I wrote a program that uses Darrel's instant interrupt. It was work perfectly. But, I accidently overwritted it. =( I am so dumb. But anyway, this is the problem I'm having since I rewrote the program...
define OSC 20
define LCD_EREG PORTE
define LCD_EBIT 0
define LCD_DREG PORTD
define LCD_DBIT 4
define LCD_LINES 4
define ADC_BITS 8
define ADC_CLOCK 3
define ADC_SAMPLEUS 100
define BUTTON_PAUSE 300
INCLUDE "DT_INTS-14.bas" ' Base Interrupt System
INCLUDE "ReEnterPBP.bas" ' Include if using PBP interrupts
INT_Handler RBC_INT, _ToggleLED2, PBP, yes
INT_Handler INT_INT, _ToggleLED1, PBP, yes
TRISB = %11100001
@ INT_ENABLE RBC_INT
@ INT_ENABLE INT_INT ; enable external (INT) interrupts
Lcdout $FE, 1, "HELLOW WORLD"
LCDOUT $FE, $C0
PAUSE 100
GOTO Main
'---[INT - interrupt handler]---------------------------------------------------
ToggleLED2:
lcdout "no"
@ INT_RETURN
ToggleLED1:
lcdout "hi"
@ INT_RETURN
The program compiles fine, but when ever I turn on my circuit, RBC_INT is constantly interrupting. All i see is "nonononono..." on my lcd. I cant figure out why it is doing this since I did not change any hardware. Then, I reloaded my old hex file of my previous working program and RBC_INT works fine and does not constantly interrupt. I have no idea what is causing this. Please help me =(
I forgot to say that portb0, portb5-7 are all pulled down and connected to a momentary buttons to 5V.
