RS232 to blue tooth modules
+ Reply to Thread
Results 1 to 9 of 9
    brighton
    Cool RS232 to blue tooth modules
    Hi All
    i know there are lots of blue tooth dungle out there has anyone got any recommendations.
    Speed is not very important 9600 baud rs 232 is what i presently use.
    so i would need a pair that is not too expensive
    Isaac
    Jun 2006
    Question Hi
    Here is a Bluetoothmodule
    http://www.pollin.de/shop/shop.php?c...a=NjIyOTcyOTk=
    Iīm from Germany I donīt know if they can send it to you.....but itīs cheep for 20 €
    -Maybe thatīs what youīre looking for...
    Martin
    Cocoa, Fl
    Looks good Lester.
    Can you ship to the States?
    How much would it cost?
    Andy
    Go there
    http://www.crownhill.co.uk/product.php?prod=1544
    Add one in your basket, go to your basket and select the right shipping method... you'll have all the answers.
    Don't forget the Currency conversion... ready to jump on your chair?
    Cocoa, Fl
    This does not tell me how much it will cost in $US.
    Feb 2003
    Quote Originally Posted by atucker View Post
    Similar to how most US websites will not show anyone in the outside world the cost in their local currency then!!!
    At least Crownhill are prepared to ship all over the world. Many US websites wont do international shipping
    If it still gives the total cost in Pounds Sterling (GBP) then take a trip to http://www.xe.com/ucc put that value in the text box, select convert British Pounds to US Dollars and you will get the value in dollars.
    Dont forget that it will cost you slightly more than the true pound/dollar rate because your credit card company will have an exchange rate weighted in their favour and will probably also charge you conversion fee.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Cocoa, Fl
    Thank you Keith. for the information and tip about conversion charges.
    Andy
    Jan 2008
    Default Bluetooth problme with the PIC 16F977A
    hello...got thing want to ask u all de.....now i using the KC-21 bluetooth module to connect with the pic 16F877A and now i facing the problem is why my pic tx out the data to my kc-21 bluetooth cant tx to the receiver part and the receiver part i also using the kc21 bluetooth module with max232 and the hyperterminal there cant receiver the data from my tx there...what the happen...below is my programming souce code....hope u all can help me....!!! thanks.......a lot...!!!!
    Define LCD_DREG PORTB
    Define LCD_DBIT 4
    Define LCD_RSREG PORTB
    Define LCD_RSBIT 0
    Define LCD_EREG PORTB
    Define LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    DEFINE OSC 4 ' We're using a 4 MHz oscillator
    DEFINE ADC_BITS 8 ' Set A/D for 8-bit operation
    DEFINE ADC_CLOCK 1 ' Set A/D clock Fosc/8
    DEFINE ADC_SAMPLEUS 50 ' Set A/D sampling time @ 50 uS
    DEFINE debug_mode 0 ' Debug sending True serial data
    DEFINE debug_reg Portc ' Debug Port = PortC
    DEFINE debug_bit 6 ' Debug.bit = PortC.6
    DEFINE debug_baud 9600 ' Default baud rate = 9600
    define loader_user 1
    include "modedefs.bas"
    pause 2000
    LCDOUT 254,1, " WELCOME MY "
    LCDOUT 254,192,20,"MONITOR SYSTEM"
    samples VAR WORD ' Multiple A/D sample accumulator
    sample VAR BYTE ' Holds number of samples to take
    temp VAR BYTE ' Temperature storage
    samples = 0 ' Clear samples accumulator on power-up
    ADCON1 = %00000011 ' Set PORTA.0,1,2,5 = A/D, PortA.5 = +Vref
    PAUSE 500 ' Wait .5 second
    loop:
    FOR sample = 1 TO 20 ' Take 20 samples
    ADCIN 0, temp ' Read channel 0 into temp variable
    samples = samples + temp ' Accumulate 20 samples
    PAUSE 250 ' Wait approximately 1/4 seconds per loop 250
    NEXT sample
    temp = samples/20
    LCDOUT $FE, 1 ' Clear LCD
    LCDOUT "My Temp: ",DEC temp,"'C"
    serout Portc.6,N9600,[#temp]
    pause 5000
    If temp >= 80 then Alarm
    if temp <= 20 then Alarm1
    high portd.0
    samples = 0 ' Clear old sample accumulator
    GOTO loop ' Do it forever
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by slimpeng View Post
    CAPS CAPS CAPS , DEFINE's need to be in CAPS!
  1. UART vs software RS232
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 5th September 2008, 18:27
  2. Software RS232 and wireless modules
    Last Post: - 17th August 2008, 05:27
  3. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 20:39
  4. Help with CC1100 RF Modules.
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 27th November 2006, 20:58
  5. supply FSK COB modules and FSK modules
    By Elsa zhang in forum Adverts
    Last Post: - 8th August 2006, 06:40
