Pic16f877
Results 1 to 11 of 11
Thread: Pic16f877
    abood's Avatar
    abood Guest
    Default Pic16f877
    I am using PIC16f877A for the first time. I tried a simple program to light two led in portb which is working for PIC16f84A (with 4 MHz crystal), but it doesn't work for 16f877A (with 20 MHz) ………what's wrong ?
    This is the program
    '40 MHz OSC
    TRISB=0
    START:
    PORTB.0=1
    PAUSE 1000
    PORTB.0=0
    PAUSE 1000
    PORTB.1=1
    PAUSE 1000
    PORTB.1=0
    PAUSE 1000
    GOTO START
    at least there's a missing DEFINE OSC 20 line but it's suppose to work anyway... but faster than you expect. I suspect a bad config fuse setting and/or bad hardware
    razman's Avatar
    razman Guest
    Default Need help to program pic 16f877a with temperature sensor
    i am using 16f877a, Please help me to make a program (C or Asm never mind) for my project:
    - port a0 as a input from LM34 sensor (small voltage output where 10mV/degree Farrenhiet- i want use 0.95V to activate port a0)
    -port a1 as input from mini switch
    -port c0 as a output to relay circuit.
    The senario is if any input high, output (to relay and fan) will be on.
    Hopely u all can help me, please.. thanks.
    ps; i am blur to use adc
    Feb 2003
    Quote Originally Posted by razman
    Sorry to disappoint but you will notice that the name of this forum is
    MELabs PICBASIC
    whilst some snippets of ASM are used from time to time I think you will find a distinct lack of "C".
    We are a freindly bunch here so if you would like some help in writing your program in PICBASIC than I am sure you will get some useful tips.
    (I was going to say "pointers" but we dont do "C" )
    Keith
    www.diyha.co.uk
    www.kat5.tv
    razman's Avatar
    razman Guest
    Is it PIC16F877a about different with picbasic forums willing...
    razman's Avatar
    razman Guest
    my problems is to use adc (analog input from LM34) in 16f877a.
    Oct 2006
    Default pic16f877a
    hi all,
    I am doing a project using PIC and CAN controller.iam also using temperature sensor as my input to PIC and transmitting to other node through bus. i like to get some help in interfacing CAN with PIC through SPI interface in PIC and like to display a simple message in LCD connected to PIC. PLZ help me writing the code in Embedded C and iam using PIC16F877A microcontroller.
    razman's Avatar
    razman Guest
    i just finished my project using LM34 temperature sensor as a input and 16F877A microcontroller. 2 input (1 as a ADC for lm34 input) and 1 output. If u want my c program, please write personally to me ([email protected])
    Oct 2006
    Default pic16f877a
    hi,
    iam using micro C for programming my pic.i need to know the hardware interfacing or communication of 2 pic microcontrollers.i need to whether i need to connect 2 pic boards for making them communicate.i like to tranmit a simply msg to a pic and display it in a lcd or seven segment.i tried to do it by making an led to toggle if the msg is tranmitted .the led is toggling but i cudnt find whether the msg is transmitted or not.
    plz reply me.it would be more helpful if i get the embedded C coding too.
    Jan 2006
    Istanbul
    Hi ANU,
    As you know this is a PBP forum.
    Also, the forum includes so many examples for PIC to PIC communcations in several ways.
    Search them through.
  1. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  2. PIC16F877 I2C programme
    By cooqo in forum mel PIC BASIC
    Last Post: - 21st April 2008, 11:02
  3. Replies: 8
    Last Post: - 17th January 2007, 20:18
  4. Ericsson T10 interface with PIC16F877
    By jam547 in forum GSM
    Last Post: - 25th March 2006, 23:27
  5. USB interface from PIC16F877 to PC
    By headshouter in forum USB
    Last Post: - 26th February 2006, 05:58
