USBDemo, something to learn USB a little bit - Page 7
Page 7 of 7 FirstFirst ... 34567
Results 241 to 279 of 279
  1. #241
    Dec 2006
    Doh, I suppose I should have looked a bit more deeply on the forum! lol.
    I did see this ages ago and it slipped my memory, but found DT's USB_ASM_Service file and tried that and BINGO! sorted it PHEW!
    Must say thanks to DT as it seems that whenever I see someone (even myself!) get stuck with something, a quick delve into the forums usually finds a post by Darrel that sorts it!
    Mark
  2. #242
    Dec 2010
    Tokyo
    Default USBout sends garbage byte ahead of message
    I am new and this is my first posting, please don't shoot me in case of mistakes.
    Today I started to use PicPasic Pro 2.6 with MPLAB IDE 8.60 and tried out the usb_demo.bas sample immediately.
    MPLAB file list:
    CDC_DEMO.BAS
    CDC_DESC.BAS
    USB_CDC.ASM
    USB_CDC.INC
    USB_MEM.ASM
    USB_DEV.ASM
    USB_DEV.INC
    CDC_DEMO.BAS Code:
    ' USB sample program for PIC18F4550 CDC serial port emulation
    '  Requires PBP 2.60 or later
    '  Compilation of this program requires that specific support files be
    '  available in the source directory.  For detailed information, see
    '  the file PBP\USB18\USB.TXT.
    	Include	"cdc_desc.bas"	' Include the HID descriptors
    Define  OSC     48
    buffer	Var	Byte[16]
    cnt	Var	Byte
    	OSCTUNE.6 = 1		' Enable PLL for 18F87J50 family
    	Pause 10
    	USBInit			' Get USB going
    ' Wait for USB input
    idleloop:
    	USBService		' Must service USB regularly
    	cnt = 16		' Specify input buffer size
    	USBIn 3, buffer, cnt, idleloop
    ' Message received
    	buffer[0] = "H"
    	buffer[1] = "e"
    	buffer[2] = "l"
    	buffer[3] = "l"
    	buffer[4] = "o"
    	buffer[5] = " "
    	buffer[6] = "W"
    	buffer[7] = "o"
    	buffer[8] = "r"
    	buffer[9] = "l"
    	buffer[10] = "d"
    	buffer[11] = 13
    	buffer[12] = 10
    	buffer[13] = 0
    outloop:
    	USBOut 3, buffer, 14, outloop
    	Goto idleloop		' Wait for next buffer
    The test program in the PC is a simple VB6 routine:
    ;---------------- Write to PIC --------------------------
    Private Sub Out3Byte(bus As Byte, adr As Byte, data As Byte)
    Dim Com(2) As Byte
    Com(0) = bus: Com(1) = adr: Com(2) = data
        '3 byte send
        MSComm1.Output = Com
    End Sub
    ;----------------- Receive from PIC ----------------------
    Private Sub MSComm1_OnComm()
    Dim data As String, ende As Boolean
    ende = False: Text1.Text = ""
        Static IsActive As Boolean
        MSComm1.RThreshold = 0
        If IsActive Then
            Label4.Caption = "OnComm Ueberschneidung"
           Exit Sub
        End If
            Do Until ende
                If MSComm1.InBufferCount > 1 Then     'min 1byte recvd
                data = MSComm1.Input
                Text1.Text = Text1.Text + Hex$(AscB(data)) + " "
                Else
                ende = True
                End If
            DoEvents
            Loop
    IsActive = False
    MSComm1.RThreshold = 1
    End Sub
    In general it works fine but, for one little but crucial problem I cant find the reason, so I suspect the problem to be with the PBP compilation.
    The 3 bytes from the PC are always received properly, but the "Hello World" message arrives in the PC correctly only the first time immediately after Com Port Open statement. When continuously sending and receiving, at the beginning of the messages there is always one garbage byte ahead of "Hello World". The value is always the same, but depends one actual memory location in PIC RAM of "buffer Var Byte[16]"
    Can anyone help?
    CDC_DEMO_transmission_log:
    35	VB6.EXE	IOCTL_SERIAL_SET_BAUD_RATE	USBSER000	SUCCESS	Rate: 115200
    36	VB6.EXE	IOCTL_SERIAL_CLR_RTS	USBSER000	SUCCESS
    37	VB6.EXE	IOCTL_SERIAL_SET_DTR	USBSER000	SUCCESS
    38	VB6.EXE	IOCTL_SERIAL_SET_LINE_CONTROL	USBSER000	SUCCESS	StopBits: 1 Parity: NONE WordLength: 8
    39	VB6.EXE	IOCTL_SERIAL_SET_CHAR	USBSER000	SUCCESS	EOF:1a ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
    40	VB6.EXE	IOCTL_SERIAL_SET_HANDFLOW	USBSER000	SUCCESS	Shake:1 Replace:0 XonLimit:8000 XoffLimit:8000
    41	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    42	VB6.EXE	IRP_MJ_WRITE	USBSER000	SUCCESS	Length 3: A1 A9 AF	<3 bytes send
    43	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    44	VB6.EXE	IOCTL_SERIAL_SET_WAIT_MASK	USBSER000	SUCCESS	Mask: RXCHAR TXEMPTY CTS DSR RLSD BRK ERR RING
    45	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    46	VB6.EXE	IOCTL_SERIAL_WAIT_ON_MASK	USBSER000	SUCCESS
    47	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    48	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 48 	   <----- Starts with "H"
    49	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    50	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    51	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 65
    52	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    53	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    54	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6C
    55	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    56	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    57	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6C
    58	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    59	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    60	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6F
    61	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    62	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    63	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 20
    64	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    65	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    66	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 57
    67	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    68	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    69	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6F
    70	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    71	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    72	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 72
    73	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    74	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    75	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6C
    76	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    77	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    78	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 64
    79	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    80	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    81	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 0D
    82	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    83	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    84	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 0A
    85	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    86	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    87	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    88	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    89	VB6.EXE	IOCTL_SERIAL_GET_PROPERTIES	USBSER000	SUCCESS
    90	VB6.EXE	IRP_MJ_WRITE	USBSER000	SUCCESS	Length 3: A1 A9 AF	<3bytes send
    91	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    92	VB6.EXE	IOCTL_SERIAL_SET_WAIT_MASK	USBSER000	SUCCESS	Mask: RXCHAR TXEMPTY CTS DSR RLSD BRK ERR RING
    93	B6.EXE	IOCTL_SERIAL_WAIT_ON_MASK	USBSER000	SUCCESS
    94	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    95	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    96	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 00		<----- starts with "0x00"
    97	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    98	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    99	B6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 48 		<----- "H" is 2nd byte
    100	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    101	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    102	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 65
    103	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    104	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    105	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6C
    106	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    107	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    108	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6C
    109	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    110	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    111	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6F
    112	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    113	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    114	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 20
    115	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    116	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    117	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 57
    118	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    119	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    120	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6F
    121	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    122	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    123	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 72
    124	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    125	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    126	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6C
    127	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    128	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    129	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 64
    130	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    131	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    132	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 0D
    133	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    134	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    135	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 0A
    136	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    137	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    138	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    139	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    140	VB6.EXE	IOCTL_SERIAL_GET_PROPERTIES	USBSER000	SUCCESS
    141	VB6.EXE	IRP_MJ_WRITE	USBSER000	SUCCESS	Length 3: A1 A9 AF	<3 bytes send
    142	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    143	VB6.EXE	IOCTL_SERIAL_SET_WAIT_MASK	USBSER000	SUCCESS	Mask: RXCHAR TXEMPTY CTS DSR RLSD BRK ERR RING
    144	VB6.EXE	IOCTL_SERIAL_WAIT_ON_MASK	USBSER000	SUCCESS
    145	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    146	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    147	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 00 <garbage again
    148	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    149	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    150	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 48
  3. #243
    Dec 2010
    Tokyo
    Default USBOut out byte mixup
    I am still stuck with my proplem, therefore, I modified the cdc_demo.bas to be able to change the outbuffer contents:
    Define  OSC     48
    inbuffer	Var	Byte[15]
    outbuffer	Var	Byte[15]
    icnt	Var	Byte
    ocnt	Var	Byte
    	Pause 10
    idleloop:
    	icnt = 6		' Specify input buffer size
    	USBIn 3, inbuffer, icnt, idleloop
    ' Message received
    	outbuffer[0] = inbuffer[0]
    	outbuffer[1] = inbuffer[1]
    	outbuffer[2] = inbuffer[2]
    	outbuffer[3] = inbuffer[3]
    	outbuffer[4] = 0
    	outbuffer[5] = icnt
    	outbuffer[6] = 0
    	outbuffer[7] = $AA
    	outbuffer[8] = $BB
    	outbuffer[9] = $CC
    	outbuffer[10] = $DD
    	outbuffer[11] = 0
    	outbuffer[12] = inbuffer[0]
    	outbuffer[13] = inbuffer[1]
    	outbuffer[14] = inbuffer[2]
    outloop:
    	ocnt = 14
    	USBOut 3, outbuffer, ocnt, outloop
    I continued testing and found out:
    With ocnt = 14
    The first USBOut after com port open in PC test program is actually
    outbuffer[0]....outbuffer[12] -> in total 13 bytes
    from the second output it is always the same
    outbuffer[13], outbuffer[0], outbuffer[1]...., outbuffer[12] ->in total 14 bytes
    I suspect in the appended .inc and .asm files might be a definition mistake, but since I do not understand the code written there, I really need the help of an USB specialist in this Forum to overcome this problem.
    To all the USB experts in this Forum, please Help.
  4. #244
    This is a update to Mister E's VB6 demo program, and firmware that uses Darrel's DT_HID260.pbp include file. It brings back some of the functions that went away with the HID update, and it adds a few more. It now transfers 10 bit A/D conversions to the PC, and it has a really low bandwidth mschart function. It also transfers the port info up to the computer in a single byte, and it's read by VB in bits. (It is hard to read bits with VB!) Ports are changed to match the Olimex PIC-USB-STK ( http://www.olimex.com/dev/pic-usb-stk.html ) . On the chart, it's a little over a second from left to right. By the way, if anyone knows how to keep the mschart from flickering as it is being redrawn, please let me know.
    VB6 doesn't make it very easy to be sure you have include all the necessary files, so if you have issues, let me know. The code was made for a PIC18F4550 with a 20 mhz crystal. You will also need Darrel's DT_HID260 file from here: http://www.picbasic.co.uk/forum/show...0434#post80434
    (Thanks Steve and Darrel for giving me the USB bug!)
    '*  Name    : USB_Demo_4_HID.pbp                                            *
    '*  Author  : Walter Dunckel ScaleRobotics using Darrels example as template*
    '*  Notice  : Copyright (c) 2011                                            *
    '*  Date    : 1/13/2011                                                     *
    '*  Version : 1.1                                                           *
    '*  Notes   : Added Darrel's text example                                   *
    ;--- if you un-comment these, you must comment the ones in the .inc file ---
    ASM  ; 18F2550/4550, 20mhz crystal
       __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
       __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
       __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
       __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    'add if using Microchip's HID Bootloader
    'DEFINE LOADER_USED 1
    'DEFINE RESET_ORG 1000h ' For Microchip USB Bootloader
    ;ASM  ; 18F13K50/14K50  Only 12mhz crystal can be used for USB
    ;    __CONFIG    _CONFIG1L, _CPUDIV_NOCLKDIV_1L & _USBDIV_OFF_1L
    ;    __CONFIG    _CONFIG1H, _FOSC_HS_1H & _PLLEN_ON_1H & _PCLKEN_ON_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    ;    ;added
    ;    __CONFIG    _CONFIG2H, _WDTEN_ON_2H & _WDTPS_512_2H
    ;    __CONFIG    _CONFIG3H, _MCLRE_ON_3H
    ;    __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _BBSIZ_OFF_4L & _XINST_OFF_4L
    ;ENDASM
    DEFINE OSC 48
    clear
    PortA = %00000000
    TrisA = %00000001
    PortB = %00000000
    TrisB = %11110100        'make pushbuttons inputs for PIC-USB-STK
    'TrisB = %00010000 'for 18k50
    PortC = %00000000
    TrisC = %00000000
    TrisD = %00000000
    CMCON = 7
    'CM1CON0 = 7  'for 18f14k50
    'CM2CON0 = 7
            '   CCP/PWM
    CCP1CON =   %00001100       ' CCP1, PWM mode
    CCP2CON =   %00001100       ' CCP2, PWM mode
    PR2     =   249             ' 12khz PWM Freq
    T2CON   =   %00000101       ' TMR2 on, prescaler 1:4
    ;--- Setup Interrupts ------------------------------------------------------
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INT_LIST  macro    ; IntSource,          Label,  Type, ResetFlag?
            INT_Handler   USB_Handler
    endasm
    ;--- Setup USB -------------------------------------------------------------
    INCLUDE "DT_HID260.pbp"
    DEFINE USB_VENDORID    6017
    DEFINE USB_PRODUCTID   2000
    DEFINE USB_VERSION     1
    DEFINE USB_VENDORNAME  "ScaleRobotics"
    DEFINE USB_PRODUCTNAME "Cheap-Scope"
    DEFINE USB_SERIAL      "001"
    DEFINE USB_INSIZE      8   ;was 32  IN report is PIC to PC (8,16,32,64)
    DEFINE USB_OUTSIZE     16   ; OUT report is PC to PIC
    DEFINE USB_POLLIN      10   ; Polling times in mS, MIN=1 MAX=10
    DEFINE USB_POLLOUT     10
    ; --- Each USB LED is optional, comment them if not used ----
    DEFINE USB_LEDPOLARITY 1       ; LED ON State [0 or 1]  (default = 1)
    'DEFINE USB_PLUGGEDLED  PORTD,0 ; LED indicates if USB is connected
    'DEFINE USB_TXLED       PORTD,2 ;  "      "     data being sent to PC
    'DEFINE USB_RXLED       PORTD,1 ;  "      "     data being received from PC
    OutCount    VAR  WORD : OutCount = 0
    Value       VAR  word   'analog result from AN0
    Value2      var  word   'analog result from AN11
    X           VAR  WORD
    counter     var  byte
    Duty1       var  word EXT ' make them available
    Duty2       var  byte EXT
    smallvalue  var  byte
    ;--- Setup ADC -------------------------------------------------------------
    DEFINE ADC_BITS 10 ; Number of bits in ADCIN result
    ADCON2.7 = 1       ; right justify    (Change this if ADFM in diff register)
    'ANSEL = %00000000  'for 18f14k50
    'ANSELH = %00000100  'for 18f14k50
    ADCON0 = %00000001 ' turn on a/d   AN0
    ;--- The Main Loop ---------------------------------------------------------
    pause 2000                               'wait for connection
    ARRAYWRITE USBTXBuffer, ["USB Demo"]    'show text example
    GOSUB WaitToSend
        FOR X = 0 to 2           ; Check for incomming USB data while pausing
    @     ON_USBRX_GOSUB  _HandleRX
          PAUSE 1
        NEXT X
        ADCin 8, value2
    @Duty1=_USBRXBuffer+1
    @Duty2=_USBRXBuffer+3
        counter = counter +1
        ADCIN 0, Value
        ARRAYWRITE USBTXBuffer,[portb,counter,value.highbyte,value.lowbyte,Value2.highbyte,Value2.lowbyte,0,0]
        CCP1CON.5=DUTY1.1       ' load CCP1 duty value
        CCP1CON.4=DUTY1.0       '      with Duty1
        CCPR1L=DUTY1>>2
        CCP2CON.5=DUTY2.1       ' load CCP2 duty value
        CCP2CON.4=DUTY2.0       '      with Duty1
        CCPR2L=DUTY2>>2
        portd = usbrxbuffer[0]
        'IF Plugged THEN GOSUB DoUSBOut     ; only send when USB is connected
        gosub SendIfReady
    GOTO Main
    ;---- This just sends the received packet back to the PC -------------------
    HandleRX:
        ARRAYWRITE USBTXBuffer,[STR USBRXBuffer\USBBufferSizeRX]
    SendIfReady:
        IF Plugged AND TX_READY THEN DoUSBOut
    WaitToSend:
        WHILE Plugged and !TX_READY : WEND
        IF TX_READY THEN GOSUB DoUSBOut
    Edit:
    Ok, now looking at Darrel's post 221 http://www.picbasic.co.uk/forum/show...0611#post80611 , he already made the program compatible with most of the original functions for the 18F4550. So I (also) lifted his code to transfer text to the PC. However, I only do this at power up, so I don't slow the analog transfers down.
    Last edited by ScaleRobotics; - 2nd May 2011 at 01:30. Reason: Added code in code tags
    http://www.scalerobotics.com
  5. #245
    Sep 2009
    FormMain.frm is missing...
  6. #246
    Thanks pedja089, I just added it.
  7. #247
    Sep 2009
    Excellent project!
    Not too complicated, but there are interesting examples of communication and usage of DT's include files.
    Perhaps you should add the LCD.
    Here is my example how to sendtext from winamp to lcd:
    http://www.elektronika.ba/506/lcd-winamp-plugin-on-usb/
    I hope that you will manage the translation...
  8. #248
    5 years later and this thread always evolve and got some more user in the "USB freaks" loops. Glad to see that. Congrats to all!
    Now I wish I have time to revamp it and share some part of what i've done for .NET (C# & VB) ...VB6 being a dead duck for ages now... and the .dll not that suitable now (but still workable) and then on the top of it, new PBP version
    Helm PCB (Amr Bekhit) did a good work on my first .NET version though http://helmpcb.com/?p=166
  9. #249
    Feb 2004
    Michigan, USA
    Default Re: USBDemo, something to learn USB a little bit
    Reading through this it looks like there was a sample of code were the 18F2550 was using an external resonator at 20mhz using the HS fuse. Looking at the datasheet, this would only enable low speed USB, right?
  10. #250
    With those chips ... you can get Full Speed with any crystal that's a multiple of 4Mhz (up to 24Mhz).
    And the processor can run at 48Mhz too.
    They have a really nice Oscillator/PLL.
    Adjusting the Configuration bits is a little tricky though.
    Dec 2010
    Tokyo
    Hello
    I use a PIC18F2550 for CDC serial port emulation based on cdc_demo.bas:
    USBInit
    For input and output I use:
    inloop:
    icnt = inbuff
    USBService
    USBIn 3, inbuffer, icnt, inloop
    outloop:
    USBService
    ocnt = outbuff
    and it works really fine.
    At start PIC tests 5V from PC-USB-Port to wait with 'USBInit'. Sometimes PC is rebooting w/o switch off, but equipmend with the PIC interface still running. Is it possible to let the PIC routine know that Windows VSP is gone and the 'USBInit' has to be done again?
    Thanks to everybody who can help
  12. #252
    Jun 2005
    Penang
    Hello All,
    I'm new in USB.Althought i have tried all the steps necessary steps in order to compile the USB CDC source,i'm not succeeding in doing so.The errors are this :
    What could be the problem?
    Waiting for help
    Regards.
  13. #253
    Quote Originally Posted by NatureTech View Post
    It could be that you are using PBP version 2.46 - 2.50C with MPLAB greater than 8.15a
    Either upgrade PBP, or downgrade MPLAB.
    If you have upgraded PBP, use the new USB files from the USB18 folder.
    I'm able to use Steve's demo along with Darrel's include, but it only works when the MeLabs U2 USB programmer is connected. If I unplug the programmer, the 18F4550 is no longer recognized:
    '*  Name    : USBLabX1_RH.pbp                                              *
    '*  Author  : Steve Monfette/Darrel Taylor/Demon                    *
    '*  Date    : Jan 11 2012                                                  *
    '*  Version : 3.0                                                          *
    '*  Notes   : This is a re-creation of mister-e's USBdemo for DT_HID       *
    '*          : Meant to work with mister-e's GUI                            *
    '*          : Modified for Lab X1                                          *
    '*  Hardware : PIC 18F4550, 20mhz crystal                                  *
    '*           : Lab X1 Experimental Board, 9.5V wall adapter                *
    '*           : MeLabs U2 Programmer v4.32                                  *
    '*  Software : PIC Basic Pro v2.60C                                        *
    '*           : MicroCode Studio Plus v2.2.1.1                              *
    '*           : MPASM WIN Assembler v4.02 (mplab tools/MPASM Suite)         *
    '*  PIC mods : plastic USB connector hot-glued onto top of PIC             *
    '*           : D- wired to C4 (pin 23) directly to top of pins             *
    '*           : D+ wired to C5 (pin 24) directly to top of pins             *
    '*           : two 0.1uF ceramic caps in parallel across VUSB and VSS      *
    '--- if you use these, you must comment the ones in the .inc file ---
    @   __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    @   __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
    @   __CONFIG    _CONFIG2L, _PWRT_OFF_2L & _BOR_ON_2L & _BORV_46_2L & _VREGEN_ON_2L
    @   __CONFIG    _CONFIG2H, _WDT_OFF_2H
    @   __CONFIG    _CONFIG3H, _CCP2MX_ON_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
    @   __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L & _XINST_OFF_4L
    DEFINE OSC 48
    DEFINE  LCD_DREG      PORTD         ' Set LCD data port
    DEFINE  LCD_DBIT      4             ' Set starting data bit
    DEFINE  LCD_RSREG     PORTE         ' Set LCD register select port
    DEFINE  LCD_RSBIT     0             ' Set LCD register select bit
    DEFINE  LCD_EREG      PORTE         ' Set LCD enable port
    DEFINE  LCD_EBIT      1             ' Set LCD enable bit
    DEFINE  LCD_BITS      4             ' Set LCD bus size
    DEFINE  LCD_LINES     2             ' Set number of lines on LCD
    DEFINE  LCD_COMMANDUS 2000          ' Set command delay time in microseconds
    DEFINE  LCD_DATAUS    50            ' Set data delay time in microseconds
    INCLUDE "ReEnterPBP-18.bas"     ; PBP Re-entry for external interrupt
            INT_Handler   INT_INT,   _ToggleLED1, PBP,    yes
    endasm
    @   INT_ENABLE   INT_INT        ; enable external (INT) interrupts
    DEFINE USB_VENDORNAME  "Mr E/DT/RH"
    DEFINE USB_PRODUCTNAME "USBLabX1"
    DEFINE USB_INSIZE      8    ;  IN report is PIC to PC (8,16,32,64)
    DEFINE USB_OUTSIZE     8    ; OUT report is PC to PIC
    ; --- Each USB status LED is optional, comment them if not used ------------
    ; --- They can be assigned to any pin, and no further action is required ---
    DEFINE USB_TXLED       PORTD,1 ;  "      "     data being sent to PC
    DEFINE USB_RXLED       PORTD,2 ;  "      "     data being received from PC
    DEFINE ADC_BITS 8  ; Number of bits in ADCIN result
        TRISA = %00000011               ' Set port A pins to 6 output, 2 input
        TRISB = %00001111               ' Set port B pins to 4 output, 4 input
                                        ' B0 = External Interrupt
        TRISC = %00000000               ' Set all port C pins to output
        TRISD = %00000000               ' Set all port D pins to output
        TRISE = %00000000               ' Set all port E pins to output
    ;--- Variables -------------------------------------------------------------
    Value0      VAR  WORD : Value0 = 0
    Value1      VAR  WORD : Value1 = 0
    DUTY1       VAR  WORD
    DUTY2       VAR  WORD
    LED1        VAR PORTD.3
    WS_CHAR     VAR BYTE
    WS_BYTE     VAR BYTE
    WS_LOOPW    VAR WORD
    ;--- Initialize ------------------------------------------------------------
        ADCON2.7 = 0       ; left justify    (Change this if ADFM in diff register)
        ADCON1 = %00001101     ; AN0 & AN1 analog
        INTCON2 = %00000000    ; Pull-up resistors, falling edge
        PORTB = %00000000      ; Set output on keypad to prevent floating pins
        PAUSE   2000                     ' Wait for USB to initalize
        LCDOUT  $FE,1,"LabX1 18F4550 USB"
        PORTD = 0                       ' Clear LEDs from LCD operations
        ARRAYWRITE USBTXBuffer, ["Lab X1  "]
        FOR WS_LOOPW = 0 to 1000           ; Check for incomming USB data while waiting
            PAUSE 1
        NEXT WS_LOOPW
        ADCIN 0, Value0            ; Send A/D about once/sec
        ADCIN 1, Value1
        ARRAYWRITE USBTXBuffer, [Value0, Value1, PORTD.3, 0, 0, 0, 0, 0]
        GOTO Main
    ;---- Receive incoming data PORTB LEDS and CCP PWM dutycycle ---------------
    HandleRX:
        ARRAYREAD  USBRXBuffer,[WS_BYTE, DUTY1.LowByte, DUTY1.HighByte, _
                                        DUTY2.LowByte, DUTY2.HighByte]
        LCDOUT  $FE,$C0,BIN WS_BYTE
    ToggleLED1:
        TOGGLE LED1
        ARRAYWRITE USBTXBuffer, ["Button  "]
        PORTB = 0               ' Set output on keypad to prevent floating pins
    @ INT_RETURN
    On the Lab X1:
    - PWM logic is not active.
    - buttons 1, 2, 3 and 4 on the keypad activate Port A2 LED.
    - AN 0 and 1 work as expected.
    On the PC:
    - Port B is displayed on the LCD.
    Any idea why Windows XP Home would need the USB programmer connected in order to recognize the PIC?
    Everything works fine if I reconnect the programmer.
  15. #255
    Robert,
    Check the ground from your USB connector.
    Plugging in the programmer will give a common ground with the computer.
    If there is no ground from your USB connector, it will disconnect when you unplug the U2.
    Yup, that fixed that problem.
    But if I leave the programmer connected, it garbles a few characters on the LCD?
    Cleaned up code (replaced PAUSE for LOOP):
    '*  Version : 3.0                                                          *
    @   __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _VREGEN_ON_2L
    @   __CONFIG    _CONFIG3H, _CCP2MX_OFF_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
    DEFINE OSC 48
    CLEAR
    endasm
    DUTY1       VAR  WORD
    DUTY2       VAR  WORD
    LED1        VAR PORTD.3
    WS_CHAR     VAR BYTE
    WS_BYTE     VAR BYTE
    WS_LOOPW    VAR WORD
        LCDOUT  $FE,1                   ' Initiate first command to LCD
        FOR WS_LOOPW = 0 to 1000        ' Wait for LCD to initalize
            PAUSE 1
        NEXT WS_LOOPW
        FOR WS_LOOPW = 0 to 1000        ' Wait for USB to initalize
            PAUSE 1
        NEXT WS_LOOPW
            PAUSE 1
        NEXT WS_LOOPW
        ADCIN 1, Value1
        GOTO Main
    HandleRX:
    ToggleLED1:
        TOGGLE LED1
    @ INT_RETURN
    Sharing the USB NEG only seems to affect the LCD. If I unplug the programmer, Port B updates properly on the LCD, everything runs fine.
    Uh oh, just realized I might have misunderstood. There's also a GROUND eyelet coming from the USB cable, is that the ground you were referring to? If so, would that go to VSS instead of the NEG?
  17. #257
    Pin 4 of the USB connector is Ground.
    It and the Shield should be connected to VSS on the LAB-X1.
    Have you removed the MAX232 chip?
    You've set the RX pin to output, which is likely to cause high currents if the MAX232 is still there.
    Tried both USB pin 4 (black wire) and the eyelet from the shielding connected to VSS, same garbles on LCD.
    I used one of the VSS pins on the PIC, does it have to be a special VSS contact on the Lab X1?
    I didn't remove the MAX232, but I installed headers on my Lab X1. The jumpers for RX and TX pins are disabled, same with VUSB pin.
    EDIT: I didn't have the recommended capacitors so I used two 0.1uF ceramic caps in parallel across VUSB and VSS. Could that be a problem?
  19. #259
    Dec 2010
    I'm just getting started with USB. I've gone through the CDC demo and created my own variants with success (after a bit of teething pain) and now I'm trying to move on to HID. I've found the DT_HID260.zip file and I've been playing with the contents, but I'm not having any luck getting DT_HID260.pbp, DT_INTS-18.bas, ReEnterPBP-18.bas and my code to work together. I'm so close.... I think, but right now I can't even compile.
    I've got 2 errors that have me completely stumped:
    Illegal opcode (USB_INT)
    Address label duplicated or different in second pass (INT_RETURN)
    Any clues where to look? Many thanks...
  20. #260
    It sounds like you would also be getting an error that says it can't open include file DT_INTS-18.bas.
    Did you put it in your PBP folder?
    Dec 2010
    Actually I just resolved it. It seems the line to include DT_HID260.pbp must come AFTER the INT_CREATE. I moved the include from the top of the file to this location and the errors went away.
    Compiles no errors means it will work fine right? Well not exactly, but I'll chew on "why" by myself for a bit.
    Thanks for the help!
  22. #262
    Dec 2010
    Well I though I'd leverage Darrel's heavy lifting and put the USB code (including the interrupt structure) together with the SD card code and make myself basically an overly complicated and expensive thumb drive, purely for my education. It seems, however, that the includes consume more than the 2K space for variables, and after about an hour of trying to make things less generic by eliminating variables wherever possible in favor of fixed values, I still don't have enough space. I'm also not sure if I'm even getting close - is there any way to have the compiler tell you how much you are over by, rather than simply "unable to fit"?
  23. #263
    Charlie,
    I had a similar problem once; so I copied the Includes in the code and removed all the variables I didn't need. That worked in my particular situation.
    Nov 2006
    Ventura, CA
    I'm just getting my feet wet with USB. I currently have PBP (2.60C). I'd like to get some recommendations, before I get too far into this project:
    1) Is there any benefit to upgrading to PBP 3.0, specifically for my USB experiments?
    2) I have very little experience with VB6, but some experience with VBA (in Excel). Back on post 248, Steve said, "...VB6 being a dead duck for ages now...". I _have_ VB6, but was wondering if there was a more current alternative (other than going out and trying to learn a completely new language, like C)
    Any tips would be greately appreciated!
    Jeff
  25. #265
    Aug 2008
    Portugal
    [QUOTE=JBKerner;112633Steve said, "...VB6 being a dead duck for ages now...". I _have_ VB6, but was wondering if there was a more current alternative (other than going out and trying to learn a completely new language, like C)
    [/QUOTE]
    VB.NET;
    http://www.picbasic.co.uk/forum/cont...-USB-to-VB.NET
    Thanks and Regards;
    Gadelhas
  26. #266
    Jeff, read this thread:
    http://www.picbasic.co.uk/forum/showthread.php?t=16234
    It's exactly about this topic.
    Dec 2011
    Unhappy Re: USBDemo, something to learn USB a little bit
    hi,
    i use USBDemo.HEX file. i send it to my PIC using USB PIC programmer (not boot loader). i use;
    18f4550
    4 MHZ crystal (with 22pF capacitors)
    3 parallel 100nF (not polarized) capacitors on pin18
    10k resistor on mclr
    100nF capacitor between VCC and GND
    my pc doesn't recognise the device. nothing happens when i connect PIC to my pc
    what is wrong. i couldn't work it. i am workin on it for months and i am going crazy.
    thanks
  28. #268
    Jun 2008
    ...well looking back it appears you can use a 4mhz. I used a 20mhz crystal when I was able to get it working.
    Do you have a schematic.
  29. #269
    Dec 2011
    this is my scheme. i tried it using 20MHZ and 15pF caps. what is wrong with it?
  30. #270
    Jun 2008
    First thing I do when I'm having trouble is either hook up some Status LEDs or a Serial output to debug the pic. I've had trouble with a program or two..and more than once something was causing a reset. Do you have a compiler so you can add in some debugging code?
    I believe i did 22pf with my 20mhz...which is more than required by the datasheet. :/ I'm not seeing anything right off :/
    Have you verified the usb cable is providing power and works with another device?
  31. #271
    Dec 2011
    i use pic programmer's usb cable. cable works. can anyone send me a simple pcb layout of a working usb project and hex file. i want to improve myself about pic and usb but i couldn't get result for weeks. thanks
  32. #272
    How do you dump the .hex file into your PIC, i mean how do you program your PIC?
    Are you sure your device programmer software program the configuration fuses properly?
    Those .HEX files providen here are there since 6 years or so, they're working.
  33. #273
    Dec 2005
  34. #274
    Dec 2003
    Wichita KS
    Hello Steve and Darrel,
    You mangy old farts, how are you all doing? Looks like all as been well for both of you. Its been a while since we have chatted.
    PIC's working ok? Haven't done any programming for a number of years on those chips. I probably should get back into them.
    Dwayne
    Ability to Fly:
    Hurling yourself towards the ground, and missing.
    Engineers that Contribute to flying:
    Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute
    Pilots that are Flying:
    Those who know their limitations, and respect the green side of the grass...
  35. #275
    So cool to see you back here Dwayne
    As long as I wake up, it's a good day
  36. #276
    Dave,
    That board is based on a PIC24 device. PBP support the 10, 12, 16 and 18 series of PICs - so the answer is no.
    Rumour has it that there's a PBP compiler for PIC24 under development though so perhaps some time in the future.
    Dec 2005
    Thanks, Henrik.
  38. #278
    Dec 2011
    DataToSend's array size is 8. i want to make it 16. i mean i want to send 16 variable at the same time. not 8. can anybody help me?
  39. #279
    Also note: This is for PBP 2.60 only ...
    Someone found a workaround for PBP 3:
    http://www.picbasic.co.uk/forum/show...599#post126599
    Last Post: - 14th June 2016, 07:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 10:38
  3. Replies: 9
    Last Post: - 31st July 2008, 08:56
  4. PICBasic newbie problem
    By ELCouz in forum mel PIC BASIC Pro
    Last Post: - 12th February 2008, 00:55
  5. USART interrupt not interrupting right
    By Morpheus in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 01:07
Members who have read this thread : 4
