Using a pic to measure current
Results 1 to 5 of 5
    Default Using a pic to measure current
    I have a 100 amp shunt which out puts 1 mv per amp. I will be using this shunt to measure current in a 24 volt dc circuit. My question is, even though the max voltage across the two leads on the shunt is limited to 100mv, I actually still have 23 to 24 volts on each side of the shunt which would damage the PIC's ADC.
    How is the best method for measuring the voltage drop of the shunt with a Pic's ADC?
    Jul 2005
    I think what you would need is possibly voltage divider that drops the voltage to 0-5v ?
    My shunt is a 100 Amp Shunt @ 1 mv/Amp
    Could I use a Differential Op Amp with the gain set to 10 to give 10mv/amp or 1 volt @ 100 amps?
    then my output from the op amp would be 0 to 1 volt for 1-100 amps?
    Does something like sound like it would work?
    Dec 2005
    Sep 2003
    Vermont
    Quote Originally Posted by rwskinner
    You will need an op amp to "condition" the voltage.A 10 bit A/D will not register any current until you are at over 4 amps of current draw! If you can float the PIC supply, you can attach the ground side of the circuit to the lower voltage side of the shunt.Your voltage input pin then attaches to the higher potential side.If you use the 24 volt system to power your circuit, you can put the shunt on the negative battery lead to the circuit under measurement. Connect the PIC/op amp to the battery negative ahead of the shunt, and your current measurement input on the other side of the shunt.
    Iffff...your maximum current drain is not that much, get a more sensitive shunt,say 10mV per amp, you may not need as much amplification, and will have less noise issues.
  1. Reducing PIC current to as low as possible...
    By FromTheCockpit in forum mel PIC BASIC Pro
    Last Post: - 18th November 2009, 04:28
  2. PIC conducting signal current when off
    By Viberer in forum Off Topic
    Last Post: - 28th May 2009, 17:27
  3. Mesuring current with pic
    By mitchf14 in forum mel PIC BASIC Pro
    Last Post: - 4th December 2008, 08:06
  4. Measure cable length with a PIC?
    Last Post: - 15th July 2007, 18:45
  5. Replies: 22
    Last Post: - 9th April 2007, 15:25
