Presetting Configuration Fuses (PIC Defines) into your Program - Page 2
+ Reply to Thread
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 83
  1. #41
    Jul 2009
    Default Help in setting internal clock on 18F1220 device
    Hello
    I am new to this forum, I am a RF Engineer trying to use a 18F1220 with its internal oscillator. So far I have been unsucessfull in doing this. When using MPLAB and a IDC2 in debugger mode the Blink program works fine. When I program the device and run it on its own power it does not work. I think I traced it to the 18f1220.inc file, CONFIG1H fuse.
    ;* 18F1220.INC *
    ;* By : Leonard Zerman, Jeff Schmoyer *
    ;* Notice : Copyright (c) 2004 microEngineering Labs, Inc. *
    ;* All Rights Reserved *
    ;* Date : 01/27/04 *
    ;* Version : 2.45 *
    ;* Notes : *
    NOLIST
    ifdef PM_USED
    LIST
    "Error: PM does not support this device. Use MPASM."
    NOLIST
    LIST
    LIST p = 18F1220, r = dec, w = -311, f = inhx32
    INCLUDE "P18F1220.INC" ; MPASM Header
    __CONFIG _CONFIG1H, _XT_OSC_1H
    __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
    __CONFIG _CONFIG3H, _MCLRE_ON_3H
    __CONFIG _CONFIG4L, _LVP_OFF_4L
    NOLIST
    LIST
    EEPROM_START EQU 0F00000h
    BLOCK_SIZE EQU 8
    It sets the oscillator to External. I am not sure what the fuse should be set to. I also beleve the INTRC needs to be reconfigured for 8 MHz. Can anyone assist me? Thank You.
  2. #42
    Quote Originally Posted by wbubel View Post
    Hello
    ;* 18F1220.INC *
    ;* Version : 2.45 *
    ;* Notes : *
    NOLIST
    ifdef PM_USED
    LIST
    NOLIST
    LIST
    NOLIST
    LIST
    BLOCK_SIZE EQU 8
    Hello wbubel, Welcome !
    In the MPASM Suite each supported PIC has a file, named for it I. E. P18F1220.inc, in it is listed every valid config and register address. To switch to using MPASM, in MCS click view, compile and program options,click on the tab named assembler, and insert a check in the box "use MPASM", click OK and you are set. Here is what is available for config 1 . . .
    ;Configuration Byte 1H Options
    _IESO_ON_1H       EQU  H'FF' ; Internal External Oscillator Switch Over mode enabled
    _IESO_OFF_1H      EQU  H'7F' ; Internal External Oscillator Switch Over mode disabled
    _FSCM_ON_1H       EQU  H'FF' ; Fail-Safe Clock Monitor enabled
    _FSCM_OFF_1H      EQU  H'BF' ; Fail-Safe Clock Monitor disabled
    _RC_OSC_1H        EQU  H'FF' ; External RC on OSC1, OSC2 as FOSC/4
    _RCIO_OSC_1H      EQU  H'F7' ; External RC on OSC1, OSC2 as RA6
    _LP_OSC_1H        EQU  H'F0' ; LP Oscillator
    _XT_OSC_1H        EQU  H'F1' ; XT Oscillator
    _HS_OSC_1H        EQU  H'F2' ; HS Oscillator
    _HSPLL_OSC_1H     EQU  H'F6' ; HS + PLL
    _EC_OSC_1H        EQU  H'F4' ; External Clock on OSC1, OSC2 as FOSC/4
    _ECIO_OSC_1H      EQU  H'F5' ; External Clock on OSC1, OSC2 as RA6
    _INTIO1_OSC_1H    EQU  H'F9' ; Internal RC, OSC1 as RA7, OSC2 as FOSC/4
    _INTIO2_OSC_1H    EQU  H'F8' ; Internal RC, OSC1 as RA7, OSC2 as RA6
    You can change it in the file you posted or comment them out there and just add the ones you want at the top of your code (my preferred method). Most PICs you use DEFINE OSC 8 , but I won't say all . . .
  3. #43
    _INTIO2_OSC_1H would set it for internal osc with OSC1 & OSC2 pins free to use for I/O.
    Look in the P18F1220.INC file in your MPLAB directory for a list of config options.
    To select 8MHz internal, look in the 18F1220 data sheet in the Oscillator Configurations
    section. It shows the value to write to OSCCON to select various frequencies.
    When programming the PIC with the ICD, in inserts a debug kernel, so you may need to
    configure the ICD as the programmer before burning the PIC for stand-alone operation.
    With the ICD debug kernel programmed into the PIC it needs the PC interface to operate.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  4. #44
    Jul 2009
    Default Re:Help in setting internal clock on 18F1220 device
    Joe S. and Bruce
    Thanks for your valuable help. Sorry its been a while since I've been able to get back to this project. Here is the status. I have set the CONFIG1H fuse to
    _INTIO2_OSC_1H as Bruce suggested and OSCCON = %01110000.
    I set the ICD as a programmer. When I released the PIC from Reset it runs so slow I thought it was not working. Either I screwed up the OSCCON settings or there is something I am missing.
    OSCCON = %01110000 'Define the Osc to 8 MHz
    LED2 var PORTB.2 ' LED
    cntr var word
    FET var PORTA.0
    TRISA = %00000000 ' Set PORTA ports 0-4 to input, 5-7 Output
    TRISB = %00000000 ' Set PORTB to all output
    PORTB = %00000100 ' Clear PORTB
    PORTA = %00000000 ' Clear PORTA
    cntr = 0
    FET = 0
    led2 = 1
    led2 = 0
    ' cntr = cntr + 1
    ' if (cntr <= 2) then goto main
    ' FET = 1
    Stop
    Can anyone Help me.
  5. #45
    You should compile NOT using ICD COMPILE, use the one which says compile, only use ICD compile to use the ICD, recompile with the COMPILE for stand alone use. Put a
    or whatever number is right in you code near the top. The PIC is probably running using the fail safe oscillator .
  6. #46
    Jul 2009
    This piece of code made it work
    DEFINE OSC 4 'Define the Osc to 8 MHz
    asm
    bsf OSCCON, SCS1 ; 1x = Internal Block
    bcf OSCCON, SCS0 ; 00 = Primary Oscillator (20Mhz?)
    bsf OSCCON, IRCF2 ; 111=8000 110=4000 101=2000
    bsf OSCCON, IRCF1 ; 100=1000 011=0500 010=0250
    bcf OSCCON, IRCF0 ; 001=0125 000=0032
    MSTABLE010 btfss OSCCON, IOFS
    bra MSTABLE010 ; wait until Oscillator is stable
    endasm
  7. #47
    Feb 2008
    Michigan, USA
    Default Subtle differences in config
    This doesn't directly apply to your situation this time, but I did run into a sneaky change the other day that took me a while to notice..
    I was trying to change the oscillator config on a 18F1320. I had been recently using 18F1330s and just assumed they would be the same since they were so close family wise. Bad assumption. Here are the two together.
    ;*  18F1330.INC                                                 *
    ;*  Notice    : Copyright (c) 2006 microEngineering Labs, Inc.  *
    ;*  Date      : 06/05/06                                        *
    ;*  Version   : 2.47                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            NOLIST
            LIST
            LIST p = 18F1330, r = dec, w = -311, w = -230, f = inhx32
            INCLUDE "P18F1330.INC"  ; MPASM  Header
            __CONFIG    _CONFIG1H, _OSC_INTIO2_1H
           ; __CONFIG    _CONFIG1H, _OSC_XT_1H
            __CONFIG    _CONFIG4L, _XINST_OFF_4L
            NOLIST
            LIST
    BLOCK_SIZE	EQU	8
    ;*  18F1320.INC                                                 *
    ;*  Version   : 2.47                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            NOLIST
            LIST
            LIST p = 18F1320, r = dec, w = -311, w = -230, f = inhx32
            INCLUDE "P18F1320.INC"  ; MPASM  Header
            __CONFIG    _CONFIG1H, _INTIO2_OSC_1H    ; this for INT OSC
        ;   __CONFIG    _CONFIG1H, _XT_OSC_1H	 ;was this for XT OSC
            NOLIST
            LIST
    BLOCK_SIZE	EQU	8
    the commented out part was my addition, but notice the different syntax for the oscillator statement.
    Just hadn't run into that before.
    Bo
  8. #48
    Feb 2008
    Michigan, USA
    Default Can't find @MyConfig
    Hi all,
    I have tried to find where the @MyConfig references were without any success. Anyone have them bookmarked?
    I still don't have a good handle on changing these without tweaking the .inc files and I'm afraid that's going to bite me someday (even though I do leave the original lines REM'd).
    I have seen @MyConfig used, but don't know if there are any caveats.
    Bo
  9. #49
    Hi Bo,
    @__Config MyConfig was something Darrel came up with for me, so as to be able to put the config statements on several lines. This was so I could see them without having to scroll across some 100 or so places on the screen. I have MCS set up with large fonts as I have rather poor vision. You still have to comment out the default configs and place the correct configs in your code. It simply allows you to put them on multiple lines. Search for my posts and you will find examples of it's use. If you need examples I can post some Saturday after my new cable internet connection get's hooked up, until then I am not at home while in here.
    JS
  10. #50
    Omaha, Nebraska USA
    Okay, I've rummaged through the manual, looked at several old threads, and at the "include" files for the device (16F88). I've carefully read through Melanie's post on the subject http://www.picbasic.co.uk/forum/show...16&postcount=1
    Whatever occurs after @_config generates error 122 ("illegal opcode"). It also appears that _INTRC_IO doesn't want to fly. I'm using MPASM.
    Maybe I've not found the right thread yet.
    HELP!
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
  11. #51
    I don't think it's what's after it, it's the config...
    @ __config _CONFIG1, _xxxx
    That's @ space two(2) underscores config space "the _CONFIG? word" comma etc...
    Only 1 underscore for the config word and options.
    Omaha, Nebraska USA
    Yep, it was the double underscore. Then I commented out the line in the INC file, and everything is peachy-keeno.
    Thanks!
    Russ
  13. #53
    Feb 2010
    Default Setting config bits
    HI.
    WHAT DO YOU MEAN WITH THE FOLLOWING?
    don't forget to comment the PBP default fuse.
  14. #54
    Quote Originally Posted by brianD View Post
    HI.
    Did you read the whole thread???
  15. #55
    Default Newer 18F chips (18F26J50) without old style configs
    So I notice that some 18F chips have the old style configs like CONFIG1H, as well as the new style listed in their chipx.inc file. But other chips, like the 18F26J50 only have the new style, with no CONFIG1H style in the Microchip .inc file for that chip.
    I have read the configs have been depreciated posts, where Darrel says ignore the warnings, they are just that ... warnings. However, with newer chips like the PIC18F26J50, is there a way to get around the error:
    Error[176]c:\picbasic\26j50-~.asm 101 :CONFIG Directive Error: (setting "48" not found for the processor 18F26J50) ? It seems so close, to only be held up by defining the oscillator!
    I get the above error when I try to use :
    DEFINE OSC 48
       CONFIG OSC=HSPLL
       CONFIG CPUDIV=OSC1
       CONFIG PLLDIV=5
       CONFIG LPT1OSC=OFF
       CONFIG CP0=OFF
       CONFIG WDTEN=ON
       CONFIG XINST=OFF
       CONFIG IOL1WAY=OFF
       CONFIG STVREN=OFF
       CONFIG T1DIG=ON
       CONFIG FCMEN=OFF
       CONFIG WDTPS=512
       CONFIG RTCOSC=T1OSCREF
    If I comment out the DEFINE OSC 48, all appears good. If I try to define the OSC setting, I get the 176 error.
    ..there are no CONFIG1H's here...
    ;   IMPORTANT: For the PIC18 devices, the __CONFIG directive has been
    ;              superseded by the CONFIG directive.  The following settings
    ;              are available for this device.
    ;   Watchdog Timer:
    ;     WDTEN = OFF          Disabled - Controlled by SWDTEN bit
    ;     WDTEN = ON           Enabled
    ;   PLL Prescaler Selection bits:
    ;     PLLDIV = 12          Divide by 12 (48 MHz oscillator input)
    ;     PLLDIV = 10          Divide by 10 (40 MHz oscillator input)
    ;     PLLDIV = 6           Divide by 6 (24 MHz oscillator input)
    ;     PLLDIV = 5           Divide by 5 (20 MHz oscillator input)
    ;     PLLDIV = 4           Divide by 4 (16 MHz oscillator input)
    ;     PLLDIV = 3           Divide by 3 (12 MHz oscillator input)
    ;     PLLDIV = 2           Divide by 2 (8 MHz oscillator input)
    ;     PLLDIV = 1           No prescale (4 MHz oscillator input drives PLL directly)
    ;   Stack Overflow/Underflow Reset :
    ;     STVREN = OFF         Disabled
    ;     STVREN = ON          Enabled
    ;   Extended Instruction Set:
    ;     XINST = OFF          Disabled
    ;     XINST = ON           Enabled
    ;   CPU System Clock Postscaler:
    ;     CPUDIV = OSC4_PLL6   CPU system clock divide by 6
    ;     CPUDIV = OSC3_PLL3   CPU system clock divide by 3
    ;     CPUDIV = OSC2_PLL2   CPU system clock divide by 2
    ;     CPUDIV = OSC1        No CPU system clock divide
    ;   Code Protect:
    ;     CP0 = ON             Program memory is code-protected
    ;     CP0 = OFF            Program memory is not code-protected
    ;   Oscillator:
    ;     OSC = INTOSC         INTOSC
    ;     OSC = INTOSCO        INTOSCO (CLKO-RA6)
    ;     OSC = INTOSCPLL      INTOSCPLL
    ;     OSC = INTOSCPLLO     INTOSCPLLO (CLKO-RA6)
    ;     OSC = HS             HS, USB-HS
    ;     OSC = HSPLL          HS+PLL, USB-HS+PLL
    ;     OSC = EC             EC (CLKO-RA6), USB-EC
    ;     OSC = ECPLL          EC+PLL (CLKO-RA6), USB-EC+PLL
    ;   T1OSCEN Enforcement:
    ;     T1DIG = OFF          Secondary Oscillator clock source may not be selected
    ;     T1DIG = ON           Secondary Oscillator clock source may be selected
    ;   Low-Power Timer1 Oscillator:
    ;     LPT1OSC = ON         Low-power operation
    ;     LPT1OSC = OFF        High-power operation
    ;   Fail-Safe Clock Monitor:
    ;     FCMEN = OFF          Disabled
    ;     FCMEN = ON           Enabled
    ;   Internal External Oscillator Switch Over Mode:
    ;     IESO = OFF           Disabled
    ;     IESO = ON            Enabled
    ;   Watchdog Postscaler:
    ;     WDTPS = 1            1:1
    ;     WDTPS = 2            1:2
    ;     WDTPS = 4            1:4
    ;     WDTPS = 8            1:8
    ;     WDTPS = 16           1:16
    ;     WDTPS = 32           1:32
    ;     WDTPS = 64           1:64
    ;     WDTPS = 128          1:128
    ;     WDTPS = 256          1:256
    ;     WDTPS = 512          1:512
    ;     WDTPS = 1024         1:1024
    ;     WDTPS = 2048         1:2048
    ;     WDTPS = 4096         1:4096
    ;     WDTPS = 8192         1:8192
    ;     WDTPS = 16384        1:16384
    ;     WDTPS = 32768        1:32768
    ;   DSWDT Clock Select:
    ;     DSWDTOSC = T1OSCREF  DSWDT uses T1OSC/T1CKI
    ;     DSWDTOSC = INTOSCREF DSWDT uses INTRC
    ;   RTCC Clock Select:
    ;     RTCOSC = INTOSCREF   RTCC uses INTRC
    ;     RTCOSC = T1OSCREF    RTCC uses T1OSC/T1CKI
    ;   Deep Sleep BOR:
    ;     DSBOREN = OFF        Disabled
    ;     DSBOREN = ON         Enabled
    ;   Deep Sleep Watchdog Timer:
    ;     DSWDTEN = OFF        Disabled
    ;     DSWDTEN = ON         Enabled
    ;   Deep Sleep Watchdog Postscaler:
    ;     DSWDTPS = 2          1:2 (2.1 ms)
    ;     DSWDTPS = 8          1:8 (8.3 ms)
    ;     DSWDTPS = 32         1:32 (33 ms)
    ;     DSWDTPS = 128        1:128 (132 ms)
    ;     DSWDTPS = 512        1:512 (528 ms)
    ;     DSWDTPS = 2048       1:2,048 (2.1 seconds)
    ;     DSWDTPS = 8192       1:8,192 (8.5 seconds)
    ;     DSWDTPS = K32        1:32,768 (34 seconds)
    ;     DSWDTPS = K131       1:131,072 (135 seconds)
    ;     DSWDTPS = K524       1:524,288 (9 minutes)
    ;     DSWDTPS = M2         1:2,097,152 (36 minutes)
    ;     DSWDTPS = M8         1:8,388,608 (2.4 hours)
    ;     DSWDTPS = M33        1:33,554,432 (9.6 hours)
    ;     DSWDTPS = M134       1:134,217,728 (38.5 hours)
    ;     DSWDTPS = M536       1:536,870,912 (6.4 days)
    ;     DSWDTPS = G2         1:2,147,483,648 (25.7 days)
    ;   IOLOCK One-Way Set Enable bit:
    ;     IOL1WAY = OFF        The IOLOCK bit (PPSCON<0>) can be set and cleared as needed
    ;     IOL1WAY = ON         The IOLOCK bit (PPSCON<0>) can be set once
    ;   MSSP address masking:
    ;     MSSP7B_EN = MSK5     5 Bit address masking mode
    ;     MSSP7B_EN = MSK7     7 Bit address masking mode
    ;   Write/Erase Protect Page Start/End Location:
    ;     WPFP = PAGE_0        Write Protect Program Flash Page 0
    ;     WPFP = PAGE_1        Write Protect Program Flash Page 1
    ;     WPFP = PAGE_2        Write Protect Program Flash Page 2
    ;     WPFP = PAGE_3        Write Protect Program Flash Page 3
    ;     WPFP = PAGE_4        Write Protect Program Flash Page 4
    ;     WPFP = PAGE_5        Write Protect Program Flash Page 5
    ;     WPFP = PAGE_6        Write Protect Program Flash Page 6
    ;     WPFP = PAGE_7        Write Protect Program Flash Page 7
    ;     WPFP = PAGE_8        Write Protect Program Flash Page 8
    ;     WPFP = PAGE_9        Write Protect Program Flash Page 9
    ;     WPFP = PAGE_10       Write Protect Program Flash Page 10
    ;     WPFP = PAGE_11       Write Protect Program Flash Page 11
    ;     WPFP = PAGE_12       Write Protect Program Flash Page 12
    ;     WPFP = PAGE_13       Write Protect Program Flash Page 13
    ;     WPFP = PAGE_14       Write Protect Program Flash Page 14
    ;     WPFP = PAGE_15       Write Protect Program Flash Page 15
    ;     WPFP = PAGE_16       Write Protect Program Flash Page 16
    ;     WPFP = PAGE_17       Write Protect Program Flash Page 17
    ;     WPFP = PAGE_18       Write Protect Program Flash Page 18
    ;     WPFP = PAGE_19       Write Protect Program Flash Page 19
    ;     WPFP = PAGE_20       Write Protect Program Flash Page 20
    ;     WPFP = PAGE_21       Write Protect Program Flash Page 21
    ;     WPFP = PAGE_22       Write Protect Program Flash Page 22
    ;     WPFP = PAGE_23       Write Protect Program Flash Page 23
    ;     WPFP = PAGE_24       Write Protect Program Flash Page 24
    ;     WPFP = PAGE_25       Write Protect Program Flash Page 25
    ;     WPFP = PAGE_26       Write Protect Program Flash Page 26
    ;     WPFP = PAGE_27       Write Protect Program Flash Page 27
    ;     WPFP = PAGE_28       Write Protect Program Flash Page 28
    ;     WPFP = PAGE_29       Write Protect Program Flash Page 29
    ;     WPFP = PAGE_30       Write Protect Program Flash Page 30
    ;     WPFP = PAGE_31       Write Protect Program Flash Page 31
    ;     WPFP = PAGE_32       Write Protect Program Flash Page 32
    ;     WPFP = PAGE_33       Write Protect Program Flash Page 33
    ;     WPFP = PAGE_34       Write Protect Program Flash Page 34
    ;     WPFP = PAGE_35       Write Protect Program Flash Page 35
    ;     WPFP = PAGE_36       Write Protect Program Flash Page 36
    ;     WPFP = PAGE_37       Write Protect Program Flash Page 37
    ;     WPFP = PAGE_38       Write Protect Program Flash Page 38
    ;     WPFP = PAGE_39       Write Protect Program Flash Page 39
    ;     WPFP = PAGE_40       Write Protect Program Flash Page 40
    ;     WPFP = PAGE_41       Write Protect Program Flash Page 41
    ;     WPFP = PAGE_42       Write Protect Program Flash Page 42
    ;     WPFP = PAGE_43       Write Protect Program Flash Page 43
    ;     WPFP = PAGE_44       Write Protect Program Flash Page 44
    ;     WPFP = PAGE_45       Write Protect Program Flash Page 45
    ;     WPFP = PAGE_46       Write Protect Program Flash Page 46
    ;     WPFP = PAGE_47       Write Protect Program Flash Page 47
    ;     WPFP = PAGE_48       Write Protect Program Flash Page 48
    ;     WPFP = PAGE_49       Write Protect Program Flash Page 49
    ;     WPFP = PAGE_50       Write Protect Program Flash Page 50
    ;     WPFP = PAGE_51       Write Protect Program Flash Page 51
    ;     WPFP = PAGE_52       Write Protect Program Flash Page 52
    ;     WPFP = PAGE_53       Write Protect Program Flash Page 53
    ;     WPFP = PAGE_54       Write Protect Program Flash Page 54
    ;     WPFP = PAGE_55       Write Protect Program Flash Page 55
    ;     WPFP = PAGE_56       Write Protect Program Flash Page 56
    ;     WPFP = PAGE_57       Write Protect Program Flash Page 57
    ;     WPFP = PAGE_58       Write Protect Program Flash Page 58
    ;     WPFP = PAGE_59       Write Protect Program Flash Page 59
    ;     WPFP = PAGE_60       Write Protect Program Flash Page 60
    ;     WPFP = PAGE_61       Write Protect Program Flash Page 61
    ;     WPFP = PAGE_62       Write Protect Program Flash Page 62
    ;     WPFP = PAGE_63       Write Protect Program Flash Page 63
    ;   Write/Erase Protect Region Select bit (valid when WPDIS = 0):
    ;     WPEND = PAGE_0       Page 0 to WPFP<5:0> erase/write-protected
    ;     WPEND = PAGE_WPFP    Pages WPFP<5:0> to (Configuration Words page) write/erase protected
    ;   Write/Erase Protect Configuration Region :
    ;     WPCFG = ON           Configuration Words page erase/write-protected
    ;     WPCFG = OFF          Configuration Words page not erase/write-protected
    ;   Write Protect Disable bit:
    ;     WPDIS = ON           WPFP[5:0], WPEND, and WPCFG bits enabled
    ;     WPDIS = OFF          WPFP[5:0], WPEND, and WPCFG bits ignored
    _DEVID1          EQU  H'3FFFFE'
    _DEVID2          EQU  H'3FFFFF'
    Is the only solution is to edit all configs in the PBP include file, or am I missing something. If this has already been covered, let me have it....
    I notice that the 18F4550 has both styles in it's include file, like this:
    ;     CPUDIV = OSC1_PLL2   [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2]
    ;     CPUDIV = OSC2_PLL3   [OSC1/OSC2 Src: /2][96 MHz PLL Src: /3]
    ;     CPUDIV = OSC3_PLL4   [OSC1/OSC2 Src: /3][96 MHz PLL Src: /4]
    ;     CPUDIV = OSC4_PLL6   [OSC1/OSC2 Src: /4][96 MHz PLL Src: /6]
    ;   USB Clock Selection bit (used in Full Speed USB mode only; UCFG:FSEN = 1):
    ;     USBDIV = 1           USB clock source comes directly from the primary oscillator block with no postscale
    ;     USBDIV = 2           USB clock source comes from the 96 MHz PLL divided by 2
    ;   Oscillator Selection bits:
    ;     FOSC = XT_XT         XT oscillator, XT used by USB
    ;     FOSC = XTPLL_XT      XT oscillator, PLL enabled, XT used by USB
    ;     FOSC = ECIO_EC       External clock, port function on RA6, EC used by USB
    ;     FOSC = EC_EC         External clock, CLKOUT on RA6, EC used by USB
    ;     FOSC = ECPLLIO_EC    External clock, PLL enabled, port function on RA6, EC used by USB
    ;     FOSC = ECPLL_EC      External clock, PLL enabled, CLKOUT on RA6, EC used by USB
    ;     FOSC = INTOSCIO_EC   Internal oscillator, port function on RA6, EC used by USB
    ;     FOSC = INTOSC_EC     Internal oscillator, CLKOUT on RA6, EC used by USB
    ;     FOSC = INTOSC_XT     Internal oscillator, XT used by USB
    ;     FOSC = INTOSC_HS     Internal oscillator, HS used by USB
    ;     FOSC = HS            HS oscillator, HS used by USB
    ;     FOSC = HSPLL_HS      HS oscillator, PLL enabled, HS used by USB
    ;   Fail-Safe Clock Monitor Enable bit:
    ;     FCMEN = OFF          Fail-Safe Clock Monitor disabled
    ;     FCMEN = ON           Fail-Safe Clock Monitor enabled
    ;   Internal/External Oscillator Switchover bit:
    ;     IESO = OFF           Oscillator Switchover mode disabled
    ;     IESO = ON            Oscillator Switchover mode enabled
    ;   Power-up Timer Enable bit:
    ;     PWRT = ON            PWRT enabled
    ;     PWRT = OFF           PWRT disabled
    ;   Brown-out Reset Enable bits:
    ;     BOR = OFF            Brown-out Reset disabled in hardware and software
    ;     BOR = SOFT           Brown-out Reset enabled and controlled by software (SBOREN is enabled)
    ;     BOR = ON_ACTIVE      Brown-out Reset enabled in hardware only and disabled in Sleep mode (SBOREN is disabled)
    ;     BOR = ON             Brown-out Reset enabled in hardware only (SBOREN is disabled)
    ;   Brown-out Voltage bits:
    ;     BORV = 0             Maximum setting
    ;     BORV = 1
    ;     BORV = 2
    ;     BORV = 3             Minimum setting
    ;   USB Voltage Regulator Enable bit:
    ;     VREGEN = OFF         USB voltage regulator disabled
    ;     VREGEN = ON          USB voltage regulator enabled
    ;   Watchdog Timer Enable bit:
    ;     WDT = OFF            HW Disabled - SW Controlled
    ;     WDT = ON             HW Enabled - SW Disabled
    ;   Watchdog Timer Postscale Select bits:
    ;     WDTPS = 1            1:1
    ;     WDTPS = 2            1:2
    ;     WDTPS = 4            1:4
    ;     WDTPS = 8            1:8
    ;     WDTPS = 16           1:16
    ;     WDTPS = 32           1:32
    ;     WDTPS = 64           1:64
    ;     WDTPS = 128          1:128
    ;     WDTPS = 256          1:256
    ;     WDTPS = 512          1:512
    ;   MCLR Pin Enable bit:
    ;     MCLRE = OFF          RE3 input pin enabled; MCLR disabled
    ;     MCLRE = ON           MCLR pin enabled; RE3 input pin disabled
    ;   Low-Power Timer 1 Oscillator Enable bit:
    ;     LPT1OSC = OFF        Timer1 configured for higher power operation
    ;     LPT1OSC = ON         Timer1 configured for low-power operation
    ;   PORTB A/D Enable bit:
    ;     PBADEN = OFF         PORTB<4:0> pins are configured as digital I/O on Reset
    ;     PBADEN = ON          PORTB<4:0> pins are configured as analog input channels on Reset
    ;   CCP2 MUX bit:
    ;     CCP2MX = OFF         CCP2 input/output is multiplexed with RB3
    ;     CCP2MX = ON          CCP2 input/output is multiplexed with RC1
    ;   Stack Full/Underflow Reset Enable bit:
    ;     STVREN = OFF         Stack full/underflow will not cause Reset
    ;     STVREN = ON          Stack full/underflow will cause Reset
    ;   Single-Supply ICSP Enable bit:
    ;     LVP = OFF            Single-Supply ICSP disabled
    ;     LVP = ON             Single-Supply ICSP enabled
    ;   Dedicated In-Circuit Debug/Programming Port (ICPORT) Enable bit:
    ;     ICPRT = OFF          ICPORT disabled
    ;     ICPRT = ON           ICPORT enabled
    ;   Extended Instruction Set Enable bit:
    ;     XINST = OFF          Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
    ;     XINST = ON           Instruction set extension and Indexed Addressing mode enabled
    ;   Background Debugger Enable bit:
    ;     DEBUG = ON           Background debugger enabled, RB6 and RB7 are dedicated to In-Circuit Debug
    ;     DEBUG = OFF          Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
    ;   Code Protection bit Block 0:
    ;     CP0 = ON             Block 0 (000800-001FFFh) code-protected
    ;     CP0 = OFF            Block 0 (000800-001FFFh) not code-protected
    ;   Code Protection bit Block 1:
    ;     CP1 = ON             Block 1 (002000-003FFFh) code-protected
    ;     CP1 = OFF            Block 1 (002000-003FFFh) not code-protected
    ;   Code Protection bit Block 2:
    ;     CP2 = ON             Block 2 (004000-005FFFh) code-protected
    ;     CP2 = OFF            Block 2 (004000-005FFFh) not code-protected
    ;   Code Protection bit Block 3:
    ;     CP3 = ON             Block 3 (006000-007FFFh) code-protected
    ;     CP3 = OFF            Block 3 (006000-007FFFh) not code-protected
    ;   Boot Block Code Protection bit:
    ;     CPB = ON             Boot block (000000-0007FFh) code-protected
    ;     CPB = OFF            Boot block (000000-0007FFh) not code-protected
    ;   Data EEPROM Code Protection bit:
    ;     CPD = ON             Data EEPROM code-protected
    ;     CPD = OFF            Data EEPROM not code-protected
    ;   Write Protection bit Block 0:
    ;     WRT0 = ON            Block 0 (000800-001FFFh) write-protected
    ;     WRT0 = OFF           Block 0 (000800-001FFFh) not write-protected
    ;   Write Protection bit Block 1:
    ;     WRT1 = ON            Block 1 (002000-003FFFh) write-protected
    ;     WRT1 = OFF           Block 1 (002000-003FFFh) not write-protected
    ;   Write Protection bit Block 2:
    ;     WRT2 = ON            Block 2 (004000-005FFFh) write-protected
    ;     WRT2 = OFF           Block 2 (004000-005FFFh) not write-protected
    ;   Write Protection bit Block 3:
    ;     WRT3 = ON            Block 3 (006000-007FFFh) write-protected
    ;     WRT3 = OFF           Block 3 (006000-007FFFh) not write-protected
    ;   Boot Block Write Protection bit:
    ;     WRTB = ON            Boot block (000000-0007FFh) write-protected
    ;     WRTB = OFF           Boot block (000000-0007FFh) not write-protected
    ;   Configuration Register Write Protection bit:
    ;     WRTC = ON            Configuration registers (300000-3000FFh) write-protected
    ;     WRTC = OFF           Configuration registers (300000-3000FFh) not write-protected
    ;   Data EEPROM Write Protection bit:
    ;     WRTD = ON            Data EEPROM write-protected
    ;     WRTD = OFF           Data EEPROM not write-protected
    ;   Table Read Protection bit Block 0:
    ;     EBTR0 = ON           Block 0 (000800-001FFFh) protected from table reads executed in other blocks
    ;     EBTR0 = OFF          Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
    ;   Table Read Protection bit Block 1:
    ;     EBTR1 = ON           Block 1 (002000-003FFFh) protected from table reads executed in other blocks
    ;     EBTR1 = OFF          Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
    ;   Table Read Protection bit Block 2:
    ;     EBTR2 = ON           Block 2 (004000-005FFFh) protected from table reads executed in other blocks
    ;     EBTR2 = OFF          Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
    ;   Table Read Protection bit Block 3:
    ;     EBTR3 = ON           Block 3 (006000-007FFFh) protected from table reads executed in other blocks
    ;     EBTR3 = OFF          Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
    ;   Boot Block Table Read Protection:
    ;     EBTRB = ON           Boot block (000000-0007FFh) protected from table reads executed in other blocks
    ;     EBTRB = OFF          Boot block (000000-0007FFh) not protected from table reads executed in other blocks
    ;       Configuration Bits
    ;   NAME            Address
    ;   CONFIG1L        300000h
    ;   CONFIG1H        300001h
    ;   CONFIG2L        300002h
    ;   CONFIG2H        300003h
    ;   CONFIG3H        300005h
    ;   CONFIG4L        300006h
    ;   CONFIG5L        300008h
    ;   CONFIG5H        300009h
    ;   CONFIG6L        30000Ah
    ;   CONFIG6H        30000Bh
    ;   CONFIG7L        30000Ch
    ;   CONFIG7H        30000Dh
    ; The following is an assignment of address values for all of the
    ; configuration registers for the purpose of table reads
    _CONFIG1L        EQU  H'300000'
    _CONFIG1H        EQU  H'300001'
    _CONFIG2L        EQU  H'300002'
    _CONFIG2H        EQU  H'300003'
    _CONFIG3H        EQU  H'300005'
    _CONFIG4L        EQU  H'300006'
    _CONFIG5L        EQU  H'300008'
    _CONFIG5H        EQU  H'300009'
    _CONFIG6L        EQU  H'30000A'
    _CONFIG6H        EQU  H'30000B'
    _CONFIG7L        EQU  H'30000C'
    _CONFIG7H        EQU  H'30000D'
    ;----- CONFIG1L Options --------------------------------------------------
    _PLLDIV_1_1L         EQU  H'F8'    ; No prescale (4 MHz oscillator input drives PLL directly)
    _PLLDIV_2_1L         EQU  H'F9'    ; Divide by 2 (8 MHz oscillator input)
    _PLLDIV_3_1L         EQU  H'FA'    ; Divide by 3 (12 MHz oscillator input)
    _PLLDIV_4_1L         EQU  H'FB'    ; Divide by 4 (16 MHz oscillator input)
    _PLLDIV_5_1L         EQU  H'FC'    ; Divide by 5 (20 MHz oscillator input)
    _PLLDIV_6_1L         EQU  H'FD'    ; Divide by 6 (24 MHz oscillator input)
    _PLLDIV_10_1L        EQU  H'FE'    ; Divide by 10 (40 MHz oscillator input)
    _PLLDIV_12_1L        EQU  H'FF'    ; Divide by 12 (48 MHz oscillator input)
    _CPUDIV_OSC1_PLL2_1L EQU  H'E7'    ; [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2]
    _CPUDIV_OSC2_PLL3_1L EQU  H'EF'    ; [OSC1/OSC2 Src: /2][96 MHz PLL Src: /3]
    _CPUDIV_OSC3_PLL4_1L EQU  H'F7'    ; [OSC1/OSC2 Src: /3][96 MHz PLL Src: /4]
    _CPUDIV_OSC4_PLL6_1L EQU  H'FF'    ; [OSC1/OSC2 Src: /4][96 MHz PLL Src: /6]
    _USBDIV_1_1L         EQU  H'DF'    ; USB clock source comes directly from the primary oscillator block with no postscale
    _USBDIV_2_1L         EQU  H'FF'    ; USB clock source comes from the 96 MHz PLL divided by 2
    ;----- CONFIG1H Options --------------------------------------------------
    _FOSC_XT_XT_1H       EQU  H'F0'    ; XT oscillator, XT used by USB
    _FOSC_XTPLL_XT_1H    EQU  H'F2'    ; XT oscillator, PLL enabled, XT used by USB
    _FOSC_ECIO_EC_1H     EQU  H'F4'    ; External clock, port function on RA6, EC used by USB
    _FOSC_EC_EC_1H       EQU  H'F5'    ; External clock, CLKOUT on RA6, EC used by USB
    _FOSC_ECPLLIO_EC_1H  EQU  H'F6'    ; External clock, PLL enabled, port function on RA6, EC used by USB
    _FOSC_ECPLL_EC_1H    EQU  H'F7'    ; External clock, PLL enabled, CLKOUT on RA6, EC used by USB
    _FOSC_INTOSCIO_EC_1H EQU  H'F8'    ; Internal oscillator, port function on RA6, EC used by USB
    _FOSC_INTOSC_EC_1H   EQU  H'F9'    ; Internal oscillator, CLKOUT on RA6, EC used by USB
    _FOSC_INTOSC_XT_1H   EQU  H'FA'    ; Internal oscillator, XT used by USB
    _FOSC_INTOSC_HS_1H   EQU  H'FB'    ; Internal oscillator, HS used by USB
    _FOSC_HS_1H          EQU  H'FC'    ; HS oscillator, HS used by USB
    _FOSC_HSPLL_HS_1H    EQU  H'FE'    ; HS oscillator, PLL enabled, HS used by USB
    _FCMEN_OFF_1H        EQU  H'BF'    ; Fail-Safe Clock Monitor disabled
    _FCMEN_ON_1H         EQU  H'FF'    ; Fail-Safe Clock Monitor enabled
    _IESO_OFF_1H         EQU  H'7F'    ; Oscillator Switchover mode disabled
    _IESO_ON_1H          EQU  H'FF'    ; Oscillator Switchover mode enabled
    ;----- CONFIG2L Options --------------------------------------------------
    _PWRT_ON_2L          EQU  H'FE'    ; PWRT enabled
    _PWRT_OFF_2L         EQU  H'FF'    ; PWRT disabled
    _BOR_OFF_2L          EQU  H'F9'    ; Brown-out Reset disabled in hardware and software
    _BOR_SOFT_2L         EQU  H'FB'    ; Brown-out Reset enabled and controlled by software (SBOREN is enabled)
    _BOR_ON_ACTIVE_2L    EQU  H'FD'    ; Brown-out Reset enabled in hardware only and disabled in Sleep mode (SBOREN is disabled)
    _BOR_ON_2L           EQU  H'FF'    ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
    _BORV_0_2L           EQU  H'E7'    ; Maximum setting
    _BORV_1_2L           EQU  H'EF'    ;
    _BORV_2_2L           EQU  H'F7'    ;
    _BORV_3_2L           EQU  H'FF'    ; Minimum setting
    _VREGEN_OFF_2L       EQU  H'DF'    ; USB voltage regulator disabled
    _VREGEN_ON_2L        EQU  H'FF'    ; USB voltage regulator enabled
    ;----- CONFIG2H Options --------------------------------------------------
    _WDT_OFF_2H          EQU  H'FE'    ; HW Disabled - SW Controlled
    _WDT_ON_2H           EQU  H'FF'    ; HW Enabled - SW Disabled
    _WDTPS_1_2H          EQU  H'E1'    ; 1:1
    _WDTPS_2_2H          EQU  H'E3'    ; 1:2
    _WDTPS_4_2H          EQU  H'E5'    ; 1:4
    _WDTPS_8_2H          EQU  H'E7'    ; 1:8
    _WDTPS_16_2H         EQU  H'E9'    ; 1:16
    _WDTPS_32_2H         EQU  H'EB'    ; 1:32
    _WDTPS_64_2H         EQU  H'ED'    ; 1:64
    _WDTPS_128_2H        EQU  H'EF'    ; 1:128
    _WDTPS_256_2H        EQU  H'F1'    ; 1:256
    _WDTPS_512_2H        EQU  H'F3'    ; 1:512
    _WDTPS_1024_2H       EQU  H'F5'    ; 1:1024
    _WDTPS_2048_2H       EQU  H'F7'    ; 1:2048
    _WDTPS_4096_2H       EQU  H'F9'    ; 1:4096
    _WDTPS_8192_2H       EQU  H'FB'    ; 1:8192
    _WDTPS_16384_2H      EQU  H'FD'    ; 1:16384
    _WDTPS_32768_2H      EQU  H'FF'    ; 1:32768
    ;----- CONFIG3H Options --------------------------------------------------
    _MCLRE_OFF_3H        EQU  H'7F'    ; RE3 input pin enabled; MCLR disabled
    _MCLRE_ON_3H         EQU  H'FF'    ; MCLR pin enabled; RE3 input pin disabled
    _LPT1OSC_OFF_3H      EQU  H'FB'    ; Timer1 configured for higher power operation
    _LPT1OSC_ON_3H       EQU  H'FF'    ; Timer1 configured for low-power operation
    _PBADEN_OFF_3H       EQU  H'FD'    ; PORTB<4:0> pins are configured as digital I/O on Reset
    _PBADEN_ON_3H        EQU  H'FF'    ; PORTB<4:0> pins are configured as analog input channels on Reset
    _CCP2MX_OFF_3H       EQU  H'FE'    ; CCP2 input/output is multiplexed with RB3
    _CCP2MX_ON_3H        EQU  H'FF'    ; CCP2 input/output is multiplexed with RC1
    ;----- CONFIG4L Options --------------------------------------------------
    _STVREN_OFF_4L       EQU  H'FE'    ; Stack full/underflow will not cause Reset
    _STVREN_ON_4L        EQU  H'FF'    ; Stack full/underflow will cause Reset
    _LVP_OFF_4L          EQU  H'FB'    ; Single-Supply ICSP disabled
    _LVP_ON_4L           EQU  H'FF'    ; Single-Supply ICSP enabled
    _ICPRT_OFF_4L        EQU  H'DF'    ; ICPORT disabled
    _ICPRT_ON_4L         EQU  H'FF'    ; ICPORT enabled
    _XINST_OFF_4L        EQU  H'BF'    ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
    _XINST_ON_4L         EQU  H'FF'    ; Instruction set extension and Indexed Addressing mode enabled
    _DEBUG_ON_4L         EQU  H'7F'    ; Background debugger enabled, RB6 and RB7 are dedicated to In-Circuit Debug
    _DEBUG_OFF_4L        EQU  H'FF'    ; Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
    ;----- CONFIG5L Options --------------------------------------------------
    _CP0_ON_5L           EQU  H'FE'    ; Block 0 (000800-001FFFh) code-protected
    _CP0_OFF_5L          EQU  H'FF'    ; Block 0 (000800-001FFFh) not code-protected
    _CP1_ON_5L           EQU  H'FD'    ; Block 1 (002000-003FFFh) code-protected
    _CP1_OFF_5L          EQU  H'FF'    ; Block 1 (002000-003FFFh) not code-protected
    _CP2_ON_5L           EQU  H'FB'    ; Block 2 (004000-005FFFh) code-protected
    _CP2_OFF_5L          EQU  H'FF'    ; Block 2 (004000-005FFFh) not code-protected
    _CP3_ON_5L           EQU  H'F7'    ; Block 3 (006000-007FFFh) code-protected
    _CP3_OFF_5L          EQU  H'FF'    ; Block 3 (006000-007FFFh) not code-protected
    ;----- CONFIG5H Options --------------------------------------------------
    _CPB_ON_5H           EQU  H'BF'    ; Boot block (000000-0007FFh) code-protected
    _CPB_OFF_5H          EQU  H'FF'    ; Boot block (000000-0007FFh) not code-protected
    _CPD_ON_5H           EQU  H'7F'    ; Data EEPROM code-protected
    _CPD_OFF_5H          EQU  H'FF'    ; Data EEPROM not code-protected
    ;----- CONFIG6L Options --------------------------------------------------
    _WRT0_ON_6L          EQU  H'FE'    ; Block 0 (000800-001FFFh) write-protected
    _WRT0_OFF_6L         EQU  H'FF'    ; Block 0 (000800-001FFFh) not write-protected
    _WRT1_ON_6L          EQU  H'FD'    ; Block 1 (002000-003FFFh) write-protected
    _WRT1_OFF_6L         EQU  H'FF'    ; Block 1 (002000-003FFFh) not write-protected
    _WRT2_ON_6L          EQU  H'FB'    ; Block 2 (004000-005FFFh) write-protected
    _WRT2_OFF_6L         EQU  H'FF'    ; Block 2 (004000-005FFFh) not write-protected
    _WRT3_ON_6L          EQU  H'F7'    ; Block 3 (006000-007FFFh) write-protected
    _WRT3_OFF_6L         EQU  H'FF'    ; Block 3 (006000-007FFFh) not write-protected
    ;----- CONFIG6H Options --------------------------------------------------
    _WRTB_ON_6H          EQU  H'BF'    ; Boot block (000000-0007FFh) write-protected
    _WRTB_OFF_6H         EQU  H'FF'    ; Boot block (000000-0007FFh) not write-protected
    _WRTC_ON_6H          EQU  H'DF'    ; Configuration registers (300000-3000FFh) write-protected
    _WRTC_OFF_6H         EQU  H'FF'    ; Configuration registers (300000-3000FFh) not write-protected
    _WRTD_ON_6H          EQU  H'7F'    ; Data EEPROM write-protected
    _WRTD_OFF_6H         EQU  H'FF'    ; Data EEPROM not write-protected
    ;----- CONFIG7L Options --------------------------------------------------
    _EBTR0_ON_7L         EQU  H'FE'    ; Block 0 (000800-001FFFh) protected from table reads executed in other blocks
    _EBTR0_OFF_7L        EQU  H'FF'    ; Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
    _EBTR1_ON_7L         EQU  H'FD'    ; Block 1 (002000-003FFFh) protected from table reads executed in other blocks
    _EBTR1_OFF_7L        EQU  H'FF'    ; Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
    _EBTR2_ON_7L         EQU  H'FB'    ; Block 2 (004000-005FFFh) protected from table reads executed in other blocks
    _EBTR2_OFF_7L        EQU  H'FF'    ; Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
    _EBTR3_ON_7L         EQU  H'F7'    ; Block 3 (006000-007FFFh) protected from table reads executed in other blocks
    _EBTR3_OFF_7L        EQU  H'FF'    ; Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
    ;----- CONFIG7H Options --------------------------------------------------
    _EBTRB_ON_7H         EQU  H'BF'    ; Boot block (000000-0007FFh) protected from table reads executed in other blocks
    _EBTRB_OFF_7H        EQU  H'FF'    ; Boot block (000000-0007FFh) not protected from table reads executed in other blocks
    Walter
  16. #56
    Hi Walter,
    When using the new config directives you need to place them in the 18F26J50.INC file. They will not work when dropped directly in your code file.
    -Bruce
    tech at rentron.com
  17. #57
    Thanks Bruce,
    The configs work. My configuration fuses get changed properly, my led blinks. However, PBP can not accept the speed of my oscillator. It looks like the only thing that needs to be done is to have MeLabs make some sort of change on their end to accept the OSC speed.
  18. #58
    Hi Walter,
    Are you setting OSCTUNE.6 to enable the 96MHz multiplier?
    -Bruce
    tech at rentron.com
  19. #59
    Hi Bruce,
    I had it in some earlier code, but you are right it is missing here. That brings me back up to what appears to be 12 x the 4 mhz default speed (that is 12x faster than PBP is expecting it, since I am missing the define to make it compile), when I leave out my oscillator define. But when I put in my DEFINE OSC XX I get the same error as before.
  20. #60
    I'm guessing you still have the new config directives in your code VS in the 18F26J50.INC file?
    That will cause the error. You need to place these in your 18F26J50.INC file.
    Then it should work as expected.
    -Bruce
    tech at rentron.com
  21. #61
    Yes, I do. My question sort of was:
    Is there a work around. Sounds like the answer is NO for the newer chips that do not have the CONFIGxL/H in their .inc file.
    Which brings me to my next question:
    Since it appears that the only hang up is the way PBP checks to see if you can run at the processor speed, do you think this can be fixed pretty easily by MeLabs? Or do you think I am making it out to be easier than it really is. I have tried to do a work-around, but have not succeeded (yet).
    It is not such a big deal, as I can declare them as you suggest. But I am stubborn, and it appears to be one single register that needs to be set, and it would work.
  22. #62
    I'm not sure what the fix would be to be honest, but if you're up for an experiment, try this;
    Make a backup copy of your PBPPIC18.LIB.
    Now use an editor to find & replace all instances of OSC with XTAL.
    Save the .LIB file, and compile with DEFINE XTAL 48, and the new config directives in your code.
    Does it work?
    -Bruce
    tech at rentron.com
  23. #63
    Default Success! Thanks Bruce!
    Thanks Bruce, that does the trick! Just did exactly as you said, and now it lets me compile inside my program code like this:
    Define XTAL 48
    OSCTUNE.6 =1
       CONFIG OSC=HSPLL
       CONFIG CPUDIV=OSC1
       CONFIG PLLDIV=5
       CONFIG LPT1OSC=OFF
       CONFIG CP0=OFF
       CONFIG WDTEN=ON
       CONFIG XINST=OFF
       CONFIG IOL1WAY=OFF
       CONFIG STVREN=OFF
       CONFIG T1DIG=ON
       CONFIG FCMEN=OFF
       CONFIG WDTPS=512
    And my LED is blinking at the right speed. Yes, I could just edit configs in the .inc file, but then you have to change it for each project. A pain if you want to jump around from unfinished project to unfinished project. Oh, that's just me....
  24. #64
    Cool. Maybe the fix is something as simple as melabs changing to something other than OSC?
    Just bear-in-mind that your next PBP update will change everything, and any patch will fail since you've modified your library files...;o)
    -Bruce
    tech at rentron.com
  25. #65
    Ah, I see what you mean!
    Define XTAL 48
    OSCTUNE.6 =1
       CONFIG OSC=HSPLL
  26. #66
    Jan 2011
    Skopje,Macedonia
    Default Re: Presetting Configuration Fuses (PIC Defines) into your Program
    I got this error: overwriting previous address contents (2007)
    I write this line @ __CONFIG _INTRC_OSC_NOCLKOUT to turn on the internal oscilator of the PIC16F628A,
    I fix any mistakes what I think I made them,but there are errors.I DEFINE OSC 4,it's not working.
  27. #67
    You need to comment the *.inc file for the chip in the PBP directory.
    http://www.picbasic.co.uk/forum/show...=6775#post6775
  28. #68
    Jan 2011
    Skopje,Macedonia
    I get: Unable to open INCLUDE file P16F628A.INC
  29. #69
    Quote Originally Posted by SKOLS1 View Post
    Be sure Microcode Studio knows where that file is located. Click view, Compile and Program Options ,click the assembler tab,check USE MPASM, and Click either find Manually or Find Automatically.
  30. #70
    Jan 2011
    Skopje,Macedonia
    Quote Originally Posted by Archangel View Post
    I try with P16F628.INF file and It isn't working with another Include file(16F628.inc).I find it automatically but still not working.I will try with my other computer.I am using MPLAB IDE v8.73,I have those problems with MPLAB IDE v.7.60.What do you think?
  31. #71
    You do not include those files, PBP does that for you. All you need to do is tell PBP where MPASM is.
    http://www.picbasic.co.uk/forum/cont...tudio-PICKIT-2
  32. #72
    Feb 2010
    Oh , it's been 7 years and this thread is still hot!
    Here is my configuration problem using PIC12F1822.
    As long as i red the manuals i guess the correct is
    @ __CONFIG1 _FOSC_INTOSC & _
    but... GAGA ... wrong.
    i also tried
    @ __CONFIG _FOSC_INTOSC & _
    also tried include the .inc neither worked.
    Any ideas?
    Thanks in advance! .
  33. #73
    These configs are for the PM assembler.
    Which assembler are you using? Also which version of PBP?
    The inc is not to be included. But you can open it and see what are the configuration words exaclty.
    I would recommend using MPASM as an assembler and the syntax of your compiler.
    Feb 2010
    Nop ,
    these configs are for the MPASM assembler - which i use ,
    since PM (of the PBP 2.60c i use) does not support the 12F1822.
    ps. just saw you're from Thessaloniki too
    so , Kalo Sabbatokyriako ! 'Good Weekend
  35. #75
    Ooops yes, thats is MPASM but the syntax was not correct.
    Try this
       __config _CONFIG1, _FOSC_INTOSC
    Yes, I am located in Thessaloniki
    Feb 2010
    Overwriting previous address contents (8007)
  37. #77
    Feb 2010
    Problem solved!
    I had to use
    __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
    __CONFIG _CONFIG2, _WRT_OFF & _PLLEN_OFF & _STVREN_OFF & _BORV_19 & _LVP_OFF
    and the trick was to ";" comment out the __CONFIG in M12F1822.INC file in the PBP directory , because it conflicted.
  38. #78
    Default Re: Presetting Configuration Fuses (PIC Defines) into PBP3 (Only version 3.0 +)
    Here are a few examples of how to use the new #CONFIG block syntax for PBP3. (This will NOT work on previous versions of PBP ... Get your upgrade now )
    PBP3 makes it a little easier to figure out, and set up your configs. It has eliminated the need to comment out the default configurations set up by PBP. It still has default settings - these can be found in the /PBP3/DEVICES file under yourchip.PBPINC . Here is an example of default settings for the PIC18F45K22:
    ; CUT rest of file out for display purposes
    ;  The #CONFIG block is passed directly to the asm file, but PBP will replace it
    ;  automagically with the contents of a user-defined #CONFIG block if one is
    ;  found in the PBP source program.
            __CONFIG    _CONFIG1H, _FOSC_INTIO67_1H
            __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
            __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    If you want to change the default configs in PBP3, DON'T edit the above file. You can just declare them in your code using the #CONFIG #ENDCONFIG block. For all the possibilities of config settings for your chip, check out the /PBP3/DEVICE_REFERENCE folder, and select the yourchip.INFO file. It will look something like this:
    ;  File:    PIC18F45K22.INFO
    ;  Date:    07/24/11
    ;  Generated by melabs File Manager
    ;  PICBASIC PRO(tm) Compiler version: 3.0.0.x
    ;  Copyright 2011 microEngineering Labs, Inc.   All Rights Reserved
    ;  The content herein is intended to facilitate embedded development using
    ;  PICBASIC PRO Compiler.  Reproduction or utilization for other purposes
    ;  is prohibited without written permission from microEngineering Labs, Inc..
    ;  microEngineering Labs, Inc.
    ;  2845 Ore Mill Road STE 4
    ;  Colorado Springs, CO  80904
    ;  719-520-5323
    ;  fax: 719-520-1867
    ;  http://melabs.com
    ;  [email protected]
    ;  Modifications to this file in the \DEVICE_REFERENCE folder will be overwritten when
    ;  you install future upgrades.
    ;MPASM CONFIG Directive Options
    ;  This section is included for reference only.  The following options may
    ;  be used with the MPASM CONFIG directive to specify configuration settings
    ;  in the source program using the #CONFIG/#ENDCONFIG block.
    ;  Example:
    ;  #CONFIG
    ;    CONFIG  OSC = HS
    ;    CONFIG  WDTE = ON
    ;  #ENDCONFIG
    ;    CONFIG FOSC = RC        ;111X External RC oscillator, CLKOUT function on RA6
    ;    CONFIG FOSC = ECLPIO6        ;EC oscillator (low power, <500 kHz)
    ;    CONFIG FOSC = ECLP        ;EC oscillator, CLKOUT function on OSC2 (low power, <500 kHz)
    ;    CONFIG FOSC = ECMPIO6        ;EC oscillator (medium power, 500 kHz-16 MHz)
    ;    CONFIG FOSC = ECMP        ;EC oscillator, CLKOUT function on OSC2 (medium power, 500 kHz-16 MHz)
    ;    CONFIG FOSC = INTIO7        ;Internal oscillator block, CLKOUT function on OSC2
    ;    CONFIG FOSC = INTIO67        ;Internal oscillator block
    ;    CONFIG FOSC = RCIO6        ;External RC oscillator
    ;    CONFIG FOSC = RC        ;External RC oscillator, CLKOUT function on OSC2
    ;    CONFIG FOSC = ECHPIO6        ;EC oscillator (high power, >16 MHz)
    ;    CONFIG FOSC = ECHP        ;EC oscillator, CLKOUT function on OSC2 (high power, >16 MHz)
    ;    CONFIG FOSC = HSMP        ;HS oscillator (medium power 4-16 MHz)
    ;    CONFIG FOSC = HSHP        ;HS oscillator (high power > 16 MHz)
    ;    CONFIG FOSC = XT        ;XT oscillator
    ;    CONFIG FOSC = LP        ;LP oscillator
    ;  4X PLL Enable
    ;    CONFIG PLLCFG = OFF        ;Oscillator used directly
    ;    CONFIG PLLCFG = ON        ;Oscillator multiplied by 4
    ;  Primary clock enable bit
    ;    CONFIG PRICLKEN = OFF        ;Primary clock can be disabled by software
    ;    CONFIG PRICLKEN = ON        ;Primary clock is always enabled
    ;    CONFIG FCMEN = OFF        ;Fail-Safe Clock Monitor disabled
    ;    CONFIG FCMEN = ON        ;Fail-Safe Clock Monitor enabled
    ;    CONFIG IESO = OFF        ;Oscillator Switchover mode disabled
    ;    CONFIG IESO = ON        ;Oscillator Switchover mode enabled
    ;    CONFIG PWRTEN = OFF        ;Power up timer disabled
    ;    CONFIG PWRTEN = ON        ;Power up timer enabled
    ;    CONFIG BOREN = SBORDIS        ;Brown-out Reset enabled in hardware only (SBOREN is disabled)
    ;    CONFIG BOREN = NOSLP        ;Brown-out Reset enabled in hardware only and disabled in Sleep mode (SBOREN is disabled)
    ;    CONFIG BOREN = ON        ;Brown-out Reset enabled and controlled by software (SBOREN is enabled)
    ;    CONFIG BOREN = OFF        ;Brown-out Reset disabled in hardware and software
    ;  Brown Out Reset Voltage bits
    ;    CONFIG BORV = 190        ;VBOR set to 1.90 V nominal
    ;    CONFIG BORV = 220        ;VBOR set to 2.20 V nominal
    ;    CONFIG BORV = 250        ;VBOR set to 2.50 V nominal
    ;    CONFIG BORV = 285        ;VBOR set to 2.85 V nominal
    ;  Watchdog Timer Enable bits
    ;    CONFIG WDTEN = ON        ;WDT is always enabled. SWDTEN bit has no effect
    ;    CONFIG WDTEN = SWON        ;WDT is controlled by SWDTEN bit of the WDTCON register
    ;    CONFIG WDTEN = NOSLP        ;WDT is disabled in sleep, otherwise enabled. SWDTEN bit has no effect
    ;    CONFIG WDTEN = OFF        ;Watch dog timer is always disabled. SWDTEN has no effect.
    ;    CONFIG WDTPS = 32768        ;1:32768
    ;    CONFIG WDTPS = 16384        ;1:16384
    ;    CONFIG WDTPS = 8192        ;1:8192
    ;    CONFIG WDTPS = 4096        ;1:4096
    ;    CONFIG WDTPS = 2048        ;1:2048
    ;    CONFIG WDTPS = 1024        ;1:1024
    ;    CONFIG WDTPS = 512        ;1:512
    ;    CONFIG WDTPS = 256        ;1:256
    ;    CONFIG WDTPS = 128        ;1:128
    ;    CONFIG WDTPS = 64        ;1:64
    ;    CONFIG WDTPS = 32        ;1:32
    ;    CONFIG WDTPS = 16        ;1:16
    ;    CONFIG WDTPS = 8        ;1:8
    ;    CONFIG WDTPS = 4        ;1:4
    ;    CONFIG WDTPS = 2        ;1:2
    ;    CONFIG WDTPS = 1        ;1:1
    ;  CCP2 MUX bit
    ;    CONFIG CCP2MX = PORTC1        ;CCP2 input/output is multiplexed with RC1
    ;    CONFIG CCP2MX = PORTB3        ;CCP2 input/output is multiplexed with RB3
    ;    CONFIG PBADEN = ON        ;PORTB<5:0> pins are configured as analog input channels on Reset
    ;    CONFIG PBADEN = OFF        ;PORTB<5:0> pins are configured as digital I/O on Reset
    ;  P3A/CCP3 Mux bit
    ;    CONFIG CCP3MX = PORTB5        ;P3A/CCP3 input/output is multiplexed with RB5
    ;    CONFIG CCP3MX = PORTE0        ;P3A/CCP3 input/output is mulitplexed with RE0
    ;  HFINTOSC Fast Start-up
    ;    CONFIG HFOFST = ON        ;HFINTOSC output and ready status are not delayed by the oscillator stable status
    ;    CONFIG HFOFST = OFF        ;HFINTOSC output and ready status are delayed by the oscillator stable status
    ;  Timer3 Clock input mux bit
    ;    CONFIG T3CMX = PORTC0        ;T3CKI is on RC0
    ;    CONFIG T3CMX = PORTB5        ;T3CKI is on RB5
    ;  ECCP2 B output mux bit
    ;    CONFIG P2BMX = PORTD2        ;P2B is on RD2
    ;    CONFIG P2BMX = PORTC0        ;P2B is on RC0
    ;    CONFIG MCLRE = EXTMCLR        ;MCLR pin enabled, RE3 input pin disabled
    ;    CONFIG MCLRE = INTMCLR        ;RE3 input pin enabled; MCLR disabled
    ;    CONFIG STVREN = ON        ;Stack full/underflow will cause Reset
    ;    CONFIG STVREN = OFF        ;Stack full/underflow will not cause Reset
    ;    CONFIG LVP = ON        ;Single-Supply ICSP enabled if MCLRE is also 1
    ;    CONFIG LVP = OFF        ;Single-Supply ICSP disabled
    ;    CONFIG XINST = ON        ;Instruction set extension and Indexed Addressing mode enabled
    ;    CONFIG XINST = OFF        ;Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
    ;  Background Debug
    ;    CONFIG DEBUG = OFF        ;Disabled
    ;    CONFIG DEBUG = ON        ;Enabled
    ;  Code Protection Block 0
    ;    CONFIG CP0 = OFF        ;Block 0 (000800-001FFFh) not code-protected
    ;    CONFIG CP0 = ON        ;Block 0 (000800-001FFFh) code-protected
    ;  Code Protection Block 1
    ;    CONFIG CP1 = OFF        ;Block 1 (002000-003FFFh) not code-protected
    ;    CONFIG CP1 = ON        ;Block 1 (002000-003FFFh) code-protected
    ;  Code Protection Block 2
    ;    CONFIG CP2 = OFF        ;Block 2 (004000-005FFFh) not code-protected
    ;    CONFIG CP2 = ON        ;Block 2 (004000-005FFFh) code-protected
    ;  Code Protection Block 3
    ;    CONFIG CP3 = OFF        ;Block 3 (006000-007FFFh) not code-protected
    ;    CONFIG CP3 = ON        ;Block 3 (006000-007FFFh) code-protected
    ;    CONFIG CPB = OFF        ;Boot block (000000-0007FFh) not code-protected
    ;    CONFIG CPB = ON        ;Boot block (000000-0007FFh) code-protected
    ;    CONFIG CPD = OFF        ;Data EEPROM not code-protected
    ;    CONFIG CPD = ON        ;Data EEPROM code-protected
    ;  Write Protection Block 0
    ;    CONFIG WRT0 = OFF        ;Block 0 (000800-001FFFh) not write-protected
    ;    CONFIG WRT0 = ON        ;Block 0 (000800-001FFFh) write-protected
    ;  Write Protection Block 1
    ;    CONFIG WRT1 = OFF        ;Block 1 (002000-003FFFh) not write-protected
    ;    CONFIG WRT1 = ON        ;Block 1 (002000-003FFFh) write-protected
    ;  Write Protection Block 2
    ;    CONFIG WRT2 = OFF        ;Block 2 (004000-005FFFh) not write-protected
    ;    CONFIG WRT2 = ON        ;Block 2 (004000-005FFFh) write-protected
    ;  Write Protection Block 3
    ;    CONFIG WRT3 = OFF        ;Block 3 (006000-007FFFh) not write-protected
    ;    CONFIG WRT3 = ON        ;Block 3 (006000-007FFFh) write-protected
    ;    CONFIG WRTC = OFF        ;Configuration registers (300000-3000FFh) not write-protected
    ;    CONFIG WRTC = ON        ;Configuration registers (300000-3000FFh) write-protected
    ;    CONFIG WRTB = OFF        ;Boot Block (000000-0007FFh) not write-protected
    ;    CONFIG WRTB = ON        ;Boot Block (000000-0007FFh) write-protected
    ;    CONFIG WRTD = OFF        ;Data EEPROM not write-protected
    ;    CONFIG WRTD = ON        ;Data EEPROM write-protected
    ;  Table Read Protection Block 0
    ;    CONFIG EBTR0 = OFF        ;Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
    ;    CONFIG EBTR0 = ON        ;Block 0 (000800-001FFFh) protected from table reads executed in other blocks
    ;  Table Read Protection Block 1
    ;    CONFIG EBTR1 = OFF        ;Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
    ;    CONFIG EBTR1 = ON        ;Block 1 (002000-003FFFh) protected from table reads executed in other blocks
    ;  Table Read Protection Block 2
    ;    CONFIG EBTR2 = OFF        ;Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
    ;    CONFIG EBTR2 = ON        ;Block 2 (004000-005FFFh) protected from table reads executed in other blocks
    ;  Table Read Protection Block 3
    ;    CONFIG EBTR3 = OFF        ;Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
    ;    CONFIG EBTR3 = ON        ;Block 3 (006000-007FFFh) protected from table reads executed in other blocks
    ;  Boot Block Table Read Protection bit
    ;    CONFIG EBTRB = OFF        ;Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    ;    CONFIG EBTRB = ON        ;Boot Block (000000-0007FFh) protected from table reads executed in other blocks
    ;/MPASM
    Here is an example of how to use the #CONFIG block:
    ' PIC18F45K22 With Internal OSC set to 64 Mhz
    ' FLASH AN LED CONNECTED TO PORTB.0
        CONFIG DEBUG = OFF
        CONFIG XINST = OFF
        CONFIG STVREN = OFF
        CONFIG WDTEN = OFF
        CONFIG FCMEN = OFF
        CONFIG PLLCFG = ON
        CONFIG IESO = OFF       ; Two-Speed Start-up disabled
        CONFIG WDTPS = 128      ; 1:128 prescaller for watchdog
        CONFIG BOREN = OFF      ; Brown-out Reset disabled in hardware and software
        CONFIG BORV = 250       ; VBOR set to 2.5 V nominal
        CONFIG MCLRE = EXTMCLR  ; MCLR pin enabled, RE3 input pin disabled
        CONFIG HFOFST = OFF     ; The system clock is held off until the HF-INTOSC is stable.
        CONFIG PBADEN = OFF     ; PORTB<4:0> pins are configured as digital I/O on Reset
        CONFIG CCP2MX = PORTC1  ; CCP2 input/output is multiplexed with RC1
        CONFIG LVP = OFF        ; Single-Supply ICSP disabled
        CONFIG CP0 = OFF        ; Block 0 (000800-001FFFh) not code-protected
        CONFIG CP1 = OFF        ; Block 1 (002000-003FFFh) not code-protected
        CONFIG CPB = OFF        ; Boot block (000000-0007FFh) not code-protected
        CONFIG CPD = OFF        ; Data eeprom not code-protected
        CONFIG WRT0 = OFF       ; Block 0 (000800-001FFFh) not write-protected
        CONFIG WRT1 = OFF       ; Block 1 (002000-003FFFh) not write-protected
        CONFIG WRT2 = OFF       ; Block 2 (4000h-5FFFh) not write-protected
        CONFIG WRT3 = OFF       ; Block 3 (6000h-7FFFh) not write-protected
        CONFIG WRTB = OFF       ; Boot block (000000-0007FFh) not write-protected
        CONFIG WRTC = OFF       ; Configuration registers (300000-3000FFh) not write-protected
        CONFIG WRTD = OFF       ; Data eeprom not write-protected
        CONFIG EBTR0 = OFF      ; Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
        CONFIG EBTR1 = OFF      ; Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
        CONFIG EBTRB = OFF      ; Boot block (000000-0007FFh) not protected from table reads executed in other blocks
        DEFINE OSC 64           'THE 16MHz IS PLL'ed TO 64 MHz
        OSCCON = %01110000    'Set internal osc to 16 Mhz
        OSCTUNE = %01000000   'Turn PLL ON to multiply osc by 4
        ANSELA = 0              'ALL ANALOG TO DIGITAL
        ANSELB = 0
        ANSELC = 0
    If you get an error like:
    [ERROR] program.pbp fatal (34) : Block overflow for #ENCONFIG
    that means that there are too many comments in your configs to "fit". Erase some comments and try compiling again.
    Some new features in PBP3 make it possible to do conditional defines, and conditional PIC setup.
    (Some content plagiarized from here: http://support.melabs.com/threads/26...wfull=1#post38 ... Thanks Darrel!)
    Here's an example of how you can set the configuration bits according to the chip being compiled for.
    It uses the Conditional Compile directives (#IF/#ELSE/#ENDIF) along with the #CONFIG blocks.
    Only the configs for the selected chip will be used.
    And if any other chip besides the 25K20 or 25K22 are selected, it will give an error.
    #IF __PROCESSOR__ = "18F25K22"
        #config
            CONFIG  FOSC = HSHP
            CONFIG  WDTEN = OFF
            CONFIG  PWRTEN = ON
            CONFIG  BOREN = OFF
            CONFIG  PBADEN = OFF
            CONFIG  LVP = OFF
            CONFIG  DEBUG = OFF
            CONFIG  XINST = OFF
        #endconfig
        ANSELA = 0   ; All Digital
        ANSELB = 0
        ANSELC = 0
    #ELSE
        #IF __PROCESSOR__ = "18F25K20"
            #config
                CONFIG  FOSC = HS
                CONFIG  WDTEN = OFF
                CONFIG  PWRT = ON
                CONFIG  BOREN = OFF
                CONFIG  PBADEN = OFF
                CONFIG  MCLRE = OFF
                CONFIG  LVP = OFF
                CONFIG  DEBUG = OFF
                CONFIG  XINST = OFF
            #endconfig
            ANSEL = 0  ; All Digital
            ANSELH = 0
        #ELSE
             #ERROR "This program does not support the " + __PROCESSOR__
        #ENDIF
    #ENDIF
    Note that it also sets the ANSEL? registers differently for each chip. Anything else specific to a particular chip can be set this way too.
    Some things to remember:
    PBP can not use the XINST ,"Instuction set extension and indexed addressing mode", so make sure it is never turned on.
    LVP is another issue. Just leave this off as well.
    Some older chips like a slightly different context. Let's take a PIC16F628A for example:
    Here are the default configs:
        ifdef PM_USED
            device  pic16F628A, xt_osc, wdt_on, mclr_on, lvp_off, protect_off
            __config _XT_OSC & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
    (The first part of this conditional config statment checks to see if the PM assembler is used. Since code for the newer chips can't be assembled with PM, I always chose MPASM.)
    You have to use a format like this for these older chips: __config _x & _y & _z
    http://www.scalerobotics.com
  39. #79
    Jun 2011
    Melanie,
    Can you help me with this?
    I cannot get the protection to work. My devices are a 18F2680 and a 18F2620.
    Here is my code;
    __CONFIG _CONFIG5L, _CP_ALL & _DATA_CP_ON
    __CONFIG _CONFIG5H, _CP_ALL & _DATA_CP_ON
    As you can see I tried it in bothe high and low registers. This is what I get when I try to compile;
    Symbol not previously defined (_CP_ALL)
    Symbol not previously defined (_DATA_CP_ON)
    Thanks for any help!
    Ray
  40. #80
    Sorry, I wish I was Melanie, but I have not seen her around lately, or even not so lately.
    The 18F2680 needs different syntax for those options. Check out post # 42 of this thread.
    Here is the syntax to use for the 18F2680:
    _CP0_ON_5L           EQU  H'FE'    ; Block 0 (000800-003FFFh) code-protected
    _CP0_OFF_5L          EQU  H'FF'    ; Block 0 (000800-003FFFh) not code-protected
    _CP1_ON_5L           EQU  H'FD'    ; Block 1 (004000-007FFFh) code-protected
    _CP1_OFF_5L          EQU  H'FF'    ; Block 1 (004000-007FFFh) not code-protected
    _CP2_ON_5L           EQU  H'FB'    ; Block 2 (008000-00BFFFh) code-protected
    _CP2_OFF_5L          EQU  H'FF'    ; Block 2 (008000-00BFFFh) not code-protected
    _CP3_ON_5L           EQU  H'F7'    ; Block 3 (00C000-00FFFFh) code-protected
    _CP3_OFF_5L          EQU  H'FF'    ; Block 3 (00C000-00FFFFh) not code-protected
  1. pic program crashing
    By comwarrior in forum General
    Last Post: - 8th July 2009, 17:33
  2. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  3. Making Program Code Space your playground...
  4. size of program vs mem on pic
    By PICMAN in forum General
    Last Post: - 1st March 2005, 18:23
  5. Serial communication PIC to PIC help.
    By Rubicon in forum mel PIC BASIC Pro
    Last Post: - 24th January 2005, 16:45
Members who have read this thread : 6
