+ Reply to Thread
Page 2 of 2 FirstFirst 12
Results 41 to 69 of 69
  1. #41
    Feb 2003
    Sydney, Australia
    Thanks guys,
    I knew someone would have it !
    Now to work out how to to 10mS int's on a 18f2550 running at 48MHz !!
    Bill
  2. #42
    Sep 2008
    Stockholm
    Stuopid me, athat didnt read all posts before replying.. :/
  3. #43
    Talking
    Thanks Alain!
    No,No ... Steve
    Thanks are for you !!!
    Best regards
  4. #44
    Default Re: New PIC Utility. PICMultiCalc
    PICMultiCalc gets runtime errors in windows 7.
    Is their a newer version than 1.3.1?
    This is a much used utility and an update would be appreciated.
    Norm
  5. #45
    Hi Norm,
    I run it on Win7-64bit and don't get any runtime (or other) errors. I don't know what version I'm running but I can check tonight. If you haven't already tried it, try running it as administrator and see if that help. I've had several apps where doing that is neccessary for it to work.
  6. #46
    Hi Norm,
    ...try running it as administrator and see if that help. I've had several apps where doing that is neccessary for it to work.
    Running as administrator didn't help in 32 bit windows 7 professional.
    I have the following NET's installed by default in case this is a Microsoft VB supportive files issue:
    Microsoft® .NET Framework Version 2.0.50727.4927
    Microsoft® .NET Framework Version 3.0.6920.4902
    Norm
  7. #47
    Hi Norm,
    I had problems installing on win98 required a file not in win98, got it off the net.
    Have you tried to run in compatibility mode ?
  8. #48
    Tried compatibility mode, no luck.
    Tried installing missing files found in XP but no luck.
    Norm
  9. #49
    Hi Norm,
    I'm running 1.3.0.1 and, like I said, I don't have any problems with on Win7 64bit. It's been over a year since I installed this machine so I'm not sure if I HAD any problems getting it running but I don't think I did.
    I know it's not much help but anyway....
    Maybe I could try copy and paste of the missing MSSTDFMT.DLL
    In XP it's located in X:\Windows\System32
    Is the same true in Windows7?
    Norm
  11. #51
    Win7 64 bit using PicMultiCalc just fine.
    When I searched my system for MSSTDFMT.DLL all I got was
    tweak_xp.xml
    it has this line
    %SYSTEM%\CPUINFO2.DLL %SYSTEM%\hxphk.ocx %SYSTEM%\MSGHOO32.OCX %SYSTEM%\MSINET.OCX %SYSTEM%\msstdfmt.dll %SYSTEM%\MSWINSCK.OCX
    the file is located here on my machine.
    C:\Program Files (x86)\Common Files\Seagate\BackupScripts
  12. #52
    On my system that file is located in the WOW64 folder but mine is 64-bit as well. Unfortunately I don't know where it would default to on a 32-bit Win-7 installation. I feel your pain Norm and I'm sorry I can't be of more help.
    I had to download & install Microsoft ActiveX control Pad to get LCD tool working.
    I had to download & register MSSTDFMT.DLL to get Timer tool working.
    All tools worked after that.
    Nice utility, I had the old SPBRG version.
  14. #54
    If you get this in Win 7 64bit:
    ActiveX Control Pad Setup:
    the app was unable to start correctly (0xc0000142)
    Run in XP compatibility mode.
    To register MSSTDFMT.DLL in Win 7 64bit:
    - download the file from microsoft.
    - copy to C:\Windows\SysWOW64 folder
    - RUN REGSVR32 C:\Windows\SysWOW64\MSSTDFMT.DLL
  15. #55
    It is surprising, but on my new and fresh Win7-64Bit system, with no VB studio installation if that matters, I did nothing special. Just executed the Steves nice job. It runs with no error messages!
    Lucky me
    I don't have VB6, MCSP, PBP or anything else programming-oriented on the Win 7 64-bit system yet either; just FS-X, PSP-XI, Open Office and Turbocad 11.
    I bet you have software that already have those DLL included.
    But cannot tell which...
    Jul 2005
    Palmdale, CA
    When I try to run the calculator, I get a 'runtime error 7' out of memory
  19. #59
    And the OS is?
  20. #60
    Some reading for the error from google here:
    http://ezinearticles.com/?How-to-Fix...ory&id=4867634
    I may still have the full installation package. Just PM me your e-mail.
  22. #62
    I just stumbled upon this problem on my Windows10 machine, ie where PICMultiCalc wouldn't run due to missing MSSTDFMT.DLL
    It's very strange because I've had this machine up and running for several months and can't Believe I've not had to use PICMultiCalc on all this time. Anyway, the fix is as above but it took some additional steps to get it to work on my machine.
    * I had to start Windows10 in fail safe mode in order to be able to actually copy MSSTDFMT.DLL to the SysWoW64 folder.
    * Run the command prompt as Administrator
    * Exectute the command %systemroot%\SysWow64\regsvr32 c:\Windows\syswow64\msstdfmt.dll
    This succesfully registred MSSTDFMT.DLL and PICMultiCalc works again.
    can you get the PICMultiCalc-lcd custom lcd generator to work . that has issues too
    wants fm20.dll .
    works on the 32 bit w10 laptop but not on the 64 bit machine
  24. #64
    Jan 2006
    Istanbul
    wants fm20.dll .
    Steve's LCD custom char generator works on my 64-bit Win10 here.
    Must be something else.
  25. #65
    On my system everything in PICMultiCalc works - except the LCD character generator (which I've never used). It throws the same error as Richard reports.
    Do you have FM20.dll on your system Sayzer?
    If you do, would you mind posting it (I know it might not be 100% kosher doing so but anyway...)
    Or, to Richard, if you have the FM20.dll file on your 32bit system would you mind posting it?
    I'm reluctant to download such file from random sites on the internet.
    My 64 bit pc has file in windows\system32 folder but it does not want to know about it ,
    might try copying it to syswow64 later , it might load up if registered there
    can't upload it to forum it exceeds upload limit
  27. #67
    Jan 2006
    Istanbul
    Thumbs up Re: New PIC Utility. PICMultiCalc
    There are two files, FM20 and FM20ENU.
    MultiCalc needs both.
    It appears that my FM20 files came from MS Office XP installation; yours might come from somehwere else.
    Attached is a rar file; just rename txt to rar.
    Includes both files.
  28. #68
    Thank you Sayzer for uploading the files. I managed to get it working by basically doing the same things as with MSSTDFMT.dll, namely this:
    Copy the files to the SysWow64 folder (again I had to revert to safe mode in order to be able to do this).
    Run a command prompt as adminstrator and register the fm20.dll using the 32bit version of regsrv32 (which, sort of conunterintuitively, is the one residing in the SysWow64 folder and not the one in the System32 folder) by executing the command:
    %systemroot%\SysWow64\regsvr32 c:\Windows\syswow64\fm20.dll
    After doing this the LCD portion of PICMultiCalc seems to work as expected which either means that I already had an registred version of FM20ENU.dll somewhere on my system or it isn't actually needed for some other reason - or there might still be some feature in PICMultiCalc that doesn't work which I have not discovered yet. I'll just leave it alone for now.
    Feb 2008
    Michigan, USA
    Thank you for the guidance. MSSTDFMT.dll seems to make everything happy again. Registering the .dll was especially helpful.
    Once again, the forum to the rescue.
    bo
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. Replies: 67
    Last Post: - 8th December 2009, 02:27
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
Members who have read this thread : 33
