LCD 16 characters inline: only first 8 work
Results 1 to 6 of 6
    Oct 2006
    Germany: Coal Area
    Default LCD 16 characters inline: only first 8 work
    Hi You all!
    read this forum a couple of times and was very interested.
    I´m kinda novice but WANT to work with this great picbasic pro.
    So my simple problem ist this:
    my LCD Display 1x16 works only on the first 8 Characters. I guess I did anything wrong with my Defines.
    ' DEFINITIONS
    DEFINE LCD_DREG PORTA
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTA
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EBIT 3
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    ' START OF MAIN PROGRAM
    TRISB.0= 0
    PAUSE 500 ' Wait 0.5 second to initialize LCD
    LCDOUT $FE,1 ' Clear LCD
    LCDOUT $FE,2 ' Home cursor
    LCDOUT "Hello World"
    END ' End of program
    It Shows only Hello Wor wich fills the first 8 characters.
    Got the book PICBASIC PROJECTS by Dogan Ibrahim and didn´t find the right Define command
    "BWAAAHAAAA........" and so on...
    Anybody like to give me the hint?
    thanks in advance, ey
    you need to treat it as a 2X8 display.
          LCDOUT $FE,1,"12345678",$FE,$C0,"ABCDEFGH"
    Spin: Goto Spin
    about now?
    pssst! read carefully the LCDOUT section of the manual.
    Iran
    please try this:
    ' Set LCD Data port
    DEFINE LCD_DREG PORTB
    ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 4
    ' Set LCD Register Select port
    DEFINE LCD_RSREG PORTB
    ' Set LCD Register Select bit
    DEFINE LCD_RSBIT 1
    ' Set LCD Enable port
    DEFINE LCD_EREG PORTB
    ' Set LCD Enable bit
    DEFINE LCD_EBIT 0
    ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4
    ' Set number of lines on LCD
    DEFINE LCD_LINES 1
    lcdout $fe,1,"Hello"
    LCD Connection
    Pin1=Vss: connect to ground
    Pin2=Vdd: connect to Vcc=5V
    Pin3=Vo: connect to middle pin of the POT(20K) to control brightness
    Pin4=RS(register select): connect to micro pins that specify in the software(RB1)
    Pin5=RW(Read/Write): connect to ground because we want to only write
    Pin6=E(Enable): connect to micro pin that specify in the software(RB0)
    Pin7 to 10: No connection
    Pin 11 to 14: connect to RB4 to RB7
    Pin15: connect to Vcc with a resistor(100 or 200 ohm resistor is good)
    Pin16: connect to ground.
    pin 16 and pin 16 are for backlights
    the other two pins of pot should connect to VCC and ground and you should connect the MCLR with a 4.7K or 10K resistor to the VCC.
    in your program you define the 2*16 lcd but you should do this:
    DEFINE LCD_LINES 1
    Oct 2006
    Germany: Coal Area
    Wink LCD 10 Characters
    First things first:
    thanks for the help..I had the manual not in my vicinity.
    Now the LCD works...and I can scribble on my LCD impressing one of my kids, hihi!
    Will test your example Amindzo!
    Hasta la vista companeros!
    Oct 2006
    Germany: Coal Area
    Hi Amindzo,
    the change to "Lines 1" instead of Lines 2 doesent work,the LCD overwrites its own charaters.
    But man I´m glad it works !
    Next i´m into is the command "Pulsin" or "count"
    Those are nice, if you want my opinion, use PIC internal Timer in counter mode. Sure you're limited to use dedicated pin but it's much accurate.
  1. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  2. Only the first 8 characters.
    By timseven in forum mel PIC BASIC Pro
    Last Post: - 22nd September 2009, 02:43
  3. cant get my Lcd to work using Pic18f452
    By civicgundam in forum General
    Last Post: - 7th October 2007, 01:13
  4. How to work with LCD in a mode of 8 bits?
    By MCU Destroyer in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 22:10
  5. Can't get LCD to work with 16F88
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 10th September 2004, 12:05
