Inconsistent output on a 4x4 matrix keypad
Results 1 to 13 of 13
    Ohio
    Default Inconsistent output on a 4x4 matrix keypad
    I am using the code listed below. It is wired per this website http://rentron.com/serkey16.htm. The output from the keypad is inconsistent. Sometimes the output is correct and sometimes the output will give the correct Column but not the correct Row. Does anybody have any ideas on why this is happening?
    Mark
    '* Name: Turret Controller Keypad *
    '* Micro: 18F452 *
    INCLUDE "modedefs.bas"
    define OSC 20
    define LOADER_USED 1 ' bootloader
    col VAR BYTE ' Keypad column
    row VAR BYTE ' Keypad row
    key VAR BYTE ' Key value
    baud VAR PortA.0 ' Baud select pin
    serpin VAR PortA.1 ' Serial output pin
    ADCON1 = 7 'set I/O pins to digital on PORT.A
    TRISA = %00000001' PortA.0 = baud select pin
    INTCON2.7 = 0 ' Enable PORTB weak pull-ups
    B0 Var Byte
    loop:
    GOSUB getkey 'Get key from keypad
    send:
    'IF baud = 1 THEN fast'If baud = 1 then N9600,else N2400
    SEROUT serpin,N2400,[key,B0]'Send key value out PortA.1
    GOTO loop
    getkey:
    PAUSE 50 'Debounce key-input
    getkeyu:' Wait for all keys up
    PORTB = 0 ' All output-pins low
    TRISB = $f0 ' Bottom 4-pins out, top 4-pins in
    IF ((PORTB >> 4) != $f) THEN getkeyu'If keys down, loop
    PAUSE 50 ' Debounce key-input
    getkeyp:' Wait for keypress
    FOR row = 0 TO 3 ' 4 rows in keypad
    TRISB = (DCD row) ^ $ff ' Set one row pin to output
    col = PORTB >> 4 ' Read columns
    IF col != $f THEN gotkey' If any keydown, exit
    NEXT row
    GOTO getkeyp ' No keys down, go look again
    gotkey: ' Change row and column to key number 1 - 16
    key = (row * 4) + (NCD (col ^ $f))
    'NOTE: for 12-key keypad, change to key = (row * 3)
    RETURN ' Subroutine over
    Hi Mark. I use a 4x4 matrix to address an ISD chip to record & play messages. This is a piece of the routine I use to test the matrix. All of portb is held high with a resistor network. Maybe it will help with your problem.
    TESTCELLS:
    Low PORTC.1 'COLUMN 1
    Pause 1
    IF PORTB.4 = 0 THEN MESSAGE 1 'ROW 1
    IF PORTB.5 = 0 THEN MESSAGE 2 'ROW 2
    IF PORTB.6 = 0 THEN MESSAGE 3 'ROW 3
    IF PORTB.7 = 0 THEN MESSAGE 4 'ROW 4
    High PORTC.1
    Low PORTC.2 'COLUMN 2
    Pause 1
    IF PORTB.4 = 0 THEN MESSAGE 5 'ROW 1
    IF PORTB.5 = 0 THEN MESSAGE 6 'ROW 2
    IF PORTB.6 = 0 THEN MESSAGE 7 'ROW 3
    IF PORTB.7 = 0 THEN MESSAGE 8 'ROW 4
    High PORTC.2
    Low PORTC.6 'COLUMN3
    Pause 1
    IF PORTB.4 = 0 THEN MESSAGE 9 'ROW 1
    IF PORTB.5 = 0 THEN MESSAGE 10 'ROW 2
    IF PORTB.6 = 0 THEN MESSAGE 11 'ROW 3
    IF PORTB.7 = 0 THEN MESSAGE 12 'ROW 4
    High PORTC.6
    Low PORTC.7 'COLUMN 4
    Pause 1
    IF PORTB.4 = 0 THEN MESSAGE 13 'ROW 1
    IF PORTB.5 = 0 THEN MESSAGE 14 'ROW 2
    IF PORTB.6 = 0 THEN MESSAGE 15 'ROW 3
    IF PORTB.7 = 0 THEN MESSAGE 16 'ROW 4
    High PORTC.7
    GoTo TESTCELLS
    Ohio
    Hi Peterdeco1,
    I appreciate the feedback but unfortunately I have made a circuit board for this design which is already installed in a piece of equipment. If I cannot get this to work I’ll give your idea a try.
    Mark
    Alternative...
    include "C:\PBP_PROG\INCLUDE_ROUTINES\KeyPad.bas"
    define OSC 20
    DEFINE HSER_SPBRG 129 ' 9600 Baud @ 0.16%
    DEFINE KEYPAD_ROW        4        ' 4 ROW keypad
    DEFINE KEYPAD_ROW_PORT   PORTB    ' ROW port = PORTB
    DEFINE KEYPAD_ROW_BIT    0        ' ROW0 = PORTB.4
    DEFINE KEYPAD_COL        4        ' 4 COL keypad
    DEFINE KEYPAD_COL_PORT   PORTB    ' COL port = PORTB
    DEFINE KEYPAD_COL_BIT    4        ' COL0 = PORTB.0
    DEFINE KEYPAD_DEBOUNCEMS 200      ' debounce delay = 200 mSec
    DEFINE KEYPAD_AUTOREPEAT 1        ' use auto-repeat feature
    INTCON2.7=0
    kKey    var byte
    Start:
        @ READKEYPAD _kKey
        hserout ["Key=",dec kkey,13,10]
        goto start
    Just modify the include to suite your requirement
    kEYpAD.BAS... AVAILABLE BELLOW
    http://www.picbasic.co.uk/forum/showthread.php?t=3250
    and IN YOUR serout LINE...
    SEROUT serpin,N2400,[#key,#B0]'Send key value out PortA.1
    AND now that some know you experiment a Write/Read/Modify behaviour... use your existing code but modify it like
        LATB = 0 ' All output-pins low
    @   nop
    @       nop
            NEXT row
    What happen now ?
    Ohio
    I'll give it a try.
    Mark
    If you still have problem after Steve's suggestions, please check the circuits. Better send the circuit here to see how you connected the buttons to the PIC. I suspect noise from some lines.
    FYI, using his code, i had similar problem as markcadam, so i decide to use my 'easy to use' INCLUDE with the same PIC and crystal... confirm that my hardware was good (EasyPIC4 + Keypad 4X4 adapter). Worked with internal pull-up AND external (of course).
    Then i worked around his code. Use LATB intead of PORTB to write to the port for safety sake. On a whole port write, it doesn't really matter.. but when you write to few bit .. it may cause some problem. In this case leaving PORTB AS IS, will work anyways.
    Writing to PORT before TRIS is also for safety sake even if some don't believe it But if you leave it like this... it still working.. but sometimes you have some screwed values
    BUT the real magic is in the @ nop. remove those lines and the readings are screwed up.. or intermittent. just by this famous PIC18Xxxxx feature called 'Read/Modify/write' behaviour.
    18Fs are much noise sensitive.. so i would avoid to use internal weak-pull-ups... IMHO.. you know i hate those anyways
    mmm, just double/triple/quad check the whole thing...
    it appear that the TRIS work better if before the PORT/LATB line ....DOH!
    BUT if you want to use the 'Microchip says' approach (write to PORT before TRIS), replace @ nop by @ GOTO $+2
    That way... it works ... a treat
    M.F.Sorry!
    Hi Steve. Doesn't @ GOTO $+2 being equal to jump to next instruction? Also the same as NOP. So whats the difference?
    ASM GOTO need 2 cycle to execute, NOP only 1 cycle
    Yeap. You are right. Its a typical delay then...
    Ohio
    I believe I found the problem. This circuit was designed for a 4Mz crystal and I am running it at 20Mz. I added a 'PAUSE 1" after the line 'TRISB = (DCD Row) ^ ff' to slow it down and this seems to of fixed the problem.
    Thanks for everbodys help,
    Mark
    That's what @ GOTO $+2 did... but 2500 times faster
    also try with shorter PAUSEUS. PAUSEUS 5 should also work...
  1. Matrix Keypad routine
    By mister_e in forum Code Examples
    Last Post: - 18th September 2022, 20:30
  2. 4x4 keypad Help
    By aaliyah1 in forum mel PIC BASIC Pro
    Last Post: - 5th October 2010, 16:34
  3. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 13:16
  4. Serious Serial Situation Setbacks...
    By Dansdog in forum mel PIC BASIC Pro
    Last Post: - 7th February 2007, 03:46
  5. I2C PCF8574 4X4 Keypad routine
    By RFsolution in forum mel PIC BASIC Pro
    Last Post: - 28th January 2007, 21:25
