+ Reply to Thread
Results 1 to 8 of 8
    Tony85's Avatar
    Tony85 Guest
    Default Problem with I2Cread and I2CWRITE function
    Hello,
    I have read MELANIE'S FAQ (I2CRead & I2CWrite not working as expected) but my code always not working. Normaly I must have minute =12 but it give me 0
    I am using 16F877A and 24LC64 (pin1, 2, 3, 4, 7 to the ground ; 8 to 5v ; SDA and SDL to 16F877A).
    Any idea ?
    My code :
    Include "modedefs.bas"
    asm
    ERRORLEVEL -306, -302
    endasm
    DEFINE LCD_DREG PORTD
    DEFINE LCD_RSREG PORTA
    DEFINE LCD_RWREG PORTA
    DEFINE LCD_EREG PORTA
    DEFINE LCD_RSBIT 2
    DEFINE LCD_RWBIT 1
    DEFINE LCD_EBIT 0
    DEFINE LCD_DBIT 0
    DEFINE LCD_BITS 8
    DEFINE LCD_LINES 4
    RETRO VAR PORTA.3
    SCL VAR PORTC.3
    SDA VAR PORTC.4
    minute VAR word
    adr var word
    ADCON1=7
    TRISA=%11100000
    TRISB=%11110000
    TRISD=%11110000
    i2cdevice CON %10100000
    High RETRO
    MAIN:
    adr=1
    I2CWRITE PORTC.4,PORTC.3,i2cdevice,adr,[12]
    pause 10
    i2CREAD PORTC.4,PORTC.3,i2cdevice,adr,[minute]
    pause 10
    LCDOUT $FE,1
    LCDOUT $FE,192,dec minute,"min "
    Oct 2003
    holland
    Maybe you forgot 2 resistors ?? From SDA to Vcc and SCL to Vcc (4K7)
    Tony85's Avatar
    Tony85 Guest
    Between 16F877 SDA pin and 24LC64 SDA pin I have a 330Ohms resistor and Between 16F877 SCL pin and 24LC64 SCL pin I have a 330Ohms resistor.
    Oct 2003
    holland
    These are serie resistors, that is no problem. But you must put also 2 resistors from 4K7 to the + power of the PICCHIP and the SDA and SCL line. Kind of pullup resistors.
    Tony85's Avatar
    Tony85 Guest
    Oct 2003
    holland
    You used 10K resistors, lower them to 4K7. And put also a capacitor of 100 nF over each supply point of each ic, near each ic.
    Is your oscillator running well? Because normally I put 22pF capacitors at a 4 MHz cristal.
    Put also an extra elco (10uF) and a capacitor of 330nF near your 7805. This prevents oscillating of this component.
    Tony85's Avatar
    Tony85 Guest
    Talking
    I just have put 4.7k resistor and it work good
    Thanks a lot
    Tony
    Oct 2003
    holland
    You'r welcome.
    M
  1. I2CRead & I2CWrite not working as expected
    Last Post: - 14th April 2007, 17:37
  2. Problem with I2Cread and I2CWRITE function
    By Tony85 in forum mel PIC BASIC Pro
    Last Post: - 6th June 2006, 18:32
  3. PFC8583 Connection and I2Cwrite I2cread!
    By uludere72 in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 13:32
  4. I2CRead / I2CWrite Problem?
    By koossa in forum mel PIC BASIC Pro
    Last Post: - 31st October 2005, 18:26
  5. I2CWRITE and I2CREAD
    By Tomas in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2004, 02:30
