Measuring Battery voltage
Results 1 to 3 of 3
    Mar 2004
    UK-Midlands
    Default Measuring Battery voltage
    Hi all,
    I want my cake and eat it too!
    I need to monitor the battery voltage powering a Pic (16F876) circuit. The voltage swing is around 4.5v to 3.3v. The problem is the batteries are small "AAA" size and the PIC 'sleeps for 99.9% of the time. What is the best way (if any) for the PIC to periodically monitor the battery without the measuring circuit draining the battery all the time?
    I thought of switching the battery voltage to a circuit but not sure how the switching transistors voltage drop would affect the measurment, for example with temprature?
    Bob
    use a timer (watchdog) interrupt + resistive voltage divider. one side of your voltage divider go to the battery, the other side (wich is suppose to go to GND) will go on a extra I/O. When your PIC wake up of the timer interrupt or sleep, or WDT or whatever else, you configure this i/o as output and send this PIN to GND, then take the battery reading. Once done, you turn this i/o to input and go back to sleep.
    Another method is to use high value resistors (few hundreds Kohms) and use analog comparator interrupt.
    16F876 is probably not the best choice for a battery opeated system. a LF serie could be better. 18F even better.
    Mar 2004
    UK-Midlands
    Thanks Mister e,
    I was thinking of switching the 5v to it but your solution is better. The Pic I was intending to use was the LF version.
    But any pointers on a better 18F part with similar ports and pinouts would be appreciated. I now get confused by the seemingly massive choice of parts.
    Is there a group of 18F parts that are commonly used?
    Bob
  1. Voltage monitor for car battery
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2008, 21:47
  2. Expanded Scale Voltmeter
    By Pic_User in forum Schematics
    Last Post: - 8th February 2008, 20:32
  3. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 20:35
  4. Help with setting adcon1 for 16f877
    Last Post: - 16th August 2005, 11:13
  5. measuring input voltage
    By thon in forum mel PIC BASIC Pro
    Last Post: - 11th August 2004, 16:03
