Working with indivividual bytes of an array
Results 1 to 6 of 6
    Jun 2006
    Glasgow, Scotland
    Smile Working with indivividual bytes of an array
    I am writing this routine in picbsic pro to set a variable say Hours and then send it as part of a array of time and date variables to a 1307 RTC chip.
    I domt seem to get it to work If I allocate the variable values at the beginning of the program and then call the settime routine then it works. I have included the code can someone explain why it dos not work.
    kind regards John
    '* Name : 1307_clock_Pad.BAS *
    '* Author : John Norrie *
    '* Notice : Copyright (c) John Norrie *
    '* : All Rights Reserved *
    '* Date : 22/12/2006 *
    '* Version : 1.0 Digital Clock w/ Time *
    '* Notes : for the 16 x2 LED *
    '* : clock display module, DS1307 RTC *
    ' PIC16F877A @ 4MHz
    'DEFINE LOADER_USED 1 ' Comment out if not using boot-loader
    INCLUDE "modedefs.bas"
    ' Set up 16x2 LCD Display
    output PortE.2
    output PortC.0
    output PortC.1
    output PortC.2
    output PortC.3
    output PortC.4
    DEFINE LCD_DREG PORTC 'Set LCD Data port
    DEFINE LCD_DBIT 0 'set start data bit 0 or 4
    DEFINE LCD_RSREG PORTC 'set LCD Register select port
    DEFINE LCD_RSBIT 4 'set LCD Register select bit
    DEFINE LCD_EREG PORTE 'LCD Enable port
    DEFINE LCD_EBIT 2 'LCD enable bit
    DEFINE LCD_BITS 4 'set LCD BUS size 4 or 8
    DEFINE LCD_COMMANDUS 2000 ' set command delay time us
    DEFINE LCD_ DATAUS 50 'set data delay time us
    ' Note: use 10K pull-up resistors on both SDA and SCL i2C lines
    ' DS1307 control pins
    SDA VAR PORTB.0 ' DS1307 SDA pin #5
    SCL VAR PORTB.1 ' DS1307 SCL pin #6
    ' Variables
    DB0 VAR BYTE[8] ' time date , data byte array
    keypress var byte
    Countvalue var byte
    Countvalue1 var byte
    Countvalue2 var byte
    Countvalue3 var byte
    Countvalue4 var byte
    Year var BYTE
    'Alias
    Hours var DB0[2] 'hours
    Mins var DB0[1] 'minutes
    Secs var DB0[0] 'seconds
    Day var DB0[3] 'day of week 0 = Sunday
    Days var DB0[4] 'day of month
    Months var DB0[5] 'month
    Years var DB0[6] 'year starting at 0 (2000)
    Square var DB0[7] '= $90 Square wave output control byte
    'Symbols
    Symbol row1 = PortD.0
    Symbol row2 = PortD.1
    Symbol row3 = PortD.2
    Symbol row4 = PortD.3
    Symbol col1 = PortD.4
    Symbol col2 = PortD.5
    Symbol col3 = PortD.6
    Symbol col4 = PortD.7
    SyMbol Print = PortB.3
    SyMbol Auto = PortB.4
    SyMbol Tare = PortB.5
    SyMbol Trip1 = PortB.2
    SyMbol Trip2 = PortB.6
    ' Port configuration
    TRISC = %00000000
    TRISB = 0
    TRISA = 0
    CMCON = %00000111 ' Comparators = off
    input portb.4
    input portb.3
    input portb.2
    input portD.0
    input portD.1
    input portD.2
    input portD.3
    high PortD.4
    high PortD.5
    high PortD.6
    high PortD.7
    low PortB.2
    Low PortB.6
    Countvalue1 = 0
    Countvalue2 = 0
    Countvalue = 15
    Hours = 21
    Mins = 59
    Secs = 38
    Days = 22
    Months = 5
    Year = 0
    Years = 6
    PAUSE 1000 ' Allow power to stabilize on power-up
    ' 24-hour clock routine for the DS1307 RTC w/SLED4C clock display
    Gosub get_button
    lcdout $fe,1, #keypress
    lcdout $fe,$C0,hex keypress
    'gosub SetTimeHrs
    ' if keypress = 12 then gosub SetTimeHrs
    GOSUB Write_First_1307 ' Write time & date on entry coment out after setting initial time
    ' or if using keypad to set time
    'goto main
    Read_1307:
    ' Read time Secs,Mins,Hours,Day,Date,Month,Year,Control
    I2CREAD SDA,SCL,$D0,$00,[STR DB0\8] ' Read 8 bytes from DS1307
    Gosub get_button
    if tare = 0 then gosub tareval
    IF auto = 1 then gosub trip_off
    'lcdout $fe,1,#DB0[2],#DB0[1],#DB0[0]
    'lcdout $fe,$C0,#DB0[4],#DB0[5],#DB0[6]
    GOSUb Year_Table
    lcdout $fe,1,"TIME=",dec DB0[2],".",dec DB0[1],".",dec DB0[0]
    'lcdout $fe,$C0,"DATE=",hex DB0[4],".",hex DB0[5],".20",dec year ,dec DB0[6]
    lcdout $fe,$C0,"DATE=",dec DB0[4],".",dec DB0[5],".20",dec year,dec DB0[6]
    if KeyPress = 4 then SetTimeMins
    if KeyPress = 5 then SetTimeHrs
    if KeyPress = 6 then SetTimeDays
    if KeyPress = 7 then SetTimeMonths
    if KeyPress = 8 then SetTimeYears
    PAUSE 2000 ' Display time for 2 seconds
    GOTO Read_1307 ' Read & display Time
    Write_First_1307:
    I2CWRITE SDA,SCL,$D0,$00,[STR DB0\8]
    I2CWRITE SDA,SCL,$D0,$00,[$00,Mins,Hours,$0,Days,Months,Years,$90] ' Write to DS1307
    RETURN ' Sec Min Hr Day D M Y Control
    tareval: high Trip1
    high trip2
    lcdout $fe,1, " Trips on "
    trip_off: LOW Trip1
    LOW trip2
    lcdout $fe,1, " Trips off "
    SetTimeHrs:
    Gosub get_button
    if KeyPress = 10 then Hours = Hours + 1
    if KeyPress = 13 then Hours = Hours - 1
    If Hours > 24 then Hours = 0
    If Hours < 0 then Hours = 24
    'Hours = Countvalue
    lcdout $fe,1, "Set Hours 0-24" ' top line text
    lcdout $fe,$C0, "Hours =", dec Hours ' bottom line text
    SEROUT PortC.6,T9600,[#Hours,13,10]
    If Keypress = 12 then Gosub Write_1307
    If Keypress = 11 then return
    goto SetTimeHrs
    SetTimeMins:
    Gosub get_button
    if KeyPress = 10 then Countvalue = Countvalue + 1
    if KeyPress = 13 then Countvalue = Countvalue - 1
    If countvalue = 60 then Countvalue = 0
    If countvalue < 0 then Countvalue = 0
    Mins = Countvalue
    lcdout $fe,1, "Set Mins 0-60" ' top line text
    lcdout $fe,$C0, "Minutes =", dec Countvalue ' bottom line text
    SEROUT PortC.6,T9600,[#countvalue,13,10]
    If Keypress = 11 then Gosub Write_1307
    goto SetTimeMins
    SetTimeDays:
    Gosub get_button
    If countvalue = 31 then Countvalue = 0
    If countvalue < 0 then Countvalue = 31
    Days = Countvalue
    lcdout $fe,1, "Set Day 1-31" ' top line text
    lcdout $fe,$C0, "Day =", dec Countvalue ' bottom line text
    goto SetTimeDays
    SetTimeMonths:
    Gosub get_button
    If countvalue = 12 then Countvalue = 0
    If countvalue < 0 then Countvalue = 12
    Months = Countvalue
    lcdout $fe,1, "Set Month 1-12" ' top line text
    lcdout $fe,$C0, "Month =", dec Countvalue ' bottom line text
    goto SetTimeMonths
    SetTimeYears:
    Gosub get_button
    If countvalue = 25 then Countvalue = 0
    If countvalue < 0 then Countvalue = 25
    Years = Countvalue
    gosub year_table
    lcdout $fe,1, "Set Year 7-25" ' top line text
    lcdout $fe,$C0, "Year = 20",dec year, dec Countvalue ' bottom line text
    goto SetTimeYears
    Write_1307:
    'I2CWRITE SDA,SCL,$D0,$00,[STR DB0\8]
    get_button:
    KeyPress = 0
    col1 = 1
    If row1 = 1 Then KeyPress = 1
    If row2 = 1 Then KeyPress = 4
    If row3 = 1 Then KeyPress = 7
    If row4 = 1 Then KeyPress = 0
    col1 = 0
    col2 = 1
    If row1 = 1 Then KeyPress = 2
    If row2 = 1 Then KeyPress = 5
    If row3 = 1 Then KeyPress = 8
    If row4 = 1 Then KeyPress = 15 'F
    col2 = 0
    col3 = 1
    If row1 = 1 Then KeyPress = 3
    If row2 = 1 Then KeyPress = 6
    If row3 = 1 Then KeyPress = 9
    If row4 = 1 Then KeyPress = 14 'E
    col3 = 0
    col4 = 1
    If row1 = 1 Then KeyPress = 10 'A
    If row2 = 1 Then KeyPress = 11 'B
    If row3 = 1 Then KeyPress = 12 'C
    If row4 = 1 Then KeyPress = 13 'D
    col4 = 0
    year_table:
    if DB0[6] = 7 then year = $0
    if DB0[6] = 8 then year = $0
    if DB0[6] = 9 then year = $0
    Jan 2006
    Istanbul
    In your code, where do you convert your values to HEX?
    I could not find it, or see it.
    (May be it is me...ohh these days I am feeling older (and elder) every passing second. )
    Jun 2006
    Glasgow, Scotland
    Thumbs up
    good point I what is the best way to convert it Hours = #Hours ?
    would that work?
    I apologise for my ignorance but I have just started with picbasic pro.
    kind regards John
    Feb 2005
    Kolkata-India
    Question Am I missing something too ?
    As far as I remember the RTC holds the time in packed BCD format. That is the upper nibble is the tens and the lower nibble is the unit. So the formula to convert it would be
    Real_Hours = (10* hour_tens)+ hour_units
    In PBP this would be :
        CLOCK_TMP1 = (HOURS >> 4) * 10              ' PROCESS 10s BCD
        HOURS    = HOURS & %00001111                 ' PROCESS 1s BCD
        HOURS    = CLOCK_TMP1+ HOURS                ' ADD BOTH TO GET BINARY
    Where CLOCK_TMP1 is a temporary variable. You can do it in one line to. I broke up the thing to make it more readable
    While working on a PCF8563 RTC chip I noticed that the unused bits in the memory map are not always "zero". Thus it is good idea to shred off the bits not used and make them zero manually. Like:
          HOURS   = HOURS     & %00111111             ' clear unused bits
          MINUTES = MINUTES & %01111111             ' clear unused bits
    Happy New Year
    Sougata
    Jan 2006
    Istanbul
    In addition to sougata's, here is a conversion from Melanie's.
    You need to convert your decimal values to HEX values and then you can write the HEX values to your RTC chip.
    DecVal = HOUR
    GOSUB ConvertBCD
    HOUR = HEXVal
    'Now you set your RTC chip with this new HOUR variable (which is now in HEX).
    ConvertBCD:
            HEXVal = DecVal DIG 1
    	HEXVal = HEXVal <<4
    	HEXVal = HEXVal + DecVal DIG 0
    Edit: also take a look at this post here: http://www.picbasic.co.uk/forum/showthread.php?t=110
    Jun 2006
    Glasgow, Scotland
    Thanks again Guy's got the clock working fine writing and reading from the RTC chip.
    Last Post: - 14th June 2016, 08:55
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 05:46
  3. Array larger than 256 bytes
    By Ron Marcus in forum mel PIC BASIC Pro
    Last Post: - 27th November 2005, 16:38
  4. Inverting a Word & Assigning Array To Bytes
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 26th August 2005, 00:44
  5. Best way to store array of bytes?
    By Deadeye in forum General
    Last Post: - 1st June 2005, 06:35
