Shift Registers For LCD Display
Results 1 to 7 of 7
    Puerto Rico
    Question Shift Registers For LCD Display
    Hello All ..
    Connect Pic with LCD and send data to LCD Using Shift Register.
    I need some Help for Shift Register with picbasic pro..
    if some one done this or Idea for it..
    is there a special reason for using the shift register? may it be changed for another PIC? if so things will be much simple, a single serial line and not much.
    No need to care about the LCD timing and all the plah plah around. SERIN, LCDOUT is all you need.
    That's my own opinion but i remind to saw that LCD/shift register combination here once or two.. i can't remind where now but if you do a search, you'll find it
    Wink SERIAL lcd
    Hi, Steve
    The discussion was around serial LCD, and also I2C drive via a PCF8574 ...
    Also, I've already used a bunch of CD 4094 ... but it was to drive 5 LED Displays from a serial output.
    You're right ... nothing to rebuilt the world !!! as serial LCDs are easy to find.
    In the wonderful ideas, let's point out the EDE 300, 700 and 701 ...
    New England
    Hi jetpr,
    Here's a link with some info:
    http://www.rentron.com/Myke1.htm
    Arch
    "Data sheets? I ain't got no data sheets. I don't need no data sheets. I don't have to read any stinking data sheets!"
    in case the costing is a must, i'll agree with the I/O expander or shift register stuff, uneless... i'll stick to the cheapest pic i can find with a built in OSC... OR not. The Myke Predko link should be a nice start point so far.
    I had posted this a long time ago, but can't remember where...
    Lot simpler just to get a PIC with enough pins to drive your LCD, as SHIFTOUT does not have all the nice data formatting features of LCDOut or SEROut...
    Jun 2006
    Bangalore, India
    Talking Serial LCD
    Just wondering if a simple conversion from normal LCD to serial LCD would help you...
    Check out the attachment and tell me if it helps...
    Use an f84 or some rewritable pic just in case...
  1. LCD's with Shift Registers, and LCDOUT
    By Darrel Taylor in forum PBP Extensions
    Last Post: - 3rd April 2015, 14:34
  2. assembly in Pic
    By lerameur in forum Off Topic
    Last Post: - 1st May 2008, 20:06
  3. Replies: 14
    Last Post: - 26th September 2007, 05:41
  4. Use the PIC 16f877 or 877A instead of shift registers.
    By tsanders in forum mel PIC BASIC Pro
    Last Post: - 27th October 2006, 17:23
  5. Shift Registers
    By shahidali55 in forum General
    Last Post: - 7th September 2006, 20:07
