Setting a pin twice
Results 1 to 5 of 5
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    Default Setting a pin twice
    Is there something wrong with having this as code:
    low PortA.0
    low PortA.1
    high PortA.0
    low PortA.1
    low PortA.0
    high PortA.1
    When I run this code where a pin set to the same value twice (A.1 is set low twice) A.1 never goes high when it is supposed to. Does setting a pin to a value disable it?
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    I now seem to have a much deeper problem. The following code results in ONLY portA.1 being high:
    DEFINE OSC 20
    high PortA.0
    high PortA.1
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    Talking
    Alright, never mind. I switched to PortB instead of PortA and all is good. I guess I just have a PIC with a messed up PortA.
    No! you have a PIC with 'features' on PORTA that must be disabled first!
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    Thumbs up
    *Reads datasheet*
    Doh!
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  2. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 14:01
  3. DS1820 with 16f688
    Last Post: - 23rd May 2009, 05:07
  4. Microcontroller with 2 way paging application problem
    Last Post: - 20th April 2007, 17:27
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 17:07
