I AM USING SE K300i's CAMERA FOR AUTOMATICALLY EMAILING PICTURE WHEN TRIGGERED BY MOVEMENT DETECTOR SENSOR.
THE PIC BASED INTERFACE CONNECTED TO K300i AUTOMATICALLY OPERATES CAMERA & TAKES PICTURE WHEN MOVEMENT IS DETECTED.
AFTER TAKING PICTURE FROM CAMERA, SOFT KEY ON LEFT SHOWS SEND & SOFT KEY ON THE RIGHT SHOWS ROTATE OPTION.
THE PROBLEM I AM FACING IS IN USING AT *EKEY=1,”[“,2 COMMAND FOR SEND &
AT *EKEY=1,”]“,2 COMMAND FOR ROTATE OPTION i.e. SOFTKEYS.
INSTEAD OF ACTIVATING SEND & ROTATE OPTIONS, SCREEN GOES TO DELETE PICTURE OPTION.
ANY FORUM USER, PLEASE GUIDE ME IN APPLYING APPROPRIATE AT COMMANDS & SYNTAX FOR SOFTKEYS AS ABOVE AT COMMANDS DO NOT WORK & INSTEAD OPERATES CLEAR KEY.
AN EARLY RESPONSE WILL BE HIGHLY APPRECIATED.
Yawar
