using TOCK pin as output?
Results 1 to 6 of 6
    Nov 2004
    Calabasas, CA
    Default using TOCK pin as output?
    Can the A.4/TOCK pin of a 16C716 be used as an LCD (serial) output? Something is unique about this pin/setup? Doesn't seem to work as other pins.
    thanks
    James
    Or it's only an input AND/OR it's an open drain type AND/OR there's some analog stuff multiplex wich have to be disable. The datasheet will give you the answer(s).
    Nov 2004
    Calabasas, CA
    Pin RA4 is multiplexed with the Timer0 module clock
    input to become the RA4/T0CKI pin. The RA4/T0CKI
    pin is a Schmitt Trigger input and an open drain output.
    All other RA port pins have TTL input levels and full
    CMOS output drivers.
    I have to see if the Timer0 module clock input which this pin MUX's with is enabled I believe. I don't know what role the open drain output has if any on the serout?
    James
    place a 1K pull-up resistor to this pin and post your results.
    Nov 2004
    Calabasas, CA
    Pin RA4 is multiplexed with the Timer0 module clock input to become the RA4/T0CKI pin. The RA4/T0CKI pin is a Schmitt Trigger input and an open drain output.
    I cannot determine by the data sheet, if the peripheral is enabled by default, and if so, how to disable. This being figured out, will the above description support the desired function, that is open drain output to serout an LCD command?
    James
    Nov 2004
    Calabasas, CA
    Yes, it works. This is because the pin has an open drain output rather then the usual bipolar stage of the rest of the output pins. This means it can pull to ground when set to 0, but it will simply float when set to a 1, instead of going high. Somewhat confusing in the data sheet, I believe this is not an optional analog pin, as the rest of PORTA.
    James
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  2. Help changing CCP3 output pin
    By ChrisHelvey in forum mel PIC BASIC Pro
    Last Post: - 15th July 2008, 03:30
  3. Microcontroller with 2 way paging application problem
    Last Post: - 20th April 2007, 18:27
  4. Serious Serial Situation Setbacks...
    By Dansdog in forum mel PIC BASIC Pro
    Last Post: - 7th February 2007, 04:46
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
