Custom array of ports using array?
Results 1 to 23 of 23
    blainecf's Avatar
    blainecf Guest
    Default Custom array of ports using array?
    Is it possible to make an array, where each element equates to a non-consecutive port.
    Example:
    RELAY VAR BIT[10]
    ' (obviously, this doesn't work, but it does crash the compiler)
    SYMBOL RELAY[1] = PORTB.6
    SYMBOL RELAY[2] = PORTC.4
    SYMBOL RELAY[3] = PORTD.2
    ' cycle through relays
    for i = 1 to 3
    RELAY[i] = %1
    PAUSE 1000
    RELAY[i] = %0
    PAUSE 300
    next i
    Apr 2006
    Michigan
    I don't see why that wouldn't work. Try removing the symbols. I don't see the need for them. I declared relay at the top.
    Apr 2006
    Michigan
    I should say the Symbol command.
    Apr 2006
    Michigan
    Plus I think an array should start with variable 0 not 1. So it would be 0 through 9.
    May 2006
    Del Rio, TX, USA
    blainecf,
    I am not sure this will work like you expect. When you declare an array variable, it is acually pointing to a series of consecutive RAM addresses. So later, when you use the variable, it goes to the address and uses the value currently at that address. What you are looking to do is create an array that is actually pointing to the addresses represented by the individual pins (which are not even consecutive).
    After playing with it a little and looking at the .lst file, I don't know if this can be done in PBP. Once you have created the array, any further references to the array are modifying/reading the contents, not the address. The only info in the manual I see is assigning a label to a specifc pin. Which is handled using different ASM commands.
    Maybe one of the real gurus could chime in here and set me straight if I'm wrong (Melanie? Darrel?). Or provide a workaround to do the job.
    Hope to get a better answer,
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Feb 2003
    Smile a little more info ...
    Although slightly contrived and uses more RAM - this does it.
    Relay var Byte[4]
    x var byte
    i var byte
    Relay[1] = 14  'RB6
    Relay[2] = 20  'RC4
    Relay[3] = 26  'RD2
    for i = 1 to 3
         x = relay[i]
         porta.0[x]=1
         PAUSE 1000
         porta.0[x]=0
         PAUSE 300
    next i
    Paul Borgmeier
    USA
    blainecf's Avatar
    blainecf Guest
    Default Makes a case for functions with pass-by-reference
    Bummer,
    It's these little things that make programming clean and respectable.
    Still, it seems a shame that I can create an aliassed variable that is equivilent to a pin, but not an array element. Seems like the same type of technology.
    So close, yet so far.
    Thanks so much for your input, everyone.
    May 2006
    Del Rio, TX, USA
    Paul:
    Thanks for "chiming in" with a solution. I just want to make sure I understand what your code is trying to do so I can learn from it. I suspected there was a way to shoehorn this idea into PBP.
    Relay[1] = 14  'RB6  is 14 bits offset from RA0
    Relay[2] = 20  'RC4  is 20 bits offset from RA0
    Relay[3] = 26  'RD2  is 26 bits offset from RA0
    This array is establishing an offset from bit.0 on PORTA. I assume that most pics have PORTA-PORTX at consecutive regiester addresses (I only have a couple of datasheets to reference, but that's what I see)
    for i = 1 to 3
         x = relay[i]
         porta.0[x]=1
         PAUSE 1000
         porta.0[x]=0
         PAUSE 300
    next i
    With the Relay[] array containing the correct offets, one can now use that with porta.0[x] to select the desire bit. Since porta.0 points to a bit, the offset [x] is in bits as well.
    Did miss this "feature" in the PBP manual? Can I extend this idea further in that the inclusion of [X] to any reference that points to a register will actually cause an offset reference in accordance to the base reference. ( ie, if it was a word variable that [x] was added to, [x] would actually reference a register x*2 bytes offset?).
    Feb 2003
    Smile Neat Trick
    Steve,
    Yes, you are 100% correct in the logic - that is exactly how it works. This “trick” is not in the manual but first appeared on the PicBasic List in 2002 (http://list.picbasic.com/forum/messages/4011/4739.html? ).
    I remember being excited when this particular email came because it solved a problem I was having at the time. The links posted in my reply #6 above by Bruce and Melanie also clearly demonstrate this trick's use.
    As I understand it, it works for all SF/GP Register locations, not just PORT bits, hence the indexed locations must be sequential like you mentioned. I always check the datasheet if I am going to use it on sequential Ports to make sure they are indeed sequential (and they always have been for the PICs I have used).
    Paul
    Post
    Since portpins rarely move(constants) you could use the LOOKUP statement to get the offset values. Should free up some RAM. The LOOKUP could ofcourse be placed in a subroutine if you need to access it from many different locations in your program. That way saving ROM.
    x      var byte
    i       var byte
    for i = 0 to 3
    '               a  b  c  d
    '               0  6  4  2
         LOOKUP i, [0,14,20,26], x
         porta.0[x]=1
         PAUSE 1000
         porta.0[x]=0
         PAUSE 300
    next i
    /Ingvar
    Feb 2003
    Smile Sweet
    Nice improvement! - The code for what blaine originally wanted to do is getting pretty clean considering it is an undocumented feature.
    Best,
    Paul
    Nice job Paul & Ingvar..;o}
    Yet another version.
    '   BASIC/ASM version = 172 words
        x   var word
        i   var byte
        RelayNum var PORTA
    '    High byte = FSR / Low byte = port pin (or multiple pins)
        RLY1 CON %0000010100000001 ' PORTA|Bit0
        RLY2 CON %0000011001000000 ' PORTB|Bit6
        RLY3 CON %0000011100010000 ' PORTC|Bit4
        RLY4 CON %0000100000000100 ' PORTD|Bit2
        ADCON1 = 7
        PORTA = 0 : PORTB = 0 : PORTC = 0 : PORTD = 0
        TRISA = 0 : TRISB = 0 : TRISC = 0 : TRISD = 0
    RelayOn macro
        movf  _x+1,w ; high byte = pointer to port file reg
        movwf FSR    ; load FSR
        movf  _x,w   ; low byte = port bit to change
        xorwf INDF,f ; toggle port pin
    RelayOff macro
        movf  _x,w   ; reload port pin to toggle
        xorwf INDF,f ; do it
        for i = 0 to 3
            LOOKUP2 i, [RLY1,RLY2,RLY3,RLY4], x ' lookup file reg & XOR pattern
            @ RelayOn
            PAUSE 500
            @ RelayOff
            PAUSE 500
        next i
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    I agree, good stuff!
    Here's another one.
    INCLUDE "VirtualPort.bas"
    Relays  VAR BYTE : Relays = 0
    RelayPort  macro
        Vpin  0, PORTB, 6  ; RELAY1
        Vpin  1, PORTC, 4  ; RELAY2
        Vpin  2, PORTD, 2  ; RELAY3
      OutputPort  RelayPort    ; Set Port to OUTPUT
    Then, here's a test loop to cycle thru the relays...
    i  VAR BYTE
        for i = 0 to 2
            Relays = DCD i
            @  WritePort _Relays, RelayPort
            PAUSE 500
        next i
    Goto Main
    Code size = 104 words, 65 without the PAUSE.
    or you can just...
    Relays = %010
    to turn on RELAY2 by itself.
    Code size = 21 words.
    http://www.pbpgroup.com/Vport/VirtualPort.bas.txt
    HTH,
    Feb 2003
    Smile Amazing yet again ...
    Bruce, Darrel,
    You guys are amazing yet again! I continue to learn and what good fun.
    Paul
    Edit - I am an ASL student (Assembly Second Language) student and removed some code from this post that was not correct.-pb
    Just keeps getting better & better ehh...;o}
    Nice work Darrel.
    -Bruce
    tech at rentron.com
    May 2006
    Del Rio, TX, USA
    Talking Bruce and Darrel Cheated!!!
    Bruce and Darrel,
    You guys cheated(lol). Paul and Ingvar got the job done tidely with PBP. You had to resort to Assembly.
    This is what I love about this forum. Bright, capable folks working together to make a good product (PBP) work even better! I knew in my initial post that there just had to be a way to do this, it just was not documented and was beyond my basic skills. Great learning oppurtunity. I think this is worth putting in the FAQ (in some form) for others to reference later.
    Even though it wasn't my post originally, thanks guys for the great lessons.
    Cheers,
    Thanks Bruce, Paul and Steve,
    And yes I did cheat, by using a module that I had already written.
    I started writing VirtualPort in response to this post from Osiris
    http://www.picbasic.co.uk/forum/showthread.php?t=3554
    He was looking for a way to have a 16-bit port that was scattered across random pins. By the time I got it working, Melanie had already given him what he needed, so I didn't bother posting it.
    But, I soon realized that it was going to be more usefull than originally intended so continued to add more macro's and features, and have managed to do some pretty cool stuff with it.
    Here's how the 16-bit port for Osiris looked...
    MyPort   VAR Word  SYSTEM
    MyPortPins  macro        ; these define which bits go with which pins
        Vpin   0, PORTB,0
        Vpin   1, PORTC,4
        Vpin   2, PORTA,0
        Vpin   3, PORTC,1
        Vpin   4, PORTC,3
        Vpin   5, PORTC,0
        Vpin   6, PORTA,1
        Vpin   7, PORTC,5
        Vpin   8, PORTB,2
        Vpin   9, PORTB,3
        Vpin  10, PORTC,2
        Vpin  11, PORTC,0
        Vpin  12, PORTB,4
        Vpin  13, PORTB,6
        Vpin  14, PORTB,5
        Vpin  15, PORTC,7
    @  OutputPort  MyPortPins
    @  WritePort   MyPort, MyPortPins
    @  InputPort   MyPortPins
    @  ReadPort    MyPort, MyPortPins
    This creates a full 16-bit bi-directional port that can be placed on ANY pins in ANY order.<HR>
    Additional macros can also allow control of Direction, Enable, Latch pulses etc. in the same structure. Here's an 8-bit port with flow control
    Direction  VAR PORTB.5
    Enable     VAR PORTB.1
    Port8_Read  macro
        PinLow _Direction   ; Set direction pin for Read
        Vpin   0, PORTB,0
        Vpin   1, PORTC,4
        Vpin   2, PORTA,0
        Vpin   3, PORTC,1
        Vpin   4, PORTC,3
        Vpin   5, PORTC,0
        Vpin   6, PORTA,1
        Vpin   7, PORTC,5
        PulseLow  Enable, 2 ; Low pulse for 2uS
    Port8_Write  macro
        PinHigh _Direction   ; Set direction pin for Write
        Vpin   0, PORTB,0
        Vpin   1, PORTC,4
        Vpin   2, PORTA,0
        Vpin   3, PORTC,1
        Vpin   4, PORTC,3
        Vpin   5, PORTC,0
        Vpin   6, PORTA,1
        Vpin   7, PORTC,5
    @  OutputPort  Port8_Write
    @  WritePort   MyPort, Port8_Write
    @  InputPort   Port8_Read
    @  ReadPort    MyPort, Port8_Read
    Or that can be simplified like this...
    Port8_Pins  macro
        Vpin   0, PORTB,0
        Vpin   1, PORTC,4
        Vpin   2, PORTA,0
        Vpin   3, PORTC,1
        Vpin   4, PORTC,3
        Vpin   5, PORTC,0
        Vpin   6, PORTA,1
        Vpin   7, PORTC,5
    Port8_Read  macro
        Port8_Pins
    Port8_Write  macro
        Port8_Pins
    <hr>
    Another similar question that keeps popping up every now and then, is how to use an LCD that's not connected to a contiguous nibble of a port.
    This program allows you to do that, and also ties it in with LCDOUT for a "transparent" interface.
    INCLUDE "HighJack.bas"
    @  HighJack  LCDOUT,  _LCDsend
    Clear
    ;----[ Change these to match your LCD ]---------------------------------------
    LCD_DB4   VAR PORTB.0
    LCD_DB5   VAR PORTB.4
    LCD_DB6   VAR PORTC.6
    LCD_DB7   VAR PORTC.3
    LCD_RS    VAR PORTD.1
    LCD_E     VAR PORTD.0
    LCD_Lines     CON 2    ' # of Lines on LCD,  1 or 2+
    LCD_DATAUS    CON 50   ' Data delay time in us
    LCD_COMMANDUS CON 2000 ' Command delay time in us
    ;----[Virtual LCD Port --- 4bit mode]----------------(Don't Change)-----------
    LCD_Port_HNIB  macro           ; Port definition for LCD High Nibble
        Vbit   LCDCDFLAG, _LCD_RS  ; Select Command/Data register
        Vpin   4, _LCD_DB4         ; Put the High Nibble on the bus
        Vpin   5, _LCD_DB5
        Vpin   6, _LCD_DB6
        Vpin   7, _LCD_DB7
        PulseLow  _LCD_E, 2        ; pulse the Enable Pin for 2 us
    LCD_Port_LNIB  macro           ; Port definition for LCD Low Nibble
        Vpin   0, _LCD_DB4         ; Put the Low Nibble on the bus
        Vpin   1, _LCD_DB5
        Vpin   2, _LCD_DB6
        Vpin   3, _LCD_DB7
      OutputPort  LCD_Port_HNIB    ; Set LCD bus to OUTPUT
    ;----[Main program starts here]-----------------------------------------------
    LoopCount  VAR WORD
      lcdout $FE,$80, dec LoopCount
      LoopCount = LoopCount + 1
    goto Main
    ;----[Send a byte to the Virtual LCD PORT]--------called by LCDOUT------------
    TempChar        var  byte
    Char            VAR  Byte
    LCD_Initialized VAR  FLAGS.1
    RSS             VAR  FLAGS.0                ; LCD RS State
    LCDsend:
          @  MOVE?AB  _TempChar                 ; Get char sent by LCDOUT, in WREG
          if !LCD_Initialized then LCD_Init     ; Make sure LCD was Initialized
      LCDAfterInit:
          if TempChar = $FE then RSS=0 : goto LCDsendDone ; next char is Command
          Char = TempChar
      LCDsendCOM:
          @  WritePort   _Char, LCD_Port_HNIB   ; send the High Nibble
      LCDsendShortCOM:
          @  WritePort   _Char, LCD_Port_LNIB   ; send the Low Nibble
          if LCD_RS OR (Char > 2) then
              PAUSEUS LCD_DATAUS                ; Data delay time in us
              PAUSEUS LCD_COMMANDUS             ; Command delay
          if LCD_Initialized then RSS = 1       ; Set RS to Data next time
      LCDsendDone:
    ;----[Initialize the LCD]-----------------------------------------------------
    LCD_Init:
        LOW LCD_RS : HIGH LCD_E   ; Start with RS LOW and Enable High
        Char = 3   : gosub  LCDsendShortCOM : pause 6
                     gosub  LCDsendShortCOM : PAUSE 1
        Char = 2   : gosub  LCDsendShortCOM : PAUSE 1  ; Start 4-bit mode
        Char = $28 : gosub  LCDsendCOM  ; Function Set, 4-bit, 2-line, 5x7
        Char = $0C : gosub  LCDsendCOM  ; Display ON
        Char = $01 : gosub  LCDsendCOM  ; Clear Screen
        Char = $06 : gosub  LCDsendCOM  ; Entry Mode
        LCD_Initialized = 1             ; LCD has been Initialized
    goto LCDAfterInit
    Of course this relies on another program I wrote, "HighJack", to actually link in to LCDOUT. But nobody bothered to respond to this thread
    http://www.picbasic.co.uk/forum/showthread.php?t=3290
    so I never bothered posting it.
    May 2006
    Del Rio, TX, USA
    Darrel,
    I am slowly worming my way through your code and I noticed in VituralPort the local variable "Vaddr" in the the Vpin macro. What's it for? I did a search for it and I only see it being assigned a value (in two places), but otherwise never used.
    Also, you mentioned "HighJack", but did not post it.
    BTW, I have been following your "Wish List" thread. Congrats. Get a good chair! And did you set a new avatar?
    Wish you all success,
    Excellent!
    <table><tr><td valign=top></td><td>Thanks Steve. That's a bug. Thanks for finding it. The Vaddr allows it to work with WORD variables for the 16-bit ports. Then, these lines...
              if (PortAction == 0)                   ; read
                  MOVE?TT  P, Pbit, PortVar, VarBit
                  if (PortAction == 1)               ; write
                      MOVE?TT  PortVar, VarBit, P, Pbit
    Should have used Vaddr instead of PortVar. I got the VarBit, but missed the Vaddr.
    I will make the changes. &nbsp;http://www.pbpgroup.com/Vport/VirtualPort.bas.txt
    Yeah, that new chair idea is sounding pretty good
    and, yup spruced up the avatar a bit. Hopefully it's not too annoying.
    Read the part about HighJack again.</td></tr></table>
    Thanks again,
    &nbsp; &nbsp; DT
    May 2006
    Del Rio, TX, USA
    Question
    Alright. I've gotten though the code but still have one question. Why use seperate delay code? It's commented as "Similar to PAUSEUS, but ASM interrupt compatible".
    Yet I'm missing something here. Why is this more compatible with ASM interrupts then the PBP PAUSEUS routine? I've been using the PAUSEUS in my current project, with both high and low priority ASM interrupts (18F4620), without any problems. The delays are slightly longer than requested, due to the interrupt occuring in the delay loop (trival for most apps), but no other ill effects I've noticed. This 'error' in delay time would occur with any delay based on code exectuing timing and a loop, unless interrupts were disabled prior to entering the loop. So this can't be the reason.
    Also, I think the PBP routine could be easily called by inserting the following where the delay is required ("_us" is a predefined word variable/literal containing the delay in us):
            movlw   (_us) >> 8
            movwf   R0 + 1
            movlw   low (_us)
            call    PAUSEUSL        ; Delay for us
    PAUSEUS_USED = 1
    One thought that just occured to me. Becuase you use a macro, your not pushing anything onto the stack. So you are avoiding any possible overflow due to interrupts occuring during the delay. Is this it?
    It's not that it's OK to "Be interrupted", but it's OK to be in the routine that does the interrupting.
    PAUSEUS has a couple shortcomings. One, is that it uses PBP's system variables (R0-R8). So it corrupts PBP's flow if it's used in an ASM interrupt without "Instant Interrupts".
    The second is that PAUSEUS has a minimum delay of around 24us @ 4mhz since it figures out the delay Count at run time.
    The DelayUS macro can pause for a little as 1us by calculating the delay at Compile Time, and adding a single NOP if that's all that's needed. Or a 3cycle loop and 2 NOP's if running at 20mhz. And it doesn't use any PBP system vars.
    It can be useful in other programs as well, so I'll show it here again for those that aren't as diligent as you Steve.
    VP_DelayCount  VAR WORD BANK0  ; Used for DelayUS only
    ;----[Similar to PAUSEUS, but ASM interrupt compatible]---(accurate to 1uS)--
    DelayUS  macro T
      local InstCount, LoopCount, DelayLoop, LoopsDone, LeftOver, Offset
    ; -- Calculate number of 3 cycle loops plus leftover nop's to execute --
    InstCount = ((OSC*10/4)*T+5)/10 ; Inst cycles required for delay (Rounded UP)
    LoopCount = InstCount / 3
        if (LoopCount > 255)
    Offset = (LoopCount >> 8) * 7 + 4
    Offset = 0
    ; -- Adjust for HighByte --
    InstCount = InstCount - Offset
        if (Offset > (LoopCount & 0FFh))
    InstCount = InstCount - 4
    Offset = 0
    LeftOver  = InstCount % 3
        if (LoopCount > 0)
            MOVE?CW  LoopCount, _VP_DelayCount
    DelayLoop
            decfsz   _VP_DelayCount, F               ;  1
            goto     DelayLoop                       ;  2   3 per loop, under 256
                movf     _VP_DelayCount + 1, W       ;  1
                btfsc    STATUS, Z                   ;  1
                goto     LoopsDone                   ;  2   4 on last loop
                decf     _VP_DelayCount + 1, F       ;  1
                goto     DelayLoop                   ;  2   7 per highbyte count
    LoopsDone
        if (LeftOver > 0)
            nop
        if (LeftOver > 1)
            nop
    May 2006
    Del Rio, TX, USA
    Exclamation
    Ok,
    Quote Originally Posted by Darrel Taylor
    This makes much more sense than what I was thinking.
    On thing that should be mentioned. It is generally best to keep interrupt service routines (ISR) as short as possible, so that additional interrupts are not "missed" while handling the current interrupt. So putting a pause into an ISR must be used with caution, and with a good understanding of how it will effect other timing related items. One exception to this would be the 16-bit PICs with High and Low priority interrupts (which are supported by PBP), where a pause in a low prority interrupt would not prevent a high priority interrupt from executing. So all the time critical inturrupts could be High Priority.
    Last Post: - 14th June 2016, 08:55
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 05:46
  3. Custom array of pins
    By bmagistro in forum mel PIC BASIC Pro
    Last Post: - 29th March 2009, 00:15
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. Making Array of two ports
    By John7 in forum General
    Last Post: - 5th March 2005, 03:20
