Disable/Enable in Interrupts
Results 1 to 5 of 5
    Default Disable/Enable in Interrupts
    If I have a group of Subroutines on top of my program and don't want these to be interrupted, can only one Disable on top and Enable on bottom be enough? Or every sub must have their own pair?
    Is this correct:
    On Interrupt Goto myint
    Disable
    Sub1
    Sub2
    Enable
    Disable
    myint:
    Resume
    Enable
    'my main loop with interrupts enabled
    Thanks, Ioannis
    Feb 2005
    Kolkata-India
    Default Hopefully Yes
    The Enable/Disable are compiler directives which does or does not put the PBP int checking codes into you routine. So this should work. Remember strictly for PBP interrupts. Another way is to turn off the individual interrupt settings only keeping the Global INT turned on i.e., INTCON = $80. If you have other peripheral interrupts then they should be turned off too. (By only clearing the PIE bits perhaps) Mention your PIC and interrupts used.
    Sougata
    Thanks for the reply.
    The PIC is 16F877 and interrupts are coming from the UART module.
    My concern is if the disable directive needs to be inserted in every subroutine. Logicaly not as it is directive and covers all the block of commands until it finds the Enable pair.
    Apr 2013
    Default Re: Disable/Enable in Interrupts
    This would also work but I think it would cause problems for you. For example;
    if you call sub2 before calling sub1, then interrupts wont be disabled
    if you call sub1 and return to main, then again interrupts wont be enabled until you call sub 2
    So my suggestion is to disable - enable interrupts on each subroutine individually.
    Thanks, although back from the dead!
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. Continuous Interrupts when using DT_INTS and an INCLUDE file
    Last Post: - 15th January 2010, 22:42
  3. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  4. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  5. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 16:10
