Long varible strings
Results 1 to 1 of 1
    Jul 2006
    Default Long varible strings
    Hi Folks,
    edit: VariAble (sp)
    I have a situation that I need to SerOut a 300+ long string whenever the the command "UPD" is recieved. Not only is it very long string but it will vary depending on the A2D voltage and GPIO inputs. It will be using a 12F683, so ram, eeprom, and code space is at a premium. Using MASM is not a option.
    I have wriiten a sample code that is conceptually what I am thinking, but may not be perfect syntax wise. I am hoping to get positive input on whether this method will 1) do the job 2) at 9600 baud be fast enough as not to miss and "UPD" polls, and 3) is there a better way?
    Off hand, it looks like short eeprom stings combined with the long Lookup statement are going to be an issue. In the real program the eeprom string will be about this long but the Lookup command would be about 4 times longer. Also in the actual program, a method of suppliing a varible A2D reading will be needed when ever a 255 or 254 is seen. I would have liked to have used a variable to store eeprom 'lookup' data but the 12F683 just does not have the ram to spare.
    Thank you
    DATA @1,  "Jack"
    DATA @5, "Tom"
    DATA @10,  "Jill"
    DATA @25, "jump"
    DATA @30, "ran"
    DATA @35, "walk"
    DATA @100, "hill"
    Data @104, "store"
    DATA @109, "well"
    DATA @150, "a"
    DATA @153, "the"
    DATA @156, "miles"
    DATA @161 "per hour"
    DATA @170, "to"
    DATA @172, "up"
    DATA @174, "under"
    DATA @179, "hyper-motovated"
    DATA @190, "ed"
    DATA @192, "ly"
    DATA @196, "ing"
    DATA @199, 13,10
    DATA @210, "."
    DATA @211, "?"
    DATA @212, "!"
    DATA @213, " "
    DATA @254, 254
    DATA @255, 255
    '12F683 has 128 Bytes of RAM, PBP uses 20 Bytes, Leaving 108 Bytes for varibles
    main: SerIn2 RxPin,Mode,ParityFail, TO, TOFail,[WAIT("UP"), STR Request\1]
     if Request[0] = "D" then
    	for UPDCounter = 0 to NumberOfStrings
    		Lookup UPDCounter,[1,213,35,190,213,255,213,156,213,172,213,150,213,100,213,179,212,199], Start
    		Lookup UPDCounter,[4,   1,  4,   2,  1,    1,    1,   5,   1,   2,  1,    1,    1,   4,   1,  15,  1,    2], Length
    		'Jack walked  12.3 miles up a hill hyper-motovated!
                    for Counter = Start to Length
    			read Counter,StringByte
    	                          if StringByte = 255
                                               Serout2,TxPin,Mode[dec MilesA2D]
    			    SerOut2 TxPin,Mode,[StringByte]
    		next Counter
        next UPDCounter
  1. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 16:45
  2. LONG Data type
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 11th February 2009, 04:06
  3. Serial communication fails after long pause
    By brid0030 in forum General
    Last Post: - 13th February 2008, 18:56
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:26
  5. I2CWRITE writing Strings to EEPROM
    By NavMicroSystems in forum mel PIC BASIC Pro
    Last Post: - 27th March 2005, 19:45
