Interrupts using a 16F877
Results 1 to 2 of 2
    Niall's Avatar
    Niall Guest
    Question Interrupts using a 16F877
    Greetings,
    I am using Letbasic 7.1 and have had success using interrupts on the 16F84. My main use is via TMR0 roll-over and the first time I used Interrupt.bas supplied by letbasic. However, this will not assemble when the device chosen is the 16F877, claiming duplicate or missing lables for all lables used in the entire program. Actually, none of the interrupt programs will assemble under the 16F877.
    Looking forward to the solution,
    Niall.
    Wrong forum for Let Basic.
    This is for MELabs PICBasic and PICBasic Pro.
    Try http://www.letbasic.com/
    Melanie
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  2. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  3. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 15:10
  4. Interrupts and Disable 16f877
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 18th April 2005, 21:08
  5. 16f877 port configuration & interrupts
    Last Post: - 15th April 2005, 17:30
