HPWM question
Results 1 to 4 of 4
Thread: HPWM question
    Oct 2003
    Australia
    Default HPWM question
    Howdy,
    I have a project in mind that could use the hpwm on my pic 16F628.
    Unfortuantley I ma getting pretty confused by the data sheet and would like some help getting started.
    For example, what code is required to generate a 1KHz / 50% duty cycle pulse train? This is what I have so far:
    <table border=1><tr><td><b>CMCON</b> = 7
    <b>DEFINE</b> OSC 4
    PAUSE 1000
    <b>HPWM</b> 1,127,1000
    </td></tr></table>
    Step by Step...
    Firstly Defines come first... by default PBP assumes 4MHz clock, so you don't need to have a DEFINE OSC statement unless your clock is other than 4MHz.
    Secondly, let's set the PIC up for internal oscillator and no MCLR (MCLR pin can be used as an Input)...
    @ DEVICE pic16F628, INTRC_OSC_NOCLKOUT
    ' System Clock Options
    @ DEVICE pic16F628, WDT_ON
    ' Watchdog Timer
    @ DEVICE pic16F628, PWRT_ON
    ' Power-On Timer
    @ DEVICE pic16F628, MCLR_OFF
    ' Master Clear Options (Internal)
    @ DEVICE pic16F628, BOD_ON
    ' Brown-Out Detect
    Now we have our PIC configured, we need to configure the pins... let's say we want a Blinky LED on PortB.0 and of course our HPWM will fall out of PortB.3...
    LED var PortB.0
    ' Put a LED on this Port Pin
    CMCON=7
    ' This assigns all pins Digital but it only affects PortA, so if
    ' you're not bothered with PortA this is irrelevant
    TRISB=%00000000
    ' I've assigned ALL of PortB as Output,
    ' I only need to have done that for B.0 and B.3
    Pause 200
    ' A large Pause at startup is only needed to wake-up sluggish
    ' external devices like LCD's...
    HPWM 1,127,1000
    ' Yup, this will give 1kHz at 50% Duty
    Loop:
    Toggle LED
    Pause 500
    Goto Loop
    This blinks an LED (somebody else wanted to know how to set up a 16F628 to do that so it answers that query as well), while at the same time it will permanently output your PWM train in background.
    Melanie
    Oct 2003
    Australia
    Thanks Mel. Great explanation.
    Cheers
    Oct 2003
    Australia
    Mel,
    I have found that those defines work a treat when programming the pic.... I have been setting those rotten fuses manually for so long.
    I use Microcode studio, and in it's PBP manual
    (help topics) there is no mention of the below @DEVICE commands.
    Silly question, but where can I find a list of these @DEVICE commands?
    Cheers
    I just read the 16F629 Post!.... Ouch!
  1. HPWM question
    By sjmusic2 in forum mel PIC BASIC Pro
    Last Post: - 20th May 2009, 19:50
  2. Multiple HPWM question
    By Johan in forum mel PIC BASIC Pro
    Last Post: - 17th October 2007, 13:00
  3. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 14:14
  4. HPWM and A to D interaction question 18F252
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 10th May 2006, 03:50
  5. 3 HPWM channels
    Last Post: - 4th April 2006, 02:43
