smile
    Hi Toley00,
    It may be worth your time to download the I2C Bus Specification manual from Phillips. There are 3 data modes for I2C, Standard Mode = upto 100kbits/sec, Fast Mode = upto 400kbits/sec, and High Speed Mode = 3.4Mbits/sec. I've only used I2C for RTC's using both software I2C and Hardware I2C. I didn't have to set anything up special on my PICs for speed. But you do have to put a 10ms pause after any write command to give it time to catch up or settle down. I have seen some posts on this forum where I2C worked better when it was slowed down.
    Don't know if this helps, but I think maybe their manual might give you a better insight into the whole process.
    BobK
    Jun 2005
    Thank you BobK for your reply.
    I already know about I2C timing protocol, and I use it in many project already. I just need it to read an EEPROM faster than I2CREAD can do.
    Thanks for your help but a 10ms pause will not give me speed...
    May 2006
    Del Rio, TX, USA
    I don't know what PIC you are using, so I can't promise anything, but I've attached a file containing some portions of code I have used with the hardware I2C on a PIC 18F4620.
    The file is a compilation of cut and past from a few include files, and has only been minimally "cleaned up" for public viewing. It has 4 sections:
    1) Basic PIC and HSEROUT setup (mostly to reinforce what pic and how it's configured)
    2) The meat of the I2C commands
    3) Samples of Large Block Reading/Writing to an EEPROM
    4) Samples of Reading/Writing to an RTC
    Hopefully this will get you started.
    Best of luck,
    Steve B
    Disclaimer: Looking a little closer I recall this being one of my first PBP-ASM items I tackled. It worked, and with other things pressing, I haven't gone back and cleaned things up, like unused variables (DelayCtr1 and DelayCtr2) and rements of HSEROUT commands used to debug.
    Jun 2005
    Thank you SteveB, looks like what I need. I will take a closer look and adapt it to my needs. I'm using a PIC16F886, but I think all MSSP modules work the same way, and I only need to read from the EEPROM.
    Pinckney, Michigan
    Also consider the RAMTRON FM24C256 32K X 8 eeprom.
    It reads and writes at FULL I2C buss speed. No artificial delays required.
    It is also pin-for-pin compatible with many common serial eeproms, and might just plug directly into your eeprom socket.
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by Toley00 View Post
    A couple of things right off the top of my head. The buffer size will need to be reduced for a 16F. Also, the way I allocated variables to "BANKA" or "BANKX" in the declaration statements will also need changing. If I get a chance later I'll try to give it a look-over for anything else. As I recall, I think I got the basics of the ASM routines from a Microchip document/source, and adapted them for the 18F. So that might also be an avenue to persue.
    Steve B
    Feb 2005
    Kolkata-India
    Thumbs up Thanks SteveB
    SteveB your routines are neat (at least than mine) and I learnt from it as well. Thanks to you and Toley for raising the topic.
    Sougata
    May 2006
    Del Rio, TX, USA
    I made a quick run through the code (while my kids took a nap). Changed all the ASM to PBP. Also modified the buffer size, and some SFR lables to correspond the 16F. It compiles OK, but no 16F's to test it (nor anything to setup the circut without canibalizing something else). Keep in mind, on many of the 18Fs, you've got RAM to burn, so the buffers reflect that. On the 16Fs, you don't have that luxary.
    Hopefully, if you are working it on your end, you can compare/use what I've done to move further down the road.
    I did notice a number of areas where things could be improved or I would do thing differently. The error handling is especially weak. However, I never got any errors with the code and my setup, so never needed it to be very robust. So, I will put this on my *LONG* list of things to do when I get around to it.
    SteveB
    Jun 2005
    Thumbs up Project finished!
    Thank you SteveB, with your help (and a lot of time) I finally make it work. I've changed some things in your Routines. First I changed the Labels for shorter names. I've also changed the lines refer to PIR1.3 for SSPSTAT.2 to indicate when a transmit is over. And I fixed a little error in your code RCEN is SSPCON2.3 instead of SSPCON2.4.
    In Fact all that is need is to correctly set the MSSP module :
    SSPSTAT.7 = 0 'High Speed Filter
    SSPADD = $0C '400 kHz @ 20 MHz
    SSPCON = %00101000 'I2C Master Mode Enable
    And in your main program use the 6 next sub routines as needed :
    ; Process Routines
    I2CSTART:
    SSPCON2.0 = 1 ; SEN - Start Condition Enable Bit
    WHILE SSPCON2.0 = 1 : WEND ; Wait for Start to complete
    I2CRD:
    SSPCON2.3 = 1 ; RCEN - Enable receive mode
    WHILE SSPCON2.3 = 1 : WEND ; Wait for Read to complete
    I2CDATA = SSPBUF
    I2CWR:
    SSPBUF = I2CDATA ; Move data to SSPBUF
    WHILE SSPSTAT.2 = 1 : WEND ; SSPSTAT = 1 Transmit in progress
    While SSPCON2.6 = 1 : WEND ; Wait for Acknowledge from slave 1=NotAck
    RETURN ; Acknowledge recieved
    I2CSTOP:
    SSPCON2.2 = 1 ; PEN - send stop bit
    While SSPCON2.2 = 1 : Wend ; Wait for SSP to complete
    I2CNOACK:
    SSPCON2.5 = 1 ; ACKDT - Set Ack bit to NotAck
    SSPCON2.4 = 1 ; ACKEN - send ACKDT bit
    While SSPCON2.4 = 1 : Wend ; Wait for SSP to complete
    I2CACK:
    SSPCON2.5 = 0 ; ACKDT - Set Ack bit to Ack
    Now By using thoses sub routines, I'm able to access an EEPROM fast enough to read a 8 sec. wav files at 8 kHz. Everything is written in PicBasic Pro (no assembly) and is at least 3 times faster than standard I2CREAD statement.
    Ok I know it's not really "User friendly" but my programming skills are limited and it work fine for me like this. Maybe someone can write something easier to use, it could be very handy.
    May 2006
    Del Rio, TX, USA
    It's great to here when someone has success. Especially when they have put in the work (like getting into the datasheet) that you have.
    SteveB
    Default Re: Hardware I2C
    I tried to use above code with 24C32 and PIC16F887 but it does not works. It stuck on this loop: while SSPCON2.0 = 1 : wend
    Here's complete code:
    '*  Name    : I2C EEPROM                                        *
    '*  Author  : Daniel T. Barber                                  *
    '*  Notice  : Copyright (c) 2018                                *
    @ ERRORLEVEL -306   ' turn off crossing page boundary message
    '************ Config Settings for 16F877A *************
    cfg1 = _INTRC_OSC_NOCLKOUT    ; INTOSCIO oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    cfg1&= _WDT_ON                ; WDT enabled
    cfg1&= _PWRTE_OFF             ; PWRT disabled
    cfg1&= _MCLRE_OFF             ; RE3/MCLR pin function is digital input, MCLR internally tied to VDD
    cfg1&= _CP_OFF                ; Program memory code protection is disabled
    cfg1&= _CPD_OFF               ; Data memory code protection is disabled
    cfg1&= _BOR_OFF               ; BOR disabled
    cfg1&= _IESO_ON               ; Internal/External Switchover mode is enabled
    cfg1&= _FCMEN_ON              ; Fail-Safe Clock Monitor is enabled
    cfg1&= _LVP_OFF               ; RB3 pin has digital I/O, HV on MCLR must be used for programming
    cfg1&= _DEBUG_OFF             ; In-Circuit Debugger disabled, RB6/ICSPCLK and RB7/ICSPDAT are general purpose I/O pins
      __CONFIG _CONFIG1, cfg1
    cfg2 = _BOR40V                ; Brown-out Reset set to 4.0V
    cfg2&= _WRT_OFF               ; Write protection off
      __CONFIG _CONFIG2, cfg2
    TRISA=%00000000  'SET A TO OUTPUT   1=input
    TRISC=%00011000   'set C 3 4  input
    TRISB=%00000000   'set PortB to output
    ANSELH=%00000000   ' ADC OFF B
    ANSEL=%00000000 'configure PortA as digital except first 2
    ADCON1=%10000000  'adc justify
    OSCCON=%01110101  'SET FREQUENCY TO 8MHZ
    WPUB=%00000000    'turn off Pullups
    CM1CON0=0         'DISABLE COMPARATORS
    CM2CON0=0         'SAME HERE
    Define OSC 8 'Adjust consistent with oscillator speed being used
    ADCON1 = 7      ' Set PORTA and PORTE to digital
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 1500
    DEFINE LCD_DATAUS 44
    'clear
    I2CBufferSize  con 64
    Reg_Pointer	Var Byte 	 ; Address register
    I2CDATA		Var Byte 	 ; data to read/write
    I2CAddr		Var Byte 	 ; Device address
    I2C_Wait	     var byte
    countI2C	     var byte
    I2CWRBuff	     var byte (I2CBufferSize)
    I2CWRsize	     Var Byte
    I2CRDBuff	     var byte (I2CBufferSize)
    I2CRDsize	     Var Byte
    I2CErrCode     Var Byte
    I2CErrCode     = 0
    x var byte 'temp var
    SSPSTAT.7 = 0       ; SMP<7> - Slew rate control Enabled (400kHz)
    SSPCON = %00101000
              ; | ''''--  SSPM<3:0> - I2C Master mode, clock = FOSC / (4 * (SSPADD+1))
              ; '-------- SSPEN<5> - Synchronous Serial Port Enable bit
    SSPADD = $0E        ; set I2C clock rate to 400kHz
    'SSPADD = $59		; set I2C clock rate to 100kHz
    for x=0 to 255
    lcdout $fe, $2, "wait..."
    I2CAddr=x
    gosub read1byte
    lcdout $fe, $2, "data=", dec i2cdata
    next
    stop
    ; Main Routines
    Write1Byte:
         I2CErrCode.1 = 0
    	I2CAddr.0	=	0	;Set Write Bit
    	Gosub StartI2C      ;Send Start, Addr, Wait for Ack
    	if I2CErrCode.1	=	1 then RETURN
    		I2CDATA = I2CWRBuff(0)
    	gosub I2CWRByte	    ;Send I2CDATA Byte
    	Gosub SendStopBit	;Send Stop Bit
    WriteXBytes:
         I2CErrCode.1 = 0
    	For countI2C = 0 to I2CWRsize-1
    		I2CDATA = I2CWRBuff(countI2C)
    ;          hserout [dec countI2C,"-",ihex2 I2CDATA," ",13,10]
    	next countI2C
    Read1Byte:
         I2CErrCode.1 = 0
    	I2CAddr.0	=	1	;Set Read Bit
        gosub I2CRDByte
    	I2CRDBuff(0) = 	I2CDATA
        gosub Send_NO_Ack
        Gosub SendStopBit
    ReadXBytes:
         I2CErrCode.1 = 0
         for countI2C = 0 to I2CRDsize-2
              gosub I2CRDByte
              gosub Send_Ack
    		I2CRDBuff(countI2C) = 	I2CDATA
         next  countI2C
         countI2C = I2CRDsize - 1
         gosub I2CRDByte
         gosub Send_NO_ACK
         Gosub SendStopBit
    ; Process Routines
    StartI2C:
         ;Send Start Bit
         SSPCON2.0 = 1                 ; SEN<0> - Send start bit
         while SSPCON2.0 = 1 : wend    ; Wait for completion
         ;Send Slave Address
         PIR1.3 = 0                    ; SSPIF - Clear interrupt Flag
         SSPBUF = I2CAddr              ; move slave address to SSPBUF
         While PIR1.3 = 0 : Wend       ; SSPIF - Wait for SSP to complete sending slave address
         ;Wait for Acknowledge or Restart
         i2c_wait = 0                  ; Reset wait counter
         While SSPCON2.6 = 1           ; Wait for Acknowledge from slave  1=NotAck
              I2C_Wait = I2C_Wait + 1  ; Increment wait counter
              if I2C_Wait = 0 then     ; Wait for 256 counts
                   goto I2CResError    ; Acknowledge "Time Out" - Report error and RETURN
                   ; Send Repeated Start
                   SSPCON2.1 = 1       ; RSEN - Send Repeated Start
                   while SSPCON2.1 = 1 : wend    ; Wait for completion
                   ; Resend the Slave Address
                   While PIR1.3 = 0 : Wend       ; SSPIF - Wait to complete sending Slave Address
         wend
    I2CWRByte:
         ;Wait for Acknowledge or Abort
         wend
    I2CRDByte:
         While PIR1.3 = 0 : Wend       ; SSPIF - Wait for SSP to complete receiving
         I2CDATA = SSPBUF
    SendStopBit
    Send_NO_Ack:
    Send_Ack:
    I2CResError:
    	I2CErrCode.1	=	1
    	lcdout $fe, $2, "I2C Error!!!"
  1. I2C Master/Slave 16F88/16F767 working code
    By DanPBP in forum Code Examples
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    By Michael Wakileh in forum Code Examples
    Last Post: - 16th June 2009, 22:07
  3. I2C Master Slave issues.
    By cpayne in forum mel PIC BASIC Pro
    Last Post: - 29th March 2008, 20:33
  4. Hardware I2C
    By Kamikaze47 in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 14:24
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
