Easy LCD Contrast
Results 1 to 9 of 9
    Default Easy LCD Contrast
    Here's a useful and very simple way of controlling the contrast on an LCD with just two Resistors and a line of code. If the PIC in your project has an unused available PWM channel (eg 16F628, F876 etc etc), then this will enable you to control your LCD's contrast over it's usable range and at absolute minimum cost.
    HPWM 1,Contrast,1000
    Where Contrast is a byte variable in the range 0-125. Steps of 25 seem to be adequate (ie Contrast=0, 25, 50, 75,100 or 125) where zero is maximum and 125 is minimum. Stepping above 125 is pointless as your display will disappear into obscurity.
    The value for Resistors R1 and R2 I've set at 1K5, mainly because I've been told we have almost 2 million of that value in stock and please can I find a way of getting rid of them. Decreasing R2 to say 680R will increase the bottom-end contrast, but the software variable Contrast might need larger steps (say steps of 40) and increased span (eg 0-240).
    You really don't get much cheaper or simpler than this...
    Melanie
    Aug 2003
    Thanx Melanie,
    I will be able to try that out in my current project which is a
    2x16 LCD. I'm not worried about a few dollars/cents for a trimpot,
    but any saving of space on any PCB is a blessing, and so is
    software control over hardware
    Art.
    California, USA
    Default Thanks Melanie!
    Well it's just amazing how simple and easy that is!
    Works Great!
    steve
    May 2007
    Will this work with a graphic LCD?
    If your LCD's Contrast is adjusted the same way as in a standard LCD, then yes. Just try it - you have nothing to lose but a few minutes out of your life.
    There's a lot of goodies buried in this forum, you just have to dig around a little.
    Good to have your vote of confidence Steve. *smiles*
    May 2007
    OK, thanks.
    Feb 2012
    PERTH AUSTRALIA
    Default Re: Easy LCD Contrast
    all your timers are in use
    ccp1 can use timer 1 or 2 , and ccp2 can use timer 1 or 2 , since you have used both timers else where u need a chip with more timers for another pwm output
    i would look at using an 18f device , that includes a lot more for the very simular price
    i would recommend the 18f26k22 or 18f26k80( FOR 12BIT ADC) for a 28pin device , or if you like perhaps go 48pin 18f46k22
    for About the same pricing , it supports alot more timers , 4 PWM PORTS min
    Sao Paulo - Brazil
    Thank you friend !
    I have some 18f2520 gere with me. I'll tive a try !
    Thank you again !
  1. 16f688 LCD what have I done wrong
  2. Need help with LCD number display.
  3. LCD will not start
  4. How to change contrast LCD?
    By MCU Destroyer in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2005, 13:16
  5. Easy LCD BackLight
    By Melanie in forum Schematics
    Last Post: - 17th October 2004, 13:18
