Let a variable change from bin to dec.
+ Reply to Thread
Results 1 to 3 of 3
    Question Let a variable change from bin to dec.
    Hi all !
    I tried the attached listning from Rentron.
    I tried to do compare a variable decimaltemp with a defined value of 25 and the varable TempC.
    The problem is that tempC is a binary and not the uservariable.
    I want to set variable decimaltemp = dec (TempC) but have'nt found any function for that.
    It is possible to do such function in serout serout2 and lcdout but not to a variable.....?
    What am i missing ?
    Rentron listning:
    http://www.rentron.com/PicBasic/one-wire3.htm
    Brgds Roy
    d1camero's Avatar
    d1camero Guest
    I am not sure I understand, but I will try anyways. Variable "decimaltemp" is a word which contains the ASCII representation of some number (e.g. 25). Is this correct? And you want to compare it to variable "TempC" which has the binary value of the temperature. Correct? If so, you need to convert the ASCII value in var "decimaltemp" to a binary value.
    To convert a to digit ASCII word to a binary value, you need to subtract 48 from each byte.
    this might work, I am sure others have way of doing it too.
    <code>
    DecimalTemp var word
    BinaryTemp var word
    BinaryTemp = (DecimalTemp.highbyte - 48)*10 + (DecimalTemp.lowbyte - 48)
    </code>
    Don
    Smile
    Your right !
    I understand now, its not decimal its of course ascii.
    Have not tested yet, but its make sense.
    Thanks Don !
    Brgds Roy
  1. EEPROM Variables (EE_Vars.pbp)
    Last Post: - 26th October 2012, 00:06
  2. PBPL 2.50 observations
    By BrianT in forum mel PIC BASIC Pro
    Last Post: - 17th September 2007, 23:58
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  4. Trouble with Serin2 and variable size
    By Ryan7777 in forum Serial
    Last Post: - 5th October 2006, 16:40
  5. Bin As Variable
    By Eyal in forum mel PIC BASIC Pro
    Last Post: - 30th September 2005, 17:33
