USBDemo, something to learn USB a little bit - Page 5
+ Reply to Thread
Page 5 of 7 FirstFirst 1234567 LastLast
Results 161 to 200 of 279
  1. #161
    Dec 2007
    Denmark
    Ok Thanks Steve! Looks like I will have to buy some 18f4550 .
  2. #162
    Well, one in the list... 18F4550, 2550,2455, 4455 they all works.
    As you'll see, it's fun to have it's first working USB project....even if you're aware of post #7 and #8
  3. #163
    Oct 2007
    Hopefully this Topic is still alive as I am really keen to do some experimenting with USB.
    I have looked at all the posts and haven't found any refering to my problem.
    I am using the 18F4550 pic, Picbasic Pro 2.50 and MicroCode Studio Plus 3.0.0.5
    When I compile it stops on Line 81
    Line 81: UCFG var byte EXT ' include UCFG register... Yeah Melabs didn't (
    Line 82: ucfg = %00010100 ' enable internal USB pull-up, Full speed USB
    With the following Error Message:
    ERROR Line 81: Redefinition of VAR. (USBDemo.pbp)
    I notice that when I paste the code from mister-e's zip file into MicroCode Studio it changes the case of line 82:
    Line 82: UCFG = %00010100 ' enable internal USB pull-up, Full speed USB
    the ucfg is now in Capitals, I don't know if this has anything to do with it?
  4. #164
    Previous versions of PBP didn't have the UCFG register defined in the include files. And usbdemo was written at that time.
    PBP 2.50 does have the UCFG register, so defining it in the main program causes a "re-definition" error.
    Just comment out the UCFG var byte EXT line and the error should go away.
    hth,
    Oct 2007
    When I compile it gives the following errors.
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 87 : Overwriting previous address contents (0000)
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 87 : Overwriting previous address contents (0001)
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 93 : Overwriting previous address contents (0000)
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 93 : Overwriting previous address contents (0001)
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 98 : Overwriting previous address contents (0002)
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 98 : Overwriting previous address contents (0003)
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 99 : Overwriting previous address contents (0004)
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 99 : Overwriting previous address contents (0005)
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 100 : Overwriting previous address contents (0006)
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 100 : Overwriting previous address contents (0007)
    Are these errors anything to be concerned with?
    Also out of interest, I am using a 4Mhz Resonator but in the code it is: DEFINE OSC 48
    What is that about?
    However, I seem to be making progress because when I plug it into the USB of the computer. I get the message found new hardware "USB Demo" but then it gives a message There were problems ........ etc etc.
    The VB Application is not picking it up yet.
  6. #166
    Quote Originally Posted by kiwipiper View Post
    What to do if i get "overwriting previous address content" error message?
    http://www.picbasic.co.uk/forum/showthread.php?p=6775
    What is that about?
    The 18F/USB PIC's have an amazing oscillator/PLL structure.
    With the proper CONFIG settings, You can use any crystal that's a multiple of 4mhz (4,8,12,16,20) and still have a system clock of 48mhz.
    If the timing doesn't work well with your program, you can also have 48mhz going to the USB module, and 4/8/12/16/20/24/32 mhz going to the system clock.
    It all depends on the CONFIG's.
    Oct 2007
    I commented out the four offending lines in the 18F4550.INC file and now don't get any errors. However, still get a error message from windows when I attach the PIC
    Messages are: Found New Hardware. USB Device
    USB Human Interface Device
    A problem occurred during hardware installation. Your new hardware might not work properly.
    I have tried USBDemo.exe and HIDmonitor.exe neither of these seems to see the PIC.
    Any suggestions as to what I should try to do now to find the fault. At this stage I have not connected the push buttons or the trim pot to the breadboard but this shouldn't affect the pic being recognised as a USB device.
    P.S. I have the USB connected to 18F4550 in the following way. D- to pin 23, D+ to pin 24 and the -ve usb connection and the USB case connected to vss. I have not connected the +ve usb connection to anything.
  8. #168
    Oct 2007
    Smile
    Forget my last I have figured it out ....... a very happy man here.
    I had left out the .47uF cap on Vusb. Connected this and all is working.
    Will now have a serious play with it, which I sure will create a bunch more questions.
    Thanks for all your help Darrel.
  9. #169
    Oct 2007
    This One for Darrel Taylor. My question is how did you get on modifying the USBDemo program from VB to Delphi. I am much more comfortable working in Delphi than VB and would be really interested in any examples of Delphi Code for this project. I found a good component at http://www.soft-gems.net/index.php?o...d=14&Itemid=33 and have had some success in using it to connect to my PIC but my limited programming ability slows me down a fair bit, although I am learning a lot. If I had a working example in Delphi I am sure it would help me understand what is going on much better.
    A second question is how do you put a serial number into the program. I have been playing around with the DESCUSBDemo.asm
    file and tried to put a serial number into the code. Here is what I did:
    ; serial number
    String3
    retlw (String4-String3)/2
    retlw DSC_STR
    retlw '4'
    retlw 0x00
    retlw '3'
    retlw 0x00
    retlw '2'
    retlw 0x00
    retlw '0'
    retlw 0x00
    retlw '8'
    retlw 0x00
    retlw '8'
    retlw 0x00
    retlw '8'
    retlw 0x00
    Not working. Any suggestions.
  10. #170
    Both questions can be answered with EasyHID.
    The serial number is entered on one of the setup screens.
    And EasyHID will make a "Starting" program for either VB or Delphi.
    Oct 2007
    Thanks for that Darrel .... I did not understand the significance of EasyHID when it was being discussed in this thread earlier on. Making some real progress now and think I should be able to recreate the VB USBDemo.exe in Delphi. Very exciting stuff this USB.
  12. #172
    Oct 2007
    Hi....i'm new in 18f4550..
    Can picbasic pro program this PIC?
    How to open the USB port on this PIC?
    Thanks a lot....
  13. #173
    Quote Originally Posted by thye View Post
    Thanks a lot....
    Read the thread...the WHOLE thread.
    It's all there. A complete project from start to finish.
    Many others have done it, I've done it, you can do it.
    However, I wouldn't expect others to do it for you.
  14. #174
    Mar 2007
    Default Mister_E example in Delphi
    Hi
    Here is an adaptation of Mister_E USBDemo but in Delphi. It's not completely finalised but it works. This example bases on the PICPROTO-USB board from MELabs (you can get all the information on this board from their web site).
    It's PIC18F4550 @ 20 MHz based. I hope the rest is self explanatory. PWM signal is on PORTC.2.
    If you need more info, just let me know. Please, take into account I am not very often on this forum, i.e. please, allow longer reaction times in case you need feedback.
    Have fun
  15. #175
    Oct 2007
    Thanks Momboz but I managed to completely recreate Mister_E's USBDemo.exe in Delphi. It was pretty easy once I understood what EasyHID was all about. Had a little bit of trouble with the PWM but in the end once I understood what MSB and LSB was all about that fell into place as well. The only thing I can get working is showing a serial number.
    Anyway, thank you to everyone who has contributed to this thread it was all very helpful getting me on the right track. For those just starting with this I concur with skimask's comments two posts back that all the information you need is in this wonderful thread. It is the journey of discovery that is the important part and a bit of a struggle makes it all the more rewarding when you get there in the end.
    Here is a link to my KPUSBDemo.zip for another take on the computer interface. It is slightly over the 200K limit, most likely due to my coding skills and overuse of graphics to pretty it up some. If anyone is keen on the code I could clean it up a bit, zip it up and put it up somewhere.
    http://www.breambay.com/downloads/KPUSBDemo.zip
  16. #176
    Oct 2007
    Hi....what is EasyHID? Is it same as picbasic pro software?
    Where can I download the EasyHID?
    Thanks a lot....
  17. #177
    Thanks a lot....
    Refer to Post #173...
    Read thru the thread...you have not...
    Use the search function...you have not...
    Therefore...EasyHID...you have not...
    Heed advice given above...and EasyHID...you shall have...
  18. #178
    semiuniversal's Avatar
    semiuniversal Guest
    Default Astoundingly good demo
    Hi mister_e & all who have contributed. I am quite new to PBP and this is my first post to this list. I just found this demo a week ago, read the thread, ordered the parts, assembled a proto board on Saturday and - (insert Windows USB Device da-dink! sound) it worked FLAWLESSLY, the first time. I am either lucky standing on the shoulders of giants - but oh, my, what a good feeling.
    I have been tinkering incessantly since then.
    Thank you for giving me super powers.
  19. #179
    Thumbs up
    Quote Originally Posted by semiuniversal View Post
    Take my advice...Give out while you still can...
    I have lost countless hours of sleep playing with USB and that demo, spent untold amounts of money, not to mention ticked off the wife numerous times...
    Seriously though...Good game...
    I wish other Noobs would take that as an example...especially the part about 'reading the thread'....
  20. #180
    Default Using USBDemo with LONG variable (PBPL)
    NOTE: If your going to use LONG variables, you MUST copy the PIC18Xxxxx.BAL file in your source directory as well, unless you'll receive some compilation errors.
    The .BAL file is located in \PBP\USB18 directory.
    If you're using PIC18F4550, you MUST copy the 18F4550.BAL file in your source code directory.
    @Darrel.. is this possible to paste it in the first post as well as the other source code (or link) for the other PICs (post 99 http://www.picbasic.co.uk/forum/show...8&postcount=99) ?
  21. #181
    Done! &nbsp;
    Done! &nbsp;
    $20 says a dozen people miss the 18Fxxxx.BAL note...
  23. #183
    Jun 2008
    Unhappy Couple of Questions
    Ok so first of THANK YOU to everyone.
    I'm much further than I was a year ago already...which is a device windows enumerates....
    Now for the problem
    So i have a 2550. I commented out the old .inc file lines updated the ASM line to reflect the proper PBP version i have, implemented the corrected Fuse settings for the 20mhz crystal. and When I plug up the device to Windows I get "USBDemo" then it changes to two different things Hid compliant device and USB Human Interface Device. Then The HID compliant one disappears...then the USB Human Interface Device Gets an ! over it...
    If i run the USB demo VB program the Device Manager Updates and sometimes It will remove teh USB device all together...or sometimes just change to a USB Unknown Device.
    WTF?!
    Earlier I plugged it in and the DEMO vb Recognized it and displayed the RX data for like...20 loops....then then everything stopped. it didnt recognize the usb device anymore as the Mister_E USBdemo that the program previously displayed...
    Other than the ASM changes, "DEFINE OSC 20" and fuse changes ....i haven't changed anything software side. Hardware I have a .33uf because well...the store had a .47uf in 300volts size..and that was to large for the board..and kinda ridiculous. PBP version is 2.46
    Is there a setting in MELABS programmer for the internal pull ups? I saw there was on in the code..but maybe it was being overwritten?
    I've been toying for 3 days now...re reading the thread and looking at others...
    Also...I dont have a .BAL file...*.bal search turned up nothing.. GR....
    Anyone?
  24. #184
    Quote Originally Posted by UnaKRon View Post
    Which are rather large changes considering you have to have the right freq for the USB to run right in the first place.
    PBP version is 2.46
    Don't know if it'll fix your problem or not, but there is a 2.46 patch, and a few updates for $25 that gets you up to PBP 2.50A. A few fixes for USB and PIC18F types. Might help, might not.
    Internal pullups on Port B are described in the datasheet for the particular PIC.
    And you won't unless you're using PBP 2.50A.
  25. #185
    Jan 2007
    Brazil
    Hello..
    I'm using 18F2550 and USB is working very well... I've been trying to increase the buffer size from 8 to 16 but it do not work.
    On Pic's code, I've only changed this:
    BufferSize      con 16
    ' BufferSize      con 8
    On VB's code, this:
    Private Const BufferInSize = 16
    ' Private Const BufferInSize = 8
    Any idea of what is the problem?
    Thanks!!
    Sylvio,
  26. #186
    The IN/OUT "Report" length is usually set in one of the easyHID dialogs.
    Or it can be changed manually in the Descriptor file.
    If you re-run easyHID for the same project, it will wipe out any changes you've made. So create a new project, set everything the way you want it in easyHID, then just copy the descriptor file to your existing project.
    hth,
    Jan 2007
    Brazil
    Done! Perfect Darrel!
    Thanks a lot!
    Sylvio,
  28. #188
    Aug 2008
    Tucson AZ
    Hello,
    First, Mister e This is an outstanding demo. Was able to get running right out of the box on a PIC18f4550.
    I've been trying to add an additonal 8 LEDs to the demo but keep getting overrun errors. Which I'm sure it's caused on the VB side. I'm almost sure the PIC side is ok as i can turn on the original 8 LED or the ones added to PORTD. Can even turn on 4 on PORTB and 4 on PORTD. I'm just unable to get all 16 working at the same time.
    I think my problem is in this part of the VB side code. I was hoping someone could point me back in the proper direction
    Private Sub Check1_Click(index As Integer)
        '   Convert PORTB check box to decimal value before sending it
        '   to USB bus.  Result is store in BufferOut(1)
        Dim LoopCheck, PORTB As Byte
        PORTB = 0
        For LoopCheck = 0 to 15                                               ' 0 To 7
            PORTB = PORTB + (Check1(LoopCheck).Value * (2 ^ LoopCheck))
            Next
        BufferOut(1) = PORTB
        WriteSomeData
    End Sub
    Any assistance would be greatly appricated
  29. #189
    Quote Originally Posted by Philtkp View Post
    PORTB = 0
    Next
    WriteSomeData
    End Sub
    PortB is a byte value. A byte runs 0-255...
    2 ^ 15 = 32,768 which is greater than 255!
  30. #190
    Aug 2008
    Tucson AZ
    I tried changing the variable, PortB to an Integer and Long with no positive results
  31. #191
    Well of course it won't work.
    PortB is a Visual Basic Byte variable (or whatever you want) which gets stored in a Byte Array and sent over the USB to the PIC as a Byte variable stored in a Byte array, which is then stored in the PIC as a Byte variable.
    PORTB = 0
    Next
    WriteSomeData
    End Sub
  32. #192
    Aug 2008
    Tucson AZ
    Can this be done using an array of bytes?
  33. #193
    You ARE sending out an array of bytes...8 of them, unless you've messed with the HID-Maker.
    You have to send out more bytes or figure out a way to 'encode' those bytes you've already got to do more...
  34. #194
    Sep 2006
    Australia
    Thumbs up HIDmonitor.exe
    www.pbpgroup.com/files/HIDmonitor.exe
    Put it anywhere, there is no installation to do.
    Very handy little utility. Thank you very much Darrel.
    ozion
  35. #195
    Aug 2008
    i want to use usbdemo to count rpm of motor and display the rpm in computer. how to do that?
  36. #196
    Begin small, begin by finding a way to count the RPM, show it on a lcd or via a serial communication... once you have it done, port your to code to USBDemo.
  37. #197
    Aug 2008
    i use 8 slot encoder.
    after googling few minutes. i add this code into usbdemo
         COUNT PORTA.2,100,speed
         speed = speed * 10 * 60 / 8
         rpm[0] = speed / 1000 // 10
         rpm[1] = speed / 100 // 10
         rpm[2] = speed / 10 // 10
         rpm[3] = speed // 10
         rpm[4] = 0
         rpm[5] = 0
         rpm[6] = 1
         rpm[7] = 1
    @   SendUSB _rpm
  38. #198
    With the release of PBP version 2.60, mister-e's USBdemo (or any other program derived from EasyHID) will no longer compile (without some changes).
    The new way of doing USB with PBP is really nice.
    So here's a modification to Steve's program that will allow it to be compiled with PBP 2.60, and hopefully show how much easier it is to do USB.<hr>
    . If you haven't already ... download and extract the USBDemo from the beginning of this thread.
    . Then create a new folder (USBDemo260) and copy the USBDemo.pbp file from Steve's archive into the new folder.
    That is the only file that is valid with 2.60, so don't copy any of the others.
    . Download the USBDEMOdesc.bas.txt (descriptor) file attached to this post and place it in the same folder. Remove the .txt extension.
    . In the USB18 folder, inside your PBP folder ...
    Copy the following files to the project ...
    usb_dev.asm
    usb_dev.inc
    usb_hid.asm
    usb_hid.inc
    usb_mem.asm
    . Add this line to the USBDemo.PBP program ... and compile.
      INCLUDE "USBDEMOdesc.bas"
    And away you go, with a little Ding-Dong ... Or maybe a Dong-Ding. <hr>
    Make sure you change the configs if you're not using a 4Mhz crystal.
    And comment out the UCFG EXT variable since it's not needed anymore.
    The Visual Basic part of mister-e's demo is the same.
    You can use the pre-compiled program, or modify it as desired.
    Mar 2009
    Colorado
    Default Schematic link broken...can you provide??
    Hi all,
    Since the USB stuff is coming more and more popular, and as we see more and more questions, i decided to post my little contribution.
    OK OK You already asked... but i'm in a good moon today, so let me believe it never been asked before
    The whole thing will use a PIC18F4550 and a 4MHz crystal + few Leds, 2 trim pot... you should be able to figure this out easy.
    There we go, here's the PC interface,
    <img SRC="http://www.mister-e.org/Pics/USBDemo.JPG">
    Steve, the link to the PC interface schematic as posted in your original is broken. Can you please give me a valid link or email me the schematic at [email protected]? I want to check your USBDemo out!
  40. #200
    Haven't seen him around for awhile.
    His website is gone too.
    Here's the schematic he had previously posted.
    Last Post: - 14th June 2016, 08:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 11:38
  3. Replies: 9
    Last Post: - 31st July 2008, 09:56
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
