What is the code to generate 2 PWM output for PIC16F877A. the second output is inverted with the first output.
I'm using the 16F876A, which is similar and I just used the following two commands. I'm not sure what you mean by inverted.
HPwm 1,value,2000
HPwm 2,value,2000
kind of half bridge i guess..
http://www.picbasic.co.uk/forum/showthread.php?t=4807
So this is a double post. One or the other should be removed. (I don't like double posts)
