HSERIN and HSEROUT problems
Results 1 to 2 of 2
    Iran
    Default HSERIN and HSEROUT problems
    i wrote this program to give serial information by jserin and hserout instructions.i want to send
    "C" charactor and then send B0 and B1 valude and in reciver first i should get the "C" charactor
    anf then get serial data and put them in B0 and B1 variables and show them on lcd.
    when i turn on reciver after 1 or 2 seconds some randim numbers is shown on lcd without turning on transmitter.
    could you help me with this problem?
    transmitter program:
    define OSC 4
    ' Set transmit register to transmitter enabled
    DEFINE HSER_TXSTA 20h
    ' Set baud rate
    DEFINE HSER_BAUD 1200
    ' Set SPBRG directly (normally set by HSER_BAUD)
    DEFINE HSER_SPBRG 25
    B0 var byte
    B1 var byte
    B0=125
    B1=225
    hserout ["C"]
    hserout [bin B0,B1]
    reciver program:
    define OSC 4
    'lcd defines
    ' Set receive register to receiver enabled
    DEFINE HSER_RCSTA 90h
    ' Set baud rate
    n var byte
    B0 var byte
    B1 var byte
    ArrayVar var byte
    C var byte
    n=1
    hserin [STR ArrayVar\n\C]
    hserin [bin B0,B1]
    lcdout $fe,1,#B0," ",#B1
    GaryD's Avatar
    GaryD Guest
    Quote Originally Posted by amindzo
    define OSC 4
    ' Set baud rate
    B0 var byte
    B1 var byte
    B0=125
    B1=225
    hserout ["C"]
    hserout [bin B0,B1]
    reciver program:
    define OSC 4
    'lcd defines
    ' Set baud rate
    n var byte
    B0 var byte
    B1 var byte
    ArrayVar var byte
    C var byte
    n=1
    hserin [bin B0,B1]
    amindzo:
    appears your attempting to use those 418mhz serial tx/rx modules:
    try this code out;
    define OSC 4
    ' Set baud rate
    B0 var byte
    B1 var byte
    B0=125
    B1=225
    hserout ["A","C",B0,B1]
    receiver program:
    define OSC 4
    'lcd defines
    ' Set baud rate
    B0 var byte
    B1 var byte
    hserin [wait ("C"),B0,B1]
  1. HSEROUT and Commas, What? Help Me Understand
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2009, 19:12
  2. HSERIN and HSEROUT commands
    By ryan in forum mel PIC BASIC Pro
    Last Post: - 6th January 2007, 22:11
  3. HSERIN and HSEROUT problems
    By amindzo in forum General
    Last Post: - 31st August 2006, 06:51
  4. Problems with HSERIN HSEROUT
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 20th September 2005, 17:24
  5. HSEROUT Problems
    By SergioRM in forum mel PIC BASIC Pro
    Last Post: - 7th April 2005, 23:17
